thread lock for prop zinc? - Page 3 - SailNet Community
 3Likes
post #21 of 23 Old 10-31-2018
Re: thread lock for prop zinc?
I use zincs to protect the aluminum saildrive. The 2 that mount on the casing would sometimes not last to haul-out time...they are not very large. Several years ago I started hanging a larger zinc over the transom while at my home dock. I have had no issues since, the transom zinc does disappear, indicating that it is working. The other zincs are not used up as quickly.
paulinnanaimo is online now
post #22 of 23 Old 10-31-2018
Sllnging a zinc over the transom , for best results,,should be wired(bonded to system ) ground including shaft brush is it's isolated
Capt Len is online now
post #23 of 23 Old 10-31-2018
Thanks Capt Len,
Of course you are right. The zinc is bolted to a stainless steel wire. The wire hangs on a stainless eye bolt on the transom. Inside the boat, a stainless wire connects the eye bolt to the motor block. The motor block is bolted to the saildrive. I periodically check the circuit with a test light.
Thread Thread: Trimaran Trampolines and UV Resistant Thread petertribo General Discussion (sailing related) 7 10-24-2013 09:29 AM
Broken prop shaft - saved by the zinc harbin2 Gear & Maintenance 14 05-31-2010 08:24 AM
How to attach Prop Nut Zinc? preservedkillick Gear & Maintenance 6 05-15-2010 12:23 AM
zinc for flex-o-fold prop trodzen Gear & Maintenance 4 01-26-2007 12:26 AM
Prop Lock pdadd Gear & Maintenance 3 01-02-2006 08:56 PM
