thread lock for prop zinc? - SailNet Community
 3Likes
post #1 of 23 Old 10-20-2018 Thread Starter
dadio917
dadio917's Avatar
what do you guys use?
Someone told me put blue thread lock on and let it cure in air before installing underwater.
Dadio917
Valiant 39
dadio917 is offline
post #2 of 23 Old 10-20-2018
Master Mariner
capta's Avatar
Re: thread lock for prop zinc?
Never heard of any such thing. Zincs come with SS Allen screws and I've never had one come loose before the zinc has deteriorated so much that the screw is useless.
Save your money and time.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is offline
post #3 of 23 Old 10-20-2018
Dirt Free
boatpoker's Avatar
The thread lock on the contact surface may insulate the anode rendering it useless. If you do use it (I never have), make sure it's confined to the screws
RegisteredUser likes this.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #4 of 23 Old 10-20-2018 Thread Starter
dadio917
dadio917's Avatar
thanks for the responses.
I should have added that I just switched props and the old zinc was held on by 3 plastic fasteners. the new one is one stainless screw...hence my question.
the prop came with all its fasteners pre-coated with a thread loc for installation underwater.
Dadio917
Valiant 39
dadio917 is offline
post #5 of 23 Old 10-20-2018
overbored's Avatar
several of the anode brands come with the screws with the thread lock pre coated on the screws . can't hurt
"GOLD RUSH" PRINDLE 16
overbored is online now
post #6 of 23 Old 10-20-2018
misfits's Avatar
After you've put the zinc on coat the screw area with nail polish.
misfits is offline
post #7 of 23 Old 10-20-2018
Clear coat or rojo caliente?
PhilCarlson likes this.
RegisteredUser is online now
post #8 of 23 Old 10-20-2018
misfits's Avatar
Whatever is avaliable from your wife, daughter or girlfriend.
misfits is offline
post #9 of 23 Old 10-21-2018
fallard's Avatar
We had a tailcone zinc for our MaxProp disappear one year (out of the 22 yrs we’ve owned this boat) and the 3 screws were also gone. The prop was uncoated that year and showed noticeable pitting, which led to a MaxProp overhaul at PYI. Hadn’t had a problem with the zinc before or since.
For quite a few years now, we’ve been coating the prop with Pettit zinc spray, sanding the prop and zinc where they contact, coating the screws with the blue stuff, and coating the area of the zinc around the screw heads with nail polish. The attached photo shows you what the prop looked like a few weeks ago after haul out and pressure washing by the yard. Must be about 98% of the zinc is left.
fallard is offline
post #10 of 23 Old 10-22-2018 Thread Starter
dadio917
dadio917's Avatar
I asked boatzincs.com...here is their answer:
Thread locker is something we tell folks to consider only if they're having a specific problem with the bolt rocking out. Otherwise, it's probably not necessary.
If you would like to use it, we like Vibra-Tite VC-3 (https://www.boatzincs.com/vibratite-specs.html). As with any thread locker, a little goes a long way. We recommend thinly coating the tip of the bolt, letting it dry, and then installing.
Dadio917
Valiant 39
dadio917 is offline
Thread Thread: Trimaran Trampolines and UV Resistant Thread petertribo General Discussion (sailing related) 7 10-24-2013 09:29 AM
Broken prop shaft - saved by the zinc harbin2 Gear & Maintenance 14 05-31-2010 08:24 AM
How to attach Prop Nut Zinc? preservedkillick Gear & Maintenance 6 05-15-2010 12:23 AM
zinc for flex-o-fold prop trodzen Gear & Maintenance 4 01-26-2007 12:26 AM
Prop Lock pdadd Gear & Maintenance 3 01-02-2006 08:56 PM
