Prop "sea Trial" - SailNet Community
post #1 of 7 Old 08-03-2018 Thread Starter
dadio917
dadio917's Avatar
Prop "sea Trial"
I thought someone might find this useful or interesting. Recently performed a “propeller Sea Trial Test” that I got from Bruntons, the maker of our 3 blade Autoprop. Our bottom had just been cleaned. 3 cylinder 32hp Westerbeke with a ZF Hurth V drive. 37’ double ended hull probably pushing 20,000# with all the stuff in her. Did two runs on a fairly calm river, one up and one down. 10-14knt wind on the beam, so speed might be a little high. This is the average of speed over water. Max rpm at idle is 3600 which matches the engine specs. I’ve sent the data to Bruntons for their opinion. Just curious what they think.
Rpm Speed (knts)
1000 2.3
1500 3.9
1800 5.0
2100 5.3
2400 5.9
2700 6.4
3000 6.7 (engine maxed out here, wouldn’t do more rpms)
Dadio917
Valiant 39
dadio917 is offline
post #2 of 7 Old 08-03-2018
Re: Prop "sea Trial"
Was this engine only?
Good post.
RegisteredUser is online now
post #3 of 7 Old 08-03-2018
You can get a fuel consumption /rpm curve to help decide best rev to run.
Capt Len is online now
post #4 of 7 Old 08-03-2018 Thread Starter
dadio917
dadio917's Avatar
yup, bare poles but probably got a little lift from the wind on the hull
where would I find fuel consumption /rpm chart? I'll look at the westerbeke spec but I don't remember seeing that.
btw, before getting the hull cleaned she max'd at 2700rpm. Only about 4 months sitting in the marina. Really surprised me to get 10% from the hull cleaning.
Dadio917
Valiant 39
dadio917 is offline
post #5 of 7 Old 08-04-2018 Thread Starter
dadio917
dadio917's Avatar
Can't find a fuel consumption/rpm chart for my engine. Is there any rule of thumb for optimal fuel consumption? Like rpm at max torque? Some % of max rpm?
Dadio917
Valiant 39
dadio917 is offline
post #6 of 7 Old 08-04-2018
Most engine data sheets include RPM /HP and torque and fuel consumption There may be a sweet spot.
post #7 of 7 Old 08-04-2018
I look at it as 2 sweet spots.
One you like the fuel consumption...and can live with the speed.
One you like the speed..and can live with the fuel consumption.
From the figures you posted i would check consumption at 1800...5 knots is a decent working speed imo.
The great variable will always be conditions.
"Seacock" vs. "ballcock" or "ball valve?" SEMIJim Gear & Maintenance 18 09-02-2013 05:31 PM
"Special" vs. "normal" primer for prop? patrickstickler Gear & Maintenance 5 05-20-2011 08:46 PM
Sea Trial TADIAS Boat Review and Purchase Forum 10 08-12-2004 01:49 PM
What to expect in a sea trial troyaux Boat Review and Purchase Forum 6 01-31-2002 03:54 AM
