Simpson Lawrence gypsy not matching chain - Page 4 - SailNet Community
 6Likes
post #31 of 36 Old 09-02-2019
Aspiring Boat Bum
skipmac's Avatar
Re: Simpson Lawrence gypsy not matching chain
Originally Posted by capta View Post
Obviously, we all use snubbers to minimize the stress on our anchor tackle, but that wasn't really this discussion.
The mention of using a snubber I thought directly related to your point of catenary minimizing shock load on an anchor rode.
Please explain why you think stronger chain makes any difference if the chain comes tight between the boat and anchor. No chain anyone can ever carry on any boat (even a ship) is going to be strong enough to hold the vessel outright. You have a better chance of the chain not breaking with more weight than strength, IMO.
As for higher wind speeds, one would hope that the vessel's operator would let out more scope to add more catenary.
I never said stronger chain makes a difference in the way you state. I said only that the weight of 3/8 vs 5/16 chain does not have a significant effect on catenary and shock.
Regarding more scope, once you reach about 7-8/1 scope you are reaching the point of diminishing returns and adding more realizes almost no benefit. In really strong winds, in my experience, too much scope will allow a much wider arc for the vessel to sail at anchor which I think increases stress on the anchoring system.
Finally 5/16 HT is rated stronger than 3/8 BBB (yes I'm aware of the difference in how they're rated and other implications) but is lighter, keeping weight out of the ends of the boat. As a very, very secondary benefit, it's also cheaper than 3/8 BBB.
skipmac is online now
post #32 of 36 Old 09-02-2019
I would expect a downward sales trend for bbb over the last few decades.
...but i have no info to back that up...
RegisteredUser is offline
post #33 of 36 Old 09-02-2019
Shock absorption and cantenary...
Its not much above 20knots when my chain is tight. Maybe its 22, 25...whatever. my guess... i can not physically pull in chain at that point.
At that point, its all snubber. I usually tie on 20ish ft of 1/2" 3-strand snubber.
At that load, chain strength is not a factor.
The Following User Says Thank You to RegisteredUser For This Useful Post:
jballou (09-02-2019)
post #34 of 36 Old 09-02-2019
Thanks for that information. Good idea to remove the gypsy and take it to the store.
jballou is offline
post #35 of 36 Old 09-02-2019
Smile Re: Simpson Lawrence gypsy not matching chain
Thanks everyone for this discussion. Very informative. I think I'll be switching my G4 3/8 to BBB 3/8.
Anyone want to buy 200' of brand new G4 3/8?
jballou is offline
post #36 of 36 Old 09-02-2019
And reading all this - l think I'll need to lengthen the snubber line as well. I think I only have about 10'
jballou is offline
Tags
gypsy doesn't match links , simpson lawrence windlass
Simpson-Lawrence Rebuild rduncan530 Gear & Maintenance 4 08-31-2007 07:31 PM
Matching chain to gypsy bjkrad Gear & Maintenance 10 11-08-2006 07:28 AM
Simpson Lawrence 555 windlass rebuild chopsy Gear & Maintenance 4 08-27-2006 07:21 PM
Simpson Lawrence gone? Windlass advice, please... WHOOSH Gear & Maintenance 4 09-08-2002 04:50 PM
Servicing a Simpson-Lawrence Windlass Tom Wood Gear and Maintenance Articles 0 09-23-1999 09:00 PM
