Trolling Motor Battery Charge - SailNet Community
 1Likes
  • 1 Post By TakeFive
post #1 of 6 Old 08-14-2018 Thread Starter
I use a trolling motor for my dinghy. On extended cruises I have to change out the battery with my starter battery and start the motor with the house battery to recharge it. What I think would work is attaching a pigtail with a twist-lock connection to the house battery (without removing). So all I have to do is pull out the pigtail, add it's mate to the dinghy battery and connect them. Now, start the engine and let the charging begin! So . . . stupid idea or what. Be gentle.
DonScribner is offline
post #2 of 6 Old 08-14-2018
Re: Trolling Motor Battery Charge
What size trolling motor? How much dinghy cruising are you doing that you are running down a battery so bad you need to switch it out? I assume a standard group 24/27 AGM for the trolling motor? So 105AH or so, so roughly a half hour full throttle to 50% on a 55lb thrust motor, or about an easy 1.5 mile range round trip. I suppose you are doing multiple trips a day?
The basic idea as you have said it is fine, I just dislike pulling the starter battery, seems to defeat the purpose.
Oh I think I see. You are saying your only way to charge it is to swap it out, than absolutely just add a pigtail and connect it to the house batteries to charge it (provided 12v bank of course). There are more complicated solutions (isolators, charge balancers, etc.) that might/would charge a bit faster, but that is totally workable.
tschmidty is offline
post #3 of 6 Old 08-15-2018
TakeFive's Avatar
If it's a true starter battery, it's the WRONG battery to run your trolling motor, and you'll likely ruin it. This is especially true if your trolling motor is running it down so far that you can't start the motor with it afterwards. Any discharge beyond 50% will drastically reduce its lifetime.
I can't suggest anything except more batteries. When I used a trolling motor I bought a 12350 AGM battery which has much less capacity, but was much easier to transport. If you buy two you can swap them out easily as needed and recharge on the boat. Rather than buy a second battery I decided to buy a 2.5 HP Suzuki, which weighed less than the batteries and has much longer range.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #4 of 6 Old 09-06-2018 Thread Starter
All my batteries are "deep cycle". But if you listen to MS, who's a marine electrician, they are not actually deep cycle. We took a two week cruise and swapping out the batteries worked fine. We never had a problem but I was just wondering if there's an easier way.
post #5 of 6 Old 09-07-2018
I used to add a group 24 battery to my house bank same way you are considering. Adding amps to house bank and then
using for trolling motor when needed. Never a problem as we motored often enough and is supplemented by solar.
Now group 24 battery has been replaced with 2 smaller AGM's. ...and still works out well.
My dinghy use is on the light side, heavy use probably would not work out as well.
HUGOSALT is offline
post #6 of 6 Old 09-08-2018
You might consider putting an AB switch on the house battery and connecting it to a charging outlet in the cockpit so you can plug a charging cable to that and charge the trolling motor battery on deck or without removing it from the dingy. Then you won't be needing to lug that trolling motor battery around so much.
Personally I find the 31 lb Honda BF2.3 I use less of a bother than lugging heavy batteries around and dealing with range anxiety. Lets face it your likely burning more fuel charging the trolling motor battery by running your main engine when you didn't really need to than if you just ran a gasoline powered outboard plus it only takes a few moments to recharge the gas powered outboard using a 8/10 lb 1 gallon gas can.
A spare trolling motor battery charged via solar would take fossil fuel out of the equation if you have space to set that all up but then you will have two heavy and expensive batteries to deal with along with the high cost of setting up the solar.
Indeed do what fits best for you however despite driving a full plug in electric car I am not 100% sold on using trolling motors as primary propulsion on a dinghy.
SeaStar58 is offline
Flying Junior Trolling Motor: Where to put battery? Bicanovsky Electric/Hybrid 5 01-24-2018 12:38 PM
Battery-powered Trolling motor bradleyswissman Gear & Maintenance 6 08-18-2013 11:48 PM
Trolling Motor to Battery Bank? snider General Discussion (sailing related) 10 06-17-2012 09:47 PM
Solar charger size - trolling motor battery drcoop Electrical Systems 2 05-13-2012 04:56 PM
To charge or not to charge lyonsian Gear & Maintenance 27 05-13-2007 08:11 PM
