Mainsheet help: C&C 24 - SailNet Community
post #1 of 13 Old 08-01-2018 Thread Starter
Hi all.
After a few boatless years Iíve purchased a 1980 C&C 24 for short cruises around the islands, mostly singlehanded, occasionally with my wife. For a small boat, it has some great cruising enhancements, like a hard dodger (Tartarooga, great quality) and cabin heater. So far Iím really enjoying it.
But my shins are tired of being scraped raw by the mid-cockpit traveller. Iím purely a cruiser, and a lazy sail trimmer, and Iíd gladly give up a bit of boat speed and efficiency to open up the cockpit. The original location for the main sheet was a padeye in the cockpit sole, right under the current traveller. That would certainly be the simplest option, and would help some; even more, at anchor, if I could somehow rig the sheet on a quick-release. I suppose Iíd still be stubbing toes, unless I used a folding padeye.
A second option is to rig boom-end sheets to the quarters. Iíve had this before on a Crown 23, and it was okay; the boomís shorter on this boat, so the sheets would encroach on the cockpit a bit more, especially off the wind; also a high stern rail might be an issue. Sheets would be nicely out of the way at anchor, though.
An off-the-wall idea is to use the dodger framework and mount the sheets (maybe twin sheets?) near the top aft corners. These dodgers have been used that way on much larger boats, but thereís not much clearance between the dodger and boom so Iím not sure itís feasible. Iíd consult with the dodger maker before I tried it, but the forces are relatively light, and the dodger is very solid.
Any thoughts are appreciated, and specifically if you know of a way to have a padeye mount, with a spring or standup of some kind, thatís easily removed at anchor let me know!
Many thanks... Perry.
idearat is offline
post #2 of 13 Old 08-01-2018
Above 5 knots
Dock
Re: Mainsheet help: C&C 24
https://www.catalinadirect.com/index...c-22-c-250.cfm
Barney post highly recommended... although that'd be another thing to trip over.
Frankly that traveler looks perfect.
MINI MOO, a 1983 Wavelength 24 - she's a fast cow!
SailingUphill is offline
post #3 of 13 Old 08-01-2018
Markwesti's Avatar
This shouldn't be to hard to rig up , you could use the attachment points on the split backstay for a start .
https://www.google.com/search?q=end+...RcIKGsfR_Dc0M:
Westsail 28 , Patricia A
Markwesti is offline
post #4 of 13 Old 08-01-2018 Thread Starter
SailingUphill, the barney post idea is a great one if I leave the sheet in the cockpit. Hadn't seen anything like that. Hmm... maybe I could engineer a base so the whole thing is removable at anchor...
Markwesti, that's the setup I'm likely to try first, as I have everything I need aboard. Just not sure how well the sheet will work with the rails aft.
Thanks folks; keep the ideas coming!
idearat is offline
post #5 of 13 Old 08-01-2018
al brazzi
A vang will give almost and maybe better control of the boom, if you don't have one now. Put a removable clip on the mainsheet and clip it out of the cockpit at anchor. I pull my boom over with a removable preventer line to get the boom out of the way when not sailing. My mainsheet Traveller is exactly where yours is but with a bridgedeck I have to climb over anyway.
albrazzi is offline
post #6 of 13 Old 08-01-2018
JimsCAL's Avatar
Yep.
S/V First Tracks
1985 Cal 33-2
JimsCAL is online now
post #7 of 13 Old 08-02-2018 Thread Starter
Yep.
I knew I'd get flak over removing the traveller. Obviously it's better for mainsail shape control. But trust me, it may look like lots of room, but this is a 24í boat, and stepping over that track whle ducking under the dodger, down into the short space aft of the companionway sill, gets old fast... as do I. I'm still pretty limber, but that's more contorting than I really enjoy, and my shins are showing the scars of the occasional misjudged step.
I'm afraid I just care more about being comfortable aboard and moving about my boat freely than achieving perfect efficiency and top boat speed. There is a good vang to help with sail shape. The relative size of the main on this boat, compared to, e.g., my old Alberg 37, makes me think the real-world losses by dispensing with the traveller will be minimal.
I'm sure I'm in the minority on this one. I'm fine with that.
Thanks again... Perry.
idearat is offline
post #8 of 13 Old 08-02-2018
One of None
deniseO30's Avatar
Flak? It's your boat! Doesn't matter what you do, it only matters to you, nobody else, you don't need anybody's permission, although it would help if you knew something about rigging and handling
Loose the dodger. What you're feeling is the pain of having a smaller boat because you once had a larger boat it's even more "painful" and unlikely you'll ever stop tripping over the traveler
Your problem really is the Dodger, it's nice but on a tiller boat, it doesn't really keep the sun away very much.
A Bimini top is better because it would clear the main sheet coming up off the traveler. Whoever made the dodger should be getting the flak lol
The only time I ever used the Dodger on my boat was when it was cold out and when wind was driving into our face which was almost never, so I took it off.
A properly made Bimini top will keep the sun off you and yours. The drawback on a smaller boat like yours, you may not be able to stand up, but it looks like the boom is already too low for that anyhow. The bim will need thru holes for the back stay which are easy to do, I had them on my boat.
It's pretty much as the only option other than where it's at now,. putting it on top of the cabin is just as bad, instead of as tripping you have to duck under.
Go with the end boom sheeting/ Crosby rig, if you have problems with the boom lifting while under way you may need a boom Vang.
Homework assignment; learn about rigging,
Keywords to look up Crosby rig, end boom sheeting, boom Vang.
My last project!
deniseO30 is offline
post #9 of 13 Old 08-02-2018
Above 5 knots
Dock
Um, owner of a 24 foot sailboat, and if you took my cockpit traveler away I think I'd be hunting you down
You may likely be missing the point, a dodger on a 24 foot boat might be part of your problem, not the traveler. But hey, its YOUR boat.
post #10 of 13 Old 08-02-2018 Thread Starter
Thanks for your thoughts, folks.
Denise, Iíve had end boom sheeting of different types on a couple of prior boats, and Iím aware of the Crosby rig for dinghys, though not by that name, and I confess I donít have a clear picture yet on how the bridle functions as a traveller. Iíll do more research. Also, as I mentioned, I do have a good boom vang. I may not be quite as ignorant of the options as I seemed, but thereís always more to learn.
The Ďflakí comment was meant light-heartedly; perhaps I should have added a smiley. Obviously Iím not here looking for permission or approval for my choices. Iím here to learn (homework) from the collective knowledge and experience on the site, and I appreciate your input.
As for the dodger, itís non-negotiable. Here in the PNW, where we can sail year Ďround, itís cold wind and rain thatís the problem, not the sun, especially in the uncrowded off-season when I prefer to sail. Very few bother with biminis, at least on smaller boats, but dodgers are ubiquitous, and the main reason I chose this boat over others.
SU, please donít hunt me down... I have no desire to take your traveller away, or define ďthe pointĒ of sailing for you. For me, the point is to get out cruising, have a fun and relaxing sail, and enjoy some of the most beautiful anchorages anywhere. Iím fully aware that a 24-foot boat involves compromises, and that different sailors will make different choices. I donít expect everyone to understand or agree with mine, and hearing different perspectives is also part of the learning process.
Cheers... Perry.
idearat is offline
Help with mainsheet LameBMX Gear & Maintenance 6 09-06-2017 07:45 PM
Mainsheet rigging help JoeLena General Discussion (sailing related) 4 05-02-2013 03:40 PM
Sailing: 'Hooligan' Champs Of 'Round-the-Island' Challenge NewsReader News Feeds 0 01-12-2012 09:30 PM
Sailing: 'Hooligan' Champs Of 'Round-the-Island' Challenge NewsReader News Feeds 0 01-12-2012 09:20 AM
C&C Northern 24' or Bayliner Buccaneer 24'? Rockstar2011 Boat Review and Purchase Forum 32 05-22-2011 12:18 PM
