Is this a healthy Catalina 22 hull/keel? - Page 2 - SailNet Community
 12Likes
post #11 of 31 Old 11-19-2018
Re: Is this a healthy Catalina 22 hull/keel?
Originally Posted by FunkyJunk View Post
Sorry about that. It's an '84. I don't know if a paid survey is on the cards since it's only a $4k-5k boat. I don't have the cash in my budget for that. I've gone over the boat pretty thoroughly and this is my only concern at this point.
Do a better job than the previous guy on scraping, sanding and pressure washing the old paint and it will look a lot better along with last longer when you re-coat it. An Ablative paint chalks to prevent marine organisms from bonding to the hull and not loose its effectiveness when stored in the boat yard. It does rub off and stain you skin and clothes.
Be more concerned about soft spots in the hull, the condition of the centerboards lift cable/pivot pin/lock pin/bushing and the centerboard trunk especially where the centerboard hits it when fully lowered along with all the bushing locations.
SeaStar58 is offline
post #12 of 31 Old 11-20-2018
TakeFive's Avatar
The cheaper the boat, the more you need a survey. Just sayin'
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #13 of 31 Old 11-20-2018
midwesterner's Avatar
...I don't know if a paid survey is in the cards since it's only a $4k-5k boat. I don't have the cash in my budget for that....
Then you will probably want to read that post on doing your own survey and do a thorough self survey.
midwesterner is online now
post #14 of 31 Old 11-20-2018
Painfully, many $4-$5k boats turn out to have values less than zero. This happens when a defect is identified that will cost more to repair than the boat will be worth, after repaired. Hull issues are one that can do this, followed by rigging, motors, sails, etc. I wonder if you could get a local professional to just come look at the suspect issue, if you're not up to the task.
Of course, it does not need to be perfect, just safe and not about to fall apart.
At a minimum, it's a waste of time to put more paint over top of that. You might as well just buy the new paint and pour it out. If you take that paint down to the hull, apply a proper barrier/primer and a few coats of bottom paint, it will last. On a 22ft boat, you could probably scrape or vacuum sand it yourself, but it will be a remarkable amount of work. You will accidentally get into the hull occasionally and need to repair that. Having a hull soda blasted is the best way to remove all product, but not damage the gelcoat. I doubt you'll want to spend the money on it.
Keep in mind, the cost of owning a boat is what will get your attention more than the cost of buying one.
Jeanneau 54DS
Minnewaska is offline
post #15 of 31 Old 11-20-2018
TQA
Bombay Explorer 44
TQA's Avatar
Looks OK to me so scrape sand paint go sailing.
Don't sweat the small stuff.
There are at least two owners web sites with a large archive of useful information. Ask Mr Google to find them.
Also Catalina themselves still provide spares and support.
BTW A Catalina 22 clone/copy built in the UK under licence as a Jaguar 22 was my first 'big' boat. I sailed mine from Troon round the Mull of Kintyre then up to Stornoway and back one summer. The following year I trailed it down to the Adriatic and sailed it down to Albania and back. They are capable little ships.
JimMcGee and RegisteredUser like this.
TQA is offline
post #16 of 31 Old 11-20-2018
Moderator
Arcb's Avatar
Boats on trailers dont often seem to have negative value because their cost to own is so much less than boats that require storage.
Hiring a surveyor is often recomended, but I wonder how many owners of 35 year old trailer sailors are actually willing to drop $$$ on a surveyor, especially considering most wont even look at a lot of the most expensive items; sails, trailer, rig and engine.
If you do hire a surveyor, find out what their credentials are and ask them before hiring them what they are actually going to survey.
Arcb is offline
post #17 of 31 Old 11-20-2018
mstern's Avatar
FWIW, when I was buying my Oday 23 almost twenty years ago, I hired a surveyor. I thought I knew a lot about boats, but I learned more in those two hours than I ever expected. He found some delamination I didn't know about, and also quelled my fears about it ("If you are going to day sail around the Sound, just rebed in these areas, and you'll be fine. It ain't worth fixing"). And because the boat was small and simple, he gave me a discounted rate for the survey.
I'm fairly risk-averse, so for me, spending about $300 for a survey on a $5000 boat was very worthwhile. YMMV.
mstern is offline
post #18 of 31 Old 11-20-2018
Is this boat going to be trailered? Hard to imagine how paint can get that bad, unless there is a serious adhesion problem, if itís only day sailed off a trailer.
Jeanneau 54DS
post #19 of 31 Old 11-20-2018
overbored's Avatar
Paint on a centerboard can get bad because it is a trailer sailer. may don't paint them because they are hard to get to on the trailer. The boat needs to be lifted in a sling to sand and paint the centerboard. many don't spend the time or money to do this. How is the rest of the bottom?
"GOLD RUSH" PRINDLE 16
overbored is online now
post #20 of 31 Old 11-20-2018
Minnesail's Avatar
WERE YOU WATCHING ME?!?!
You'd think a 22' boat isn't that big, but when working with amateur level tools and a homemade cradle it was a tremendous amount of work. And yes, I went into the fiberglass once.
If I were to do it again I would definitely just pay to have it done.
Anyway, that keel looks about how mine looked. It's iron, so if it isn't sealed it will rust up and if a lazy owner paints over the rust that's what you get.
I ground my keel down to metal. I put Marine Tex in to fill the large pits, didn't worry too much about smoothing it. I used Pettit Rustlok Steel Primer and then finished with Pettit Neptune 5.
I chose the Pettit Neptune 5 because it advertises that it will go over all other bottom paints. I had no idea what paint the previous owner had used and didn't feel like going all the way to the fiberglass, so for the hull I just sanded till it was smooth and the flaking bits came off, then hit it with the Neptune 5. I've had it on for three years and it's held well.
Make sure the deck is solid around the shrouds. Remember that new sails could cost $2000 so if the sails are shot you might want to keep looking.
You can't go too wrong. Lot's of Catalina 22 out there, if you end up not liking it you should be able to re-sell it easily.
Catalina 22
on a starboard tack
Minnesail is offline
Swing Keel or Fixed Wing Keel? Catalina 22 or 25? BRCincy Boat Review and Purchase Forum 60 08-29-2015 01:03 AM
How to stay healthy on cruise ships (Kansas City Star) NewsReader News Feeds 0 03-18-2007 05:15 AM
How to stay healthy at sea (CNN.com) NewsReader News Feeds 0 03-07-2007 12:15 PM
How to stay healthy on a cruise (Detroit Free Press) NewsReader News Feeds 0 02-25-2007 05:15 AM
Here's to healthy sailing (Long Beach Press-Telegram) NewsReader News Feeds 0 01-21-2007 04:15 AM
