Loooking for bowroller suggestions - Page 3 - SailNet Community
 11Likes
post #21 of 28 Old 01-13-2019
Re: Loooking for bowroller suggestions
Originally Posted by RegisteredUser View Post
The leverage forces on a sprit can be tremendous
Cant do that less than right
If forces at anchorage have already bent a reasonable quality steel Danforth which for a 38 foot boat is at minimum somewhere around a 25 lb anchor then yes it would have to be well designed/engineered and installed 100% righteously. No shortcuts or should be good enough's.
SeaStar58 is offline
post #22 of 28 Old 01-14-2019 Thread Starter
North Channel Sailor's Avatar
Yes no doubt. My primary objective is to have the ability to deploy a larger anchor. I still think I will rely on the deck cleats to hold the rode or snubber.
Could be tough to get away with a cheap soloution on this one. Iím determined to figure something since I really want to feel secure on bigger tackle.
Hughes 38
North Channel Sailor is offline
post #23 of 28 Old 01-15-2019
Sailor
Gladrags1's Avatar
This product (https://stainlessoutfitters.com/prod...chor-carriers/) looks very similar to the one my friend has on his Pearson I was referring to. I think it will do the trick!
RegisteredUser likes this.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is online now
The Following User Says Thank You to Gladrags1 For This Useful Post:
North Channel Sailor (01-15-2019)
post #24 of 28 Old 01-15-2019
Bleemus's Avatar
This is mine. Might be good on your boat . . .
Keth
Boat Vinyl Lettering and Graphics
Bleemus is offline
post #25 of 28 Old 01-15-2019
SanderO's Avatar
I think you want the anchor secure and easy to deploy. When I press the down button the anchor may nor drop unless I give it a little kick or lift the shank and that gets it going down. You want a set up that you can quickly/easily deploy.
pay attention... someone's life depends on it
SanderO is online now
post #26 of 28 Old 01-15-2019
Swedish company with lots of nice solutions
https://www.batsystem.se/en/gallery/sweden-yacht-38-2/
knuterikt is online now
The Following User Says Thank You to knuterikt For This Useful Post:
post #27 of 28 Old 01-15-2019
Heart and brain....all trusting that connection when the gale/squall rolls thru.
If you are putting it out there (pun intended)....its all you hold dear
I really like the fairlead connection to boat...and just hanger idea for anchor.
Sweet dreams are made of this...good sleep
RegisteredUser is online now
post #28 of 28 Old 01-15-2019 Thread Starter
Hughes 38
Suggestions for Repair of C&C 33 windows Tom M Gear & Maintenance 20 05-10-2009 08:50 AM
Suggestions on fishing gear sheba Cruising & Liveaboard Forum 4 06-26-2006 10:25 AM
Call for suggestions on Custom Arch bubba Seamanship & Navigation 1 09-14-2001 08:14 AM
Call for suggestions - custom arch bubba Gear & Maintenance 0 09-13-2001 12:41 PM
Tossing the 9to5 for life on the water: suggestions/experien drydocked General Discussion (sailing related) 0 02-27-2001 02:09 PM
