Exhaust under water - Page 2 - SailNet Community
 7Likes
post #11 of 32 Old 10-29-2018
Living the dream
ReefMagnet's Avatar
Re: Exhaust under water
Here's a video of my boat doing the squat thing. And my exhaust dips below water at times
ReefMagnet is offline
post #12 of 32 Old 10-30-2018
fallard's Avatar
My boat squats at higher engine speeds but not under sail. The difference has to do with the engine pushing the boat vs. the sails pulling the boat, like jtsailjt said.
fallard is online now
post #13 of 32 Old 10-31-2018
outbound's Avatar
Hopefully you have a loop significantly above the waterline with a vacuum break to prevent filling the exhaust and then the engine. The most important time to not have water in your exhaust is before you start the engine. Back pressure then burns out starters. Some will need to tack to drain exhaust before starting engine to prevent this and then drop sails as they come in. The run from through hull should go straight up to top of loop to prevent this occurrence thereby eliminating need to worry about back pressure ruining your starter. Some boat have such funny runs closing the through hull is necessary whenever the engine isnít running. My prior genset was like that. The one Iím putting in isnít.
Some diesels will tolerate a bit of back pressure but decreasing or eliminating it is a good thing from what I understand.
s/v Hippocampus
Outbound 46
outbound is online now
post #14 of 32 Old 10-31-2018
Dirt Free
boatpoker's Avatar
Tens of millions of powerboats with exhaust exiting under water. Most (not all) outboards exhaust under water.
My 55hp diesel exhausts under water. My previous 235hp diesel exhausted under water. My 145hp Perkins did 20,000hrs exhausting under water before I rebuilt her ..... maybe she would have done 40,000 if she'd exhausted above water
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #15 of 32 Old 10-31-2018
Stinkpot exhausts are typically engineered below the waterline, with proper diameter, etc. The OP’s was reportedly design above. Adding resistance underwater, for an exhaust that is above the waterline to begin with, could be significant. Bends in the run, as well as exhaust diameter matter, so I’m sure blocking the exit with water is too.
Jeanneau 54DS
Minnewaska is offline
post #16 of 32 Old 10-31-2018
I'm asking as much as informing, but...
When you push or pull anything through water, isn't there a vacuum right against the trailing surface? In the case of an exhaust, I don't think there would actually be any water at the exit, and therefore no backpressure at all. What do others think, or know?
boatpoker likes this.
paulinnanaimo is online now
post #17 of 32 Old 11-01-2018 Thread Starter
One problem with the exhaust under water, cant see water flow or hear the hollow sound of no water flow.
Thanks for all the replies, I think all is normal so one less thing to fixate on.
thumper53 is online now
The Following User Says Thank You to thumper53 For This Useful Post:
boatpoker (11-01-2018)
post #18 of 32 Old 11-01-2018
Dirt Free
boatpoker's Avatar
I agree, all normal and nothing to worry about however, a raw water flow detector/alarm is a wise investment. It has been the first thing added to each of my boats.
MastUndSchotbruch likes this.
post #19 of 32 Old 11-01-2018
Or an exhaust temperature alarm which is what I installed.
MastUndSchotbruch is online now
post #20 of 32 Old 11-01-2018
Dirt Free
boatpoker's Avatar
The advantage of the raw water detector is that it alarms the instant there is loss of flow. You may already have a fried impeller by the time an exhaust temp alarm goes off. It does not hurt to have both.
under Under $5k a year possible on Chesapeake Bay? deniseO30 Living Aboard 25 01-15-2011 06:54 PM
Pitch Black Exhaust Water Yanmar 2GM20F rireefguy Gear & Maintenance 14 03-03-2010 08:13 AM
exhaust water injection elbow wescarroll Gear & Maintenance 1 08-17-2008 07:18 PM
reduced exhaust water rsford Pacific Seacraft 4 08-07-2007 08:36 PM
Diesel exhaust- water? MBesant Gear & Maintenance 26 07-18-2007 05:19 AM
