Simpson Lawrence gypsy not matching chain - Page 3 - SailNet Community
 6Likes
post #21 of 36 Old 09-28-2018
Re: Simpson Lawrence gypsy not matching chain
Why not just get the BBB chain that is spec’d for the wildcat, if you’re trading it out.
Jeanneau 54DS
Minnewaska is offline
post #22 of 36 Old 09-28-2018
Master Mariner
capta's Avatar
Originally Posted by MarinaOnMaui View Post
Good point. Upon closer inspection of the chain there were also links in it that connected different chain, so it's possible the original piece was BBB and then they added G4. Who knows. It's a mess. The only problem with changing to 5/16 is I'm not sure if it's strong enough fo the boat which is 21,000 lbs and a 45lb Bruce.
No chain you can fit aboard your boat is going to be strong enough to hold your boat (21,000#) if it is straight from the anchor to the boat, not even our ˝" BBB! You must set yourself up with a nylon snub line for elasticity in the setup. Personally, I'd always go with the heaviest chain your gypsy can handle, not the more expensive smaller size G-4.
In 1971 I had my 3/8" BBB chain break in Hanalei Bay, Kauai when the wind swung north and the boat began pitching in the rising seas. I immediately thereafter set up a snub line and have always used one when anchoring since and have never broken my chain again.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
The Following User Says Thank You to capta For This Useful Post:
MarinaOnMaui (09-28-2018)
post #23 of 36 Old 09-28-2018 Thread Starter
Planning my escape
Yes, I always use a snubber, and I am in Hawaii, so I know the winds you are talking about! Thanks for your feedback. BBB is much heavier in the Bow when talking about 250-300 feet, but is what I'm considering at this point. I just hate spending the money - again, specially if there might be a less expensive option out there. Doesn't look like I can get a different gypsy since SL is out of business. And it's good to pick your brains. I will remove the gypsy tomorrow and take it to the chain company and sort this once and for all. I appreciate everyone's feedback! You are all very helpful.
CVAT likes this.
MarinaOnMaui is offline
The Following User Says Thank You to MarinaOnMaui For This Useful Post:
jballou (09-02-2019)
post #24 of 36 Old 09-28-2018
colemj's Avatar
Lewmar bought SL, and I'm pretty sure that gypsy is still available. Try Defender - I got ours there several years ago. They don't stock it - it is a special order item.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #25 of 36 Old 09-28-2018
Master Mariner
capta's Avatar
I've very rarely found I needed more than 200 feet of chain. Probably the deepest I've ever had to anchor was at Cook's monument in Kealakekua Bay at around 150' but that's a very unique situation where you drop your anchor to 150' and back up to the monument until your pick hooks into the side of the crater almost directly below you.
200' gives you 3:1 scope in 65' of water in normal conditions, which is all you really need with a good anchor and an all chain rode.
I doubt you'll want or need to anchor in 60 feet of water or more in storm conditions, as you'd probably be in a pretty exposed position in that much water. I try to tuck into 30 feet or less for hurricanes and the like, giving me 6+:1 scope with 200' of chain on my #1, never mind the other 4 anchors and rode I would have out if conditions warranted.
CVAT likes this.
capta is online now
post #26 of 36 Old 09-02-2019
I have exactly the same problem as the OP. Had BBB chain but it was rusted badly where the bitter end sat in the anchor locker. A LOT of rust! So I checked out the SL 555 manual and it clearly states either BBB or Hi Test, both 3/8”.
Found some G4 (Hi Test) and installed it yesterday. And – it skips just like the OP says.
Diameter of long side of both BBB and G4 links are the same, but inside diameter differ, as others have mentioned, is larger on the G4 than the BBB.
So why does the manual say both G4 and BBB will work? Have measurements chained? (haha)
So what is the resolution besides having to by 200’ of 3/8” BBB? Might Simpson-Lawrence replace the gipsy. Are they still around?
Any ideas?
jballou is offline
post #27 of 36 Old 09-02-2019
Master Mariner
capta's Avatar
Diameter of long side of both BBB and G4 links are the same, but inside diameter differ, as others have mentioned.
Any ideas?
There is nothing similar in the dimensions of HT and BBB chain, and as you have found out, they are not interchangeable. Simpson-Lawrence should be able to sell you a HT gypsy, though it probably won't be cheap.
I keep trying to tell folks that HT chain is a waste of money. The way chain works is by using the catenary curve to cushion any shock to the chain. BBB chain weighs more per foot than HT and therefore does a better job. Way too many folks think that just because HT is stronger it is better, but if you check the specks, you'll see that neither BBB or HT is strong enough to actually hold the boat, should the chain be tight between the anchor and the boat. Therefore you are better off with the BBB as it is actually the chain designed for anchoring.
I'm sorry you are in this predicament, but you are not alone. A lot of folks make this very expensive mistake.
Just as an informational note, our windlass manufacturer (Lofrans) has a pretty strange way of numbering their gypsies, so we ended up with the wrong one a few times, @ $1200.00 each! We did end up getting things straightened out, but it was a lot of out of pocket money and time.
capta is online now
post #28 of 36 Old 09-02-2019
Aspiring Boat Bum
skipmac's Avatar
Exactly. A casual measurement of one link might look close but if you measure a longer piece or look at the specs you will see that 3/8" HT and 3/8" BBB are not the same. At least in my SL windlass what matters is links/ft which is of course determined by the link dimensions. 5/16 HT and 3/8 BBB are close enough that either works perfectly but 3/8 HT definitely not.
By the way, the SL manuals are nonsense. Mine (the origional) claims that my gypsy will use 3/8 BBB or HT, 5/16 BBB or HT and 8-10 other chain sizes including metric which absolutely wrong. Spoke with John at SL Spares in UK and he confirmed the manual was marketing BS.
He is by the way, the go to guy for parts on old SL windlasses. He worked at SL for years and bought out rights and parts to all the old models when SL discontinued support.
Respectfully I don't completely agree with this. First I'm sure you agree that a snubber is much more effective at cushioning the shock than the catenary of the chain. Also catenary may work at lower winds speeds but when it really starts to blow the catenary on either size chain will be small enough that the effect will be effectively nil.
skipmac is offline
The Following User Says Thank You to skipmac For This Useful Post:
post #29 of 36 Old 09-02-2019
Master Mariner
capta's Avatar
Obviously, we all use snubbers to minimize the stress on our anchor tackle, but that wasn't really this discussion.
Please explain why you think stronger chain makes any difference if the chain comes tight between the boat and anchor. No chain anyone can ever carry on any boat (even a ship) is going to be strong enough to hold the vessel outright. You have a better chance of the chain not breaking with more weight than strength, IMO.
As for higher wind speeds, one would hope that the vessel's operator would let out more scope to add more catenary.
Minnewaska and CVAT like this.
capta is online now
post #30 of 36 Old 09-02-2019
colemj's Avatar
For some of us, lower total chain weight is vital. Also for some of us, anchoring is usually in less than 10', where catenary is useless. Having equal strength chain at much lower weight is a better choice for us.
By the time it really matters, catenary is no longer helpful.
Mark
skipmac likes this.
colemj is offline
Tags
gypsy doesn't match links , simpson lawrence windlass
Simpson-Lawrence Rebuild rduncan530 Gear & Maintenance 4 08-31-2007 07:31 PM
Matching chain to gypsy bjkrad Gear & Maintenance 10 11-08-2006 07:28 AM
Simpson Lawrence 555 windlass rebuild chopsy Gear & Maintenance 4 08-27-2006 07:21 PM
Simpson Lawrence gone? Windlass advice, please... WHOOSH Gear & Maintenance 4 09-08-2002 04:50 PM
Servicing a Simpson-Lawrence Windlass Tom Wood Gear and Maintenance Articles 0 09-23-1999 09:00 PM
