Thru hull possibly leaking... what to do - Page 2 - SailNet Community
 4Likes
post #11 of 21 Old 09-11-2018
overbored's Avatar
Re: Thru hull possibly leaking... what to do
if they are below the water line then you will need to haul the boat to fix. if they are below the water then they should have valves before the hose to prevent the boat from sinking if a hose leaks or comes off. originally the cockpit drains where in the very stern of the boat just above the waterline, have they been moved. is that the inside of the transom in the first pic
"GOLD RUSH" PRINDLE 16
overbored is online now
post #12 of 21 Old 09-11-2018 Thread Starter
I don't think there were ever any aft cockpit drains in the Wilderness 21... only fore cockpit drains.
I don't think that is the inside of the transom in the first pic. But I will look today to check for sure.
hnash53 is offline
post #13 of 21 Old 09-11-2018
overbored's Avatar
You may be right, I sail on a Burns 21 which is the latter model of the wilderness 21 We had the last one built and they may have changed the location of the drains. ours went straight out the transom. we kept ours on a trailer at the club launch
post #14 of 21 Old 09-14-2018
With a 21' boat, it is possible that you can either careen the boat, or take a line from the masthead to a dock/shore fitting and haul it over sideways, so that you can lift one side of the hull pretty much clear of the water, at a time. That would allow you to remove and rebed one side, and then come back to do the other. And removed and rebedding is really the right way to go. "Do once and do it right" instead of patching and kludging. And, if the big white nut splits....uh, yeah, you're going to need to do something like that real fast anyway.
If there's any type of crane or an overhanging dock structure, you may also be able to tie a line around the read of the hull and simply lift the rear clear of the water. Hauling isn't the only option, although for 21' you may be able to have a local marina give you an overnight haul, i.e. they haul you last thing in the day, leave you in the sling, launch you again in the morning and that gives you a few hours between the haul and sunset when you can do a fast job.
A PITA but something that can be done. I used 5200 to replace a speed log throughhull once. The previous one had been put in the same way. Didn't matter, the new one was larger than the old one, would require a large hole to be drilled. The old fitting was easily split with a saw and then imploded into the hole. The 5200 was practically the same as the frp of the hull, which doesn't seem to bad for what is intended to be a permanent installation.
hellosailor is offline
post #15 of 21 Old 09-14-2018
A proper repair as described previously is what should be done at some point.
If you are a good swimmer, underwater epoxy( the type made for emergency repairs) could be rolled into a 'stringlike' format and applied around the perimeter. The stuff does work.
paulinnanaimo is online now
post #16 of 21 Old 09-15-2018
Dirt Free
boatpoker's Avatar
Throughulls (of mismatched plastics yet) below the waterline and without seacocks ..... keep an eye over your shoulder, Mr. Darwin is on the hunt.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
post #17 of 21 Old 09-17-2018
asdf38's Avatar
On a 21 foot boat the drains are likely below or at the waterline (my Contessa drains were underwater, Precision are underwater with anyone in the cockpit).
Can't this just wait until the season is over? A liter of water isn't going to sink it.
Precision 18, Massachusetts
Former boat: Contessa 26
asdf38 is offline
post #18 of 21 Old 09-18-2018 Thread Starter
[QUOTE=asdf38;2051553582]On a 21 foot boat the drains are likely below or at the waterline (my Contessa drains were underwater, Precision are underwater with anyone in the cockpit). Can't this just wait until the season is over? A liter of water isn't going to sink it.
Thanks for the comments. I thought about trying splashzone underwater epoxy. I'm a good swimmer but 55 degree water.... nah. Yes a proper repair will be done.
As for being a future Darwin Award winner, it's a little late... I've already passed my genes on to two of the next generation. As mentioned above, yes, a proper repair is in order.
Finally, yes, waiting till I haul it back out is what I've chosen to do. I'll be monitoring the water ingress each time I use the boat... which is often... multiple times a week. And you are right, a little water even up to a gallon is not an issue... but by then the bilge pump will kick in.
hnash53 is offline
post #19 of 21 Old 09-18-2018
Catalina 400 MKII
Scotty C-M's Avatar
HNash. I believe that George has it right. If, indeed the though hulls are under water, you need to haul. The good news is that you can just haul the boat for a short time, and fix the problem. Most yards will work with you to schedule this haul. For example, they haul it before they break for lunch, then splash you after lunch. If you've never done this type of repair before, get someone to help you. It's a bummer, but at least it shoul be (knock on wood) a relately easy fix. Good luck!
Scotty C-M is online now
post #20 of 21 Old 09-18-2018 Thread Starter
Hauling it is a bummer. The only place that hauls it uses a sling which means I have to unstep the mast. And since the mast is not deck stepped (no mast hinge), I have to have a different location stick the mast for me. My previous boats all had mast hinges/deck stepped. Using the crane to stick my mast damaged the Windex. All in all, it was a ***** to do. So, no, hauling is a pain.
If I could find a trailer tongue extension, I might be able to back the trailer deep enough to float the boat on the trailer, pull it out and do the work the next couple of days and then re-launch.
hnash53 is offline
Thru--hull base on curved hull Bruce3966 General Discussion (sailing related) 4 05-21-2015 11:10 PM
Leaking Thru Hull sfbaysailing Gear & Maintenance 8 05-15-2012 01:08 AM
Old brass thru hull for sink leaking dhendry1316 Gear & Maintenance 4 04-25-2012 03:02 AM
Is my old thru-hull thru? Skipper Joe Gear & Maintenance 18 06-13-2009 12:17 AM
Do you paint over thru hull bronze nipples on hull saurav16 Gear & Maintenance 4 08-19-2007 07:15 PM
