Twin mainsheets...why? - SailNet Community
 18Likes
post #1 of 21 Old 01-03-2019 Thread Starter
My wife and I are returning to BVI, chartering a 38' with a twin mainsheet config. I get that there might be some benefit in the set-up as a gybe preventer, but not much else. The vessel is supposedly brand new(ish). Why am I not seeing this twin set up as more than buttons on a balloon?
Any thoughts appreciated.
22catcapri is offline
post #2 of 21 Old 01-03-2019
Lake Sailor
cb32863's Avatar
Re: Twin mainsheets...why?
Twin mainsheet. Do you mean two separate systems with separate blocks or do you mean it has two ends, not tied off, through the same block system?
22catcapri likes this.
Umquam Porro
Seeker 1992 Beneteau First 235
cb32863 is online now
post #3 of 21 Old 01-03-2019
SanderO's Avatar
I have a mainsheet rigged as both 8:1 and 4:1... for fine tune you use one line and for coarse trim you use both. For gybing you haul both.
pay attention... someone's life depends on it
SanderO is online now
post #4 of 21 Old 01-03-2019
Might be in lieu of a traveler
TakeFive, Arcb and 22catcapri like this.
RegisteredUser is online now
post #5 of 21 Old 01-03-2019 Thread Starter
I am not sure which system it is.
Thanks.
post #6 of 21 Old 01-03-2019
My Fantasia 35 had a twin mainsheet in lieu of a traveler.
It worked pretty well.
Arcb is offline
post #7 of 21 Old 01-03-2019
colemj's Avatar
It is just a different way of achieving the sail control that a single mainsheet and traveller would provide. We just got a boat with a dual mainsheet, so I'm just getting used to it. It really doesn't do anything for jibe prevention because they don't project far enough for that.
Essentially, one sheet is used to position the boom, and the other to control the leach tension and twist. Catana is one popular brand that has used dual mainsheets for many years.
Our other boat has no traveller and a mainsheet on the hardtop inline with the boom. However, it has a rigid vang. So this system works by using the mainsheet to control the boom position, and the vang to control the leach and twist. One advantage it has over a traveller or dual sheet is that the sail can be controlled deep off wind using the vang.
So AFAIK, there are three ways to do the same thing regarding mainsail control: traveller and mainsheet, dual mainsheets, mainsheet and vang.
Mark
Dolphin 460 Catamaran "Reach"
Manta 40 Catamaran "Reach" - For Sale!
colemj is offline
post #8 of 21 Old 01-03-2019
SchockT's Avatar
If is a newer Jeanneau then you might be referring to a German Sheeting system, which is a double ended mainsheet run to both sides of the boat. They are typically led to both primary winches. The main benefit of the setup is so that both the Genoa and the main can be trimmed from the helm position, and both share the primary winches. Since the leeward winch is being used for the Genoa, the leeward mainsheet is cleated off, and the other end is on the windward winch.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #9 of 21 Old 01-03-2019
twin main - or German mainsheet - lets you control main sail from winches at either helm position. I'm assuming your 38 has dual helms like most newer charter boats. Just don't trim from the same side all the time - you'll run out of sheet.
reeder is offline
The Following User Says Thank You to reeder For This Useful Post:
Jeff_H (01-06-2019)
post #10 of 21 Old 01-03-2019 Thread Starter
Thanks all. Will be learning new stuff!
Cabin top mainsheets chas5131 General Discussion (sailing related) 17 11-25-2009 03:06 PM
Traveler vs Twin Mainsheets mentalfee Sailboat Design and Construction 24 11-09-2007 04:10 PM
Mainsheets wgfi Seamanship & Navigation 3 12-10-2002 11:55 AM
twin keels as an option tomcostin General Discussion (sailing related) 4 06-17-2002 09:55 PM
Twin Keels EtherCat Boat Review and Purchase Forum 1 02-01-2002 02:20 AM
