antifreeze for diesel engines - SailNet Community
 13Likes
post #1 of 54 Old 01-14-2019 Thread Starter
dadio917
dadio917's Avatar
Was reading the manual (always dangerous) on our little Westerbeke 35b and it says to use antifreeze specifically made for diesel engines. Have to admit I thought antifreeze was antifreeze and either greed on red. Has anyone found it really makes a difference?
Dadio917
Valiant 39
dadio917 is offline
post #2 of 54 Old 01-14-2019
Markwesti's Avatar
Re: antifreeze for diesel engines
Good one dadio917 , I had never heard of it . Now I have to read this article .
https://www.underhoodservice.com/vid...l-or-abnormal/
Westsail 28 , Patricia A
Markwesti is offline
post #3 of 54 Old 01-14-2019
overbored's Avatar
most important is to not mix the different types. there are more than two types and colors and most are spec-ed for the metals in the system that they are to protect.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #4 of 54 Old 01-14-2019
Geoff54's Avatar
Vibration can cause cavitation in diesel cylinder cooling passages. Diesel anti-freeze has additives to reduce this.
"The great thing about the internet is that you can quote anyone and no one will bother to check the source" - Aristotle
Geoff54 is offline
post #5 of 54 Old 01-14-2019 Thread Starter
dadio917
dadio917's Avatar
Geoff - interesting. Any recommendations? ours is green.
Dadio917
Valiant 39
dadio917 is offline
post #6 of 54 Old 01-14-2019
Geoff54's Avatar
Not really, sorry! I use Zerex GO5 because it is easily available from autoparts stores and was the factory coolant for diesels for a couple of major automakers. It is orange. Cummins and Detroit coolants are suppose to be good - that sounds reasonable but I have no actual knowledge. If you want to change, flush thoroughly first.
Geoff54 is offline
post #7 of 54 Old 01-14-2019
pdqaltair's Avatar
Google "diesel liner pitting." you will find many references. In dead, this problem is unique to diesels.
The problem is that under sustained high load, piston slap causes cavitation on the outside of the cylinder liner, which can lead to holes in severe cases. This can be controled with several chemistries, the most common being either nitrite/moly or high concentrations of OAT.
G05, in fact, is a good choice. Or you can just shop from the diesel engine manufacturers.
[In a former life I sat on the ASTM committee that developed the standards, and developed additives for diesels, which we tested using ultra sound. A long story and I am retired from it.]
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #8 of 54 Old 01-14-2019
This is on a tangent but still related to anti-freeze for diesel engines. A boat I know of failed the survey because the owners thought you were supposed to put anti-freeze in the fuel tank then run the diesel to make sure it was winterized. Scrap one diesel. Also ended up scrapping the entire boat. Had to call a salvage company to remove it from the marina.
ImGary01 is offline
post #9 of 54 Old 01-14-2019
Learning the HARD way...
eherlihy's Avatar
Practical Sailor did a good review of coolant for diesel engines a couple of years ago. I can't remember the brand that was considered "best," but I bought 4 gallons of it from my local Caterpillar dealer. I was surprised to find that the marina that I kept my boat in had the same brand on the shelf.
USCG Licensed OUPV Captain, US/Sailing BKB and ASA 101/103/104/105/106/114/118 Instructor - Also ABYC certified in Marine Electrical Systems,
eherlihy is online now
post #10 of 54 Old 01-14-2019
ASA and PSIA Instructor
IMHO if you are servicing a Yanmar then every part or fluid container used should say 'Yanmar'
Sent from my SM-G965U using Tapatalk
sailingfool is online now
Automotive antifreeze vs. RV antifreeze for engine. dman535 Gear & Maintenance 54 04-04-2020 12:19 AM
how much antifreeze? xort Gear & Maintenance 5 10-24-2008 07:11 PM
Antifreeze valdon34 Gear & Maintenance 2 07-18-2008 01:06 PM
Is winterizing/antifreeze needed for in-water boat on Vancouver Island? FrankLanger Gear & Maintenance 5 09-20-2006 06:19 PM
antifreeze stm Gear & Maintenance 8 02-04-2004 02:53 PM
