What type of technical drawing - SailNet Community
 2Likes
  • 2 Post By Jeff_H
post #1 of 2 Old 01-30-2019 Thread Starter
I have a Columbia 8.3, that I am trailering from California to Texas.
I just bought a trailer and need to add in the supports. I have found general dimensions for the boat, but not precise dimensions.
Searching through the internet, I have found a site that has all the technical drawings for the boat. What type of techinical drawing would I need to order, so I can get all the correct dimensions of the hull?
I was about to order the General Arrangement drawing, but wasn’t sure that it would have all the necessary details.
chipd512 is offline
post #2 of 2 Old 01-31-2019
Administrator
Jeff_H's Avatar
Re: What type of technical drawing
You would need the lines drawing, and know how to read them to get the shape right, and the accommodations plan to see where framing and the prop shaft are located.
But in reality, even with the lines drawing, it would be difficult to accurately construct "bunks" that would fit the boat since the molds for a value oriented production boat rarely match the lines drawings. But also, you will want to be able shift the boat on the trailer to make sure that you get the tongue weight right.
If you really want to build a custom fit trailer, it would be a better idea to accurately measure the boat on the trailer and then careful build the supports.
A better plan B would be to weld up a support structure for the bottom of the keel and three sets of properly braced tubes that will accept the adjuster screw and pads from jackstands.
SanderO and PhilCarlson like this.
Jeff_H is online now
TY 37 bowsprit drawing mylynne General Discussion (sailing related) 8 07-08-2018 01:31 PM
Drawing By 10-Year-Old George Washington Found? - History NewsReader News Feeds 0 02-23-2012 05:50 PM
Where can I buy circular compasses used for graphing and drawing angles? Mildreond General Discussion (sailing related) 4 04-05-2011 12:48 PM
Cat 30 Line Drawing? rayncyn51 Catalina 13 05-23-2010 07:05 PM
Lines Drawing for Cal 39 bheintz Sailboat Design and Construction 1 02-04-2009 06:35 PM
