Sailing kayak - Page 7 - SailNet Community
 50Likes
post #61 of 68 Old 11-26-2018 Thread Starter
Moderator
Arcb's Avatar
Re: Sailing kayak
This set up continues to impress me not just for its performance but for its ease of use in a variety of conditions. We are at the end of a week long deep freeze. Temperatures have not been above freezing day or night for a week, with temps dropping to -17 one night. Nearly every local body of water is frozen over.
However, only a 10-15 minute drive from me is a sections of gravel swifts on a river where the current is strong and turbulent enough to resist freezing even in cold conditions. However, its a pain to get to. No normal sailboat would be able to get there, in part due to depth and also in part due to the ravine its in. First there is a 50 yard drag or carry from the parking lot to the river bank. Then a clamber down muddy, icy, slippery river bank to the waters edge, and then, but the boat and rig are so light I was able o get it in the water this morning without an excessive amount of effort and set the rig up at the waters edge before sailing away for a few hours. Wind gusts at the nearby airport were recorded up to 17 knots, although the ravine surely reduced that.
The boat had little difficulty sailing up river against the current in these conditions. I am still without rudder, so steering was through sail balance and leaning. I didn't push my luck with upwind sailing due to wind gusts, lack of sea room and water temp, but sailed her as high as a beam reach and she handled nicely.
Minnesail likes this.
Arcb is offline
post #62 of 68 Old 04-16-2019 Thread Starter
Moderator
Arcb's Avatar
Re: Sailing kayak
I haven't updated this thread in a bit, so I thought I would as the boat is pretty much a complete system now. The last pieces of the puzzle have just come together recently including a rudder, spray skirt for dirty weather and a proper racing paddle.
The rudder came together nicely. The rudder that I was interested in was pricey over $300 CDN, so I have been watching out for deals. A couple weeks ago, I happened across one, the only catch was it was attached to a used demo boat. Sweet, so I bought the boat which is a rather nice tandem kayak. So now, on week ends I can bring my son training with me on week ends, he seems happy to sit and play in the water, fish or whatever while I paddle, works for me. The rudder system is a fairly standard kayak rudder system. It uses cables lead to foot pedals, so you are steering with your feet because hands are busy with paddle. I think airplane rudders are the same deal, foot pedals control rudder. The rudder system is nylon, including the blade.
Spray skirt was an off the shelf item for my Kayak. For those not familiar with sea kayaks, they are fully decked boats, except for the cockpit which has a combing. You wear the spray skirt something like a skirt with suspenders and the hem attaches around the combing, creating a water tight seal, even when upside down, in theory self rescue is conducted by conducting a role with your paddle.
Possibly the most important detail was the paddle- the engine, along with the sail. I did a lot of research on this, books, paddling forums etc. At first I was looking at ergonomically designed bent shaft carbon fibre paddles. After chatting with some world record holders for distance paddling I decided not to go that way. I decided to go with a custom made western red cedar wood paddle. This type of paddle is known as a Greenland paddle the blades are quite narrow but long, basically shaped like airplane wings. On the power stroke you angle the paddle blades at about 30 degrees maybe, this creates lift on the forward edge of the paddle, much like a propeller or we as sailors are accustomed to our keels and sails doing. This effectively causes the boat to be both pushed through the water and pulled by the lift. And being custom made it is a perfect fit for me ergonomically. There are other bonuses too, but that's a big part of it.
Early on in the thread I roughly listed my specs. The final boat gets a lesser percentage of its power from the sail then I had originally envisioned and more power from its paddle. My testing so far seems to indicate that I should be able to meet my performance expectations. Maybe not 60 mile days, but consistent 45 mile days with higher potential on strong tail wind days. The boat doesn't seem to have much problem holding 5 knots on a run in a decent wind aft of the beam.
Here a quick look at her cruising along nicely with both the sail and paddle in play in light winds.
Arcb is offline
post #63 of 68 Old 05-13-2019 Thread Starter
Moderator
Arcb's Avatar
Re: Sailing kayak
Finally got this boat into a race. It went okay. The winds were too light to deploy my sail, so I just paddled old school. I finished in the middle of the pack. My paddling speed was 4.73 knots over 1 hour 26 minutes I was happy with my paddling speed, but I would like to let her rip with the sail next time.
RegisteredUser likes this.
Arcb is offline
post #64 of 68 Old 05-13-2019
Re: Sailing kayak
Comparing your speed to what we observe around here, I'd call that pretty impressive paddling Arcb.
Arcb likes this.
paulinnanaimo is online now
The Following User Says Thank You to paulinnanaimo For This Useful Post:
Arcb (05-13-2019)
post #65 of 68 Old 05-13-2019 Thread Starter
Moderator
Arcb's Avatar
Re: Sailing kayak
^^^ I was getting a pretty good boost from the current. Everyone is a bit quicker when they are falling down hill
Arcb is offline
post #66 of 68 Old 05-13-2019 Thread Starter
Moderator
Arcb's Avatar
Re: Sailing kayak
Here is another little vid I took while I was out sailing today. Nothing fancy. Running down wind, gybe, then round up onto a reach. There were a couple big gusts that required me to dump some wind.
Arcb is offline
post #67 of 68 Old 07-18-2019 Thread Starter
Moderator
Arcb's Avatar
Re: Sailing kayak
I discovered an entire new area of kayak sailing this week that was previously unknown to me, and that is the world of folding kayak sailing.
It seems many of the early commercially available kayaks were folding skin on frame kayaks modeled loosely after those of hunters kayaks of the arctic, except beamier and sailable.
Klepper kayaks was an early manufacturer starting some time before world war 1 and still making high quality expedition sailing (and non sailing) kayaks today. These are no back yard toys, they are serious expedition boats. In 1957 it seems a solo transat was completed in one of these 17.5 ft sailing kayaks.
Then in 1933, a British company started manufacturing Folbot folding kayaks. And it seems moved production to the US in 1935. These boats also had fairly nice factory sail rigs including lateen rigs, rudder and lee boards.
Any way, earlier this week I had a trailer sailer I wasn't using up on the classifieds for sale or trade and one of the 1960s Folbot folding sailing kayaks ended up in my front yard
The boat in the vid isn't my boat, but a random vid off the net of of one similar to the one I got my hands on this week.
https://youtu.be/t6HP8z_ilSY
Arcb is offline
post #68 of 68 Old 07-18-2019
Re: Sailing kayak
The mostly Germans hauling out on the beach ,Koh Jum, were on their way to Singapore, paddling Klepper types from Winnipeg? Too gruelling for me. Helped some make bamboo /tarp rigs as the available stuff won't fit in plane luggage. While sailing a Colin Archer from Norway, I was told about meeting Thor Heyerdahl Jr. in a Keppler type mid Atlantic .His son also did a balsa raft but that's another story.
Arcb likes this.
Capt Len is online now
Building/modifying sailing kayak? jbarros Sailboat Design and Construction 32 11-12-2014 11:44 PM
building a sailing kayak? jbarros Gear & Maintenance 0 09-09-2009 05:09 PM
mounts for kayak EscapadeCaliber40LRC Gear & Maintenance 28 02-11-2007 10:19 PM
Around Florida in 19 days - by Sailing Kayak @ Sail World Australia NewsReader News Feeds 0 04-15-2006 05:15 AM
kayak racks czzmg8 Gear & Maintenance 1 02-23-2003 06:11 PM
