Thru hull possibly leaking... what to do - Page 3 - SailNet Community
 4Likes
post #21 of 21 Old 09-18-2018
Re: Thru hull possibly leaking... what to do
Would a barrel lashed on the forestay change the wl enough at the stern? If you can pull the outlets clear and with you in the stern.to work. Disconnect hoses , put a wood toggle on a rope thru the fitting and push it out. boathook the rope. Clean the surfaces and apply the goop. Pull the rope back in Jigglepoke the threads back in and apply nut .And valve//? Even a strop under the stern and a handy piling /dropping tide would do it. A helpful trawler or dragger maybe would swing his boom out for a case of beer. Be resourceful
Capt Len is online now
Thru--hull base on curved hull Bruce3966 General Discussion (sailing related) 4 05-21-2015 10:10 PM
Leaking Thru Hull sfbaysailing Gear & Maintenance 8 05-15-2012 12:08 AM
Old brass thru hull for sink leaking dhendry1316 Gear & Maintenance 4 04-25-2012 02:02 AM
Is my old thru-hull thru? Skipper Joe Gear & Maintenance 18 06-12-2009 11:17 PM
Do you paint over thru hull bronze nipples on hull saurav16 Gear & Maintenance 4 08-19-2007 06:15 PM
