Liner cleaning from leak, how difficult? - SailNet Community
 4Likes
post #1 of 11 Old 01-07-2019 Thread Starter
Looked at a prospective boat, and it had some nasty water leaking in through the chainplates (and bulkhead?), and a few stanchions. It's on the hard, this was after a solid day of pretty heavy rain here. At least it's only been in fresh water so no salt anywhere. I was in a bit of hurry, and the seller hovered over me and wouldn't shut up, but will go back in a few weeks and check more thoroughly for rot, water damage under the leak areas etc. I'm not sure how the whole width of the bulkhead got saturated?
I'm trying to judge how bad this is, whether I should try to get the price down hoping to fix the leak and clean up the liner, or just move on. Rebed looks easy, but how hard is this stuff to clean up? Will there be mold that I'll never get out? WWYD..? Assuming there's no rot inside or deck, is the cleanup & rebed a simple fix if I can get this boat for a good price? It looked ok otherwise. It's a 1999 model if that makes a difference.
Thanks
Scandium is online now
post #2 of 11 Old 01-07-2019
Skipper Jer's Avatar
Re: Liner cleaning from leak, how difficult?
My first thought, "RUN AWAY". Then looking at the pictures I had additional thoughts. Focus on the third picture, see where the washer has crushed the wood? Wood soft, not good. If that is correct then the entire bulkhead needs to be replaced. Also I'm wondering why in the second picture there are a mixture of bolts and wood screws on the chain plate. If you do decide to purchase this boat get a survey and even then there might be additional "surprises" you hadn't counted on.
RegisteredUser likes this.
Nor'sea 27
Don't re-accommodate me, Bro
And the trees are all keep equal by hatchet, axe and saw...RUSH
I invented a new word today, plagiarism.
Skipper Jer is online now
post #3 of 11 Old 01-07-2019 Thread Starter
Yes I leaning more towards that as I look at the photos pondering this. Don't want to get stuck with this headache as my first boat. It's sad as the boat was nice otherwise, and the precision 23 is hard to find (closest other for sale is Minneapolis!). The guy selling (for a friend) of course made no big deal off it, but admitted the owner "wasn't into maintenance.. So everything was original on the boat too.
Wondering if it's even worth going back, but we'll be just 40 min away so can't hurt I guess.
fallard likes this.
post #4 of 11 Old 01-07-2019
PhilCarlson's Avatar
Dock
If you're OK with replacing that bulkhead, then go for it.
Not sure how difficult it will be on that boat, but consider that the bulkhead is plywood. When it gets wet enough, it delaminates. The water intrusion will have let water work it's way down in between the plys making the problem much greater than what you see on the outside. When you tighten the rig, or load it hard, the bolts will start to work the rotten wood.
Proceed with extreme caution.
PhilCarlson is offline
post #5 of 11 Old 01-07-2019
overbored's Avatar
Call Precision and ask them how hard it is to change the bulkhead . they still make the boat so parts can be ordered. liner can be replaced. use the the fact that it needs to be replace to make the boat safe as a means to get t the best price.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #6 of 11 Old 01-07-2019 Thread Starter
uhm, yeah not really. I supposed if I get the price down it might not be huge deal, but at this point in my life I'd rather get a boat that's more or less ready to go. Adding new stuff, replacing sails etc I'm fine with, but compromised structural integrity is where I draw the line.. Call me a wimp I guess.
And considering the PO was "not good about maintenance" according to the seller, who knows what else is lurking! Think I got enough bad vibes from this one
PhilCarlson likes this.
post #7 of 11 Old 01-07-2019
fallard's Avatar
Skipper Jer called it right. Run, donít walk from this one! Sure, it might be fixable, but only if the price is right and you are interested in a project boat. Go with your gut (and vibes).
fallard is online now
post #8 of 11 Old 01-07-2019
Dont pay to be whipped, even in private.
Less abused and more cared for is available.
Have fun looking...and learn from each one
RegisteredUser is online now
post #9 of 11 Old 01-07-2019
paulk's Avatar
May be worth looking more carefully. We have leaky chainplates too. (On the project list...) The wood on our bulkhead has dark streaks and soft spots on both forward and aft sides. The wood is, however, only a thin veneer that covers a solid fiberglass bulkhead. Since there's no plywood anywhere in it, the damage is essentially just cosmetic. Make sure what you're looking at before making assumptions. I was also involved at one point with a Pearson 36 that a surveyor found did have a rotted plywood main bulkhead sandwiched between outside layers of formica. The whole thing had to be removed & replaced. The price went down about 10K on that one, but the sale still went through because the rest of the boat was in nice shape. (And they're nice boats.) So... if the bulkhead is plywood: beware. If it isn't- this could be the boat for you.
paulk is online now
post #10 of 11 Old 01-07-2019
Moderator
Arcb's Avatar
Was this the $15000 Precision 23 you mentioned in the other thread?
For $15k a small trailer sailor should be darn near pristine.
If this is the boat, and thats the price, I personally wouldnt be too keen on this boat.
Arcb is offline
The Following User Says Thank You to Arcb For This Useful Post:
Scandium (01-08-2019)
Do liner boats get mold in between the liner and the hull? Jgbrown General Discussion (sailing related) 20 11-13-2012 06:04 PM
Football Recruiting Made Difficult (Blogcritics.org) NewsReader News Feeds 0 12-17-2006 12:15 AM
Difficult Dousing Dilemma blacktie Seamanship & Navigation 17 08-01-2006 01:08 PM
At sea. Volvo Ocean race: ABN AMRO ONE makes a difficult tactical decision @ BYM Sailing News NewsReader News Feeds 0 04-11-2006 07:15 AM
3th or 40 ft is a difficult change? Oriol Boat Review and Purchase Forum 1 12-27-2001 05:25 PM
