Reinstalling stanchions on teak cap rail - SailNet Community
 10Likes
post #1 of 12 Old 01-30-2019 Thread Starter
krisscross's Avatar
I need to replace 3 stanchions that sit on teak cap rail. The bases have 4 bolts and a backing plate below. Boat is Island Packet 35. Old stanchions had some rubber like sealant under them. I’m going with same bases so there will be no need for new holes. What do you suggest for bedding them? Thank you in advance.
Plato
krisscross is online now
The Following User Says Thank You to krisscross For This Useful Post:
MarcusJames (01-30-2019)
post #2 of 12 Old 01-30-2019
Sailor
Gladrags1's Avatar
Re: Reinstalling stanchions on teak cap rail
Butyl rubber available in West Marine.
Sent from my iPhone using Tapatalk
krisscross and MarcusJames like this.
Mandolin
Bayfield 36
Sailing out of Rock Creek, Chesapeake Bay
Gladrags1 is online now
post #3 of 12 Old 01-30-2019 Thread Starter
krisscross's Avatar
Would you just do the bolts, or entire base?
Plato
post #4 of 12 Old 01-30-2019
Sailor
Gladrags1's Avatar
I would probably just do the bolts as the butyl will squeeze out from under the base?
krisscross likes this.
Mandolin
Bayfield 36
post #5 of 12 Old 01-30-2019 Thread Starter
krisscross's Avatar
That is what I was thinking as well. Just doing the bolts.
Plato
post #6 of 12 Old 01-30-2019
Chamfering the bolt holes is a choice
RegisteredUser is online now
post #7 of 12 Old 01-30-2019
Senior Moment Member
SloopJonB's Avatar
Originally Posted by RegisteredUser View Post
Chamfering the bolt holes is a necessity
Corrected.
Also, I prefer to not have sealant under the outboard edge of the base so any water that gets under it (and it will) has a path to escape.
I seal the countersunk boltholes and lay a bead around the other three sides of the base. I've never had a leak after doing it that way.
RegisteredUser and krisscross like this.
SloopJonB is online now
post #8 of 12 Old 01-30-2019
Señor Member
ottos's Avatar
Kriss,
You could refer to Maine Sail's write-up, and use his Butyl if the write-up helped you. https://marinehowto.com/bed-it-tape/
Otto
ottos is online now
post #9 of 12 Old 01-30-2019 Thread Starter
krisscross's Avatar
I have the butyl tape, but I was not sure if installing hardware on teak would be any different. The factory used something like liquid rubber on the entire length of the bolts. They are now a real b..tch to pull out. I got blisters on my blisters from trying to pull them out.
Plato
post #10 of 12 Old 01-30-2019
They did good...
reinstalling rail hardware CapnRon47 Gear & Maintenance 5 03-09-2011 04:37 PM
removing cap rail and sealing deck-hull joint tflak Gear & Maintenance 3 05-09-2010 01:44 PM
? re. reinstalling deck hardware 2Sheets2Wind Gear & Maintenance 0 04-12-2010 03:08 PM
Help reinstalling my old Northstar 951x landlockvasailor Gear & Maintenance 0 08-11-2008 10:03 PM
advice on reinstalling a centerboard cable ambianceack Sabre 0 09-20-2006 10:04 PM
