SailNet Community (https://www.sailnet.com/forums/)
-   Gear & Maintenance (https://www.sailnet.com/forums/gear-maintenance/)
-   -   Black water holding tank (https://www.sailnet.com/forums/gear-maintenance/328190-black-water-holding-tank.html)
Teamstone 01-30-2019 10:33 AM
3 Attachment(s)
35 Allmand
Holding tank under the dinette (assume that in the normally place for it)
I have a small leak (confirmed by dye)
Not sure if it is the screw in "blank" on the stern side of tank or a small crack in the bottom.
Will be trying to remove the blank on the left and using Boatlife to seal it. I have attached a photo of the plug I am talking about.
Assuming that doesn't work, will be needing to R&R it.
Do we know who made the tank and if it still available?
I assume I will have to cut out the fiberglass under the dinette seat to do the R&R and than have it repaired.
If you have to have a custom tank made, who do you recommend?
chef2sail 01-30-2019 08:47 PM
Re: Black water holding tank
I recommend plastic not metal after you remove it.
Many reputable fabricators online . Some have a huge variety of premades also. Now's the Time also to have the outlets exactly where you want them placed
Ronco-plastics.com is where we bought ours.
Minnewaska 01-31-2019 06:11 AM
Originally Posted by Teamstone (Post 2051580140)
...If you have to have a custom tank made, who do you recommend?
I had my custom 77 gallon poly tank made by Triple M plastics in Maine. Awesome service. They delivered it to me.
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
