porta-bote repair? - Page 3 - SailNet Community
 13Likes
post #21 of 25 Old 10-28-2018
hpeer's Avatar
Re: porta-bote repair?
I just went over the Eternabond site again and I canít find any description of the removable Mylar liner on any of the products. I also read about the primer and that seems to have to do with the material you are sticking to not the tape.
So I donít know whatís up. Maybe I got a bad batch or Iíll find the Mylar when I unwind the tape roll further.
But thanks for all the help. Much appreciated.
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
post #22 of 25 Old 10-28-2018
hpeer's Avatar
OK, once again I must eat crow. It DOES have the Mylar. They held down the end of the tape with clear packing tape, which held down the clear Mylar and the tape came right off. I saw it once I got outside into the sunshine.
Anyway, I have made my repair. This the seam in the transome bladder all the way at the bottom at the keel. The material rips here due to bending. Now that Iíve ďdugĒ into this I see they take precautions this rip does not leak. I hauled up real hard on the transome bladder, there was some additional white tape in this joint. It was not fully adhered. I pulled it out best I could, sanded the area, and framed a bit Eternabond in there. Not a lot of faith in that repair.
On the outside I cleaned up the area around the rip, I scraped it pretty hard with a knife , cleaned it with acetone, let it dry, then applied the Eternabond over the rip. I did not try to cover anything except the bladder, I canít see anything holding over the riveted seams and thought it would only make things worse. I pressed the dickens out of it. I feels likes itís holding.
Iíll be happy if I get 6 months, then Iíll repeat. I do have a bit of tape left over, 49í 9Ē.
hpeer is online now
post #23 of 25 Old 10-28-2018
Originally Posted by hpeer View Post
I just went over the Eternabond site again and I can’t find any description of the removable Mylar liner on any of the products. I also read about the primer and that seems to have to do with the material you are sticking to not the tape.
So I don’t know what’s up. Maybe I got a bad batch or I’ll find the Mylar when I unwind the tape roll further.
The removable backing is not mylar its just a clear plastic sheet which you can see the soft grey butly rubber adhesive through or a waxed paper. The face, which will be the outer surface on the roll, may be a woven material, aluminum foil or a fairly sturdy mylar plastic in white or a whatever color you chose. The tape used for pond liners for example will usually have the woven face which will provide a better base for the oil paint than the mylar face. As the video indicated sometimes the backing that covers the adhesive may not come off easily and this can be made worse if the roll was left out in the sun for an extended period of time.
The primer activates the bond between the butyl rubber and the surface your working on which is especially important when working on dirty or oxidized surfaces or with materials that do not work well with adhesives.
Perhaps this more detailed video will help:
https://youtu.be/jUvDzyiGb64
SeaStar58 is offline
post #24 of 25 Old 10-28-2018
Anyway, I have made my repair. This the seam in the transome bladder all the way at the bottom at the keel. The material rips here due to bending. Now that I’ve “dug” into this I see they take precautions this rip does not leak. I hauled up real hard on the transome bladder, there was some additional white tape in this joint. It was not fully adhered. I pulled it out best I could, sanded the area, and framed a bit Eternabond in there. Not a lot of faith in that repair.
On the outside I cleaned up the area around the rip, I scraped it pretty hard with a knife , cleaned it with acetone, let it dry, then applied the Eternabond over the rip. I did not try to cover anything except the bladder, I can’t see anything holding over the riveted seams and thought it would only make things worse. I pressed the dickens out of it. I feels likes it’s holding.
I’ll be happy if I get 6 months, then I’ll repeat. I do have a bit of tape left over, 49’ 9”.
Great that you got it figured out. Cleanliness and prep is critical and you do have to press hard to ensure the butyl adhesive gets into any imperfections in the surface so it won't wick. Be sure to store the remainder with the wax paper rings covering the sides and in the original container if possible. I will ensure that the roll stays clean by putting it in a large zip lock freezer bag before putting it back in the box. Be sure to store in a cool dry place to limit the adhesive oozing out the sides over time.
post #25 of 25 Old 10-29-2018
Cruiser
wrwakefield's Avatar
Originally Posted by bristol299bob View Post
Courtesy of hurricane Florence I find myself in possession of two 10ft porta-botes, both damaged. I intend to make one usable bote from the parts.
Patient #1: has two tears/holes in the floor each about 4"x1"
Patient #2: the plastic transom is torn right along the seam. This patient is better condition overall but the tear along the seam means that the repair would be flexed/worked each time the bote is folded/unfolded.
Which patient would attempt to save? and how?
Years ago I installed a round deck plate [e.g., 3" in diameter] to the outside of the hull [so the cover was almost flush with the outside of the hull...] of my hard dink because many were being 'borrowed' in the area I was cruising.
By removing the deck plate cover [and taking it with me on shore...] and running a locking cable through the hole I was able to secure my dink. [Even if they cut the lock they wouldn't get far...]
It worked great.
Depending upon the location of the tears in the hull of patient #1, might you be able to install appropriately sized deck plates? [Using butyl tape as the sealant, and machine screws with acorn nuts (or SS rivet-nuts) as the fasteners...]
Just an idea that I have first hand experience withĖ but not in a Porta-Boat...
Cheers! Bill
wrwakefield is offline
8.5' Porta-bote as dinghy for 28' sailboat Frogwatch Gear & Maintenance 18 06-21-2013 09:28 PM
Porta-Bote Stability? GrahamO General Discussion (sailing related) 9 05-10-2012 10:28 PM
Dinghy experiment #4, or it is 5, Porta-Bote Frogwatch Gear & Maintenance 7 04-26-2012 08:03 PM
Porta Bote lancelot9898 Gear & Maintenance 8 03-03-2009 02:42 AM
Folding Porta Bote as Dinghy phoebe10011 Cruising & Liveaboard Forum 8 07-21-2003 05:48 PM
