Henderson MKIII replacement - SailNet Community
post #1 of 9 Old 02-06-2019 Thread Starter
My ancient Henderson mkIII through bulkhead mounted manual bilge pump stopped working over last summer and from research it seems the mkV diaphragm will replace the one in the mkiii however the valves are long out of production
A thread on a contessa website suggests that the mkV pump is a direct replacement as far as bolt up pattern and bulkhead rubber fitting however Iím unsure. I was wondering if anyone had done this replacement
I can always order from west marine and return if it doesnít fit but wanted to see before I put in the trouble.
Thanks,
Jeffrey Gawrys is offline
post #2 of 9 Old 02-06-2019
Re: Henderson MKIII replacement
Same footprint seems to be important.
Learn if there are new pumps with same.
Prob easiest longterm fix
RegisteredUser is online now
post #3 of 9 Old 02-06-2019 Thread Starter
Yes what Iím wondering is if the mkV available New has the same bolt pattern as the original mkiii, I canít find a mounting diagram online to match up with my measurements from the boat.
Also if the mkV rubber bulkhead is the same as the mkiii
post #4 of 9 Old 02-06-2019
The parts kit, including the valves, is available on Amazon
Hudsonian is online now
post #5 of 9 Old 02-13-2019 Thread Starter
For anyone wondering, the whale/simms engineering mark v is a direct replacement for the old mkiii. Same bolt holes, size etc.
The base of the pump is exactly the same as well as the diaphragm and pumping mechanism however the cover is different to accommodate the joker style valve they use in all of their other pumps.
The new mark v even still says Henderson on it instead of whale!
I know there are plenty of these left in boats so I hope it helps anyone looking around on the internet for a solution.
These pumps are different from whales numerical pumps in that the v and iii are different from the 5 and 3, I donít have either of these so I canít speak to their bolt alignment or sizes
The Following User Says Thank You to Jeffrey Gawrys For This Useful Post:
danvon (02-20-2019)
post #6 of 9 Old 02-15-2019
TQA
Bombay Explorer 44
TQA's Avatar
I hope you don't mind if I join in. I have a similar problem with 3 old Henderson pumps. One is leaking and I need to get it out and rebuild it. One has a hole in the front plate which is just a dust cover.
My boat is 40 years old and I am assuming the pumps to be original fitment.
Can anyone confirm the model from the pics.
Dependent on the model I guess but what about rebuild kits. My current understanding is the Mk 5 diapragm will fit but not the valves. The front plate rubber is also available.
TQA is offline
post #7 of 9 Old 02-20-2019 Thread Starter
It looks to me like you have a mark 5 style pump and rebuild kits are available anywhere.
All the kit is is a diaphragm, auction and discharge valve.
Is yours a joker style discharge valve?
post #8 of 9 Old 02-20-2019
This is a great coincidence. Was just about to start rebuilding mine & trying to figure out what the hell mine was. Looks just like TQA's.
danvon is offline
post #9 of 9 Old 02-21-2019
hpeer's Avatar
Interesting, we have a double acting Mark V bilge pump. Essentially two pumps on one actuating shaft, back to back. I try it once in a while. Until 2 days ago it worked fine, now seems to be operating inefficiently.
We also have 2 Lavac toilets that use the same pump making 4 pumps in total on this boat.
I think I have 2 rebuild kits aboard, and a spare pump.
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
Coast Guard saves two teens whose sailboat crashed near Henderson Harbor - WatertownD NewsReader News Feeds 0 07-07-2014 06:30 AM
Man dies after sailboat hits power lines, causing electrocution on Henderson ... - Gr NewsReader News Feeds 0 06-15-2014 06:50 PM
Man dies after sailboat hits power lines, causing electrocution on Henderson ... - Th NewsReader News Feeds 0 06-14-2014 02:50 PM
Officials: Man electrocuted while moving sailboat into Henderson - FOX ... - WHNS Gre NewsReader News Feeds 0 06-13-2014 11:50 AM
Newport 27 MKIII help vesper55 Boat Review and Purchase Forum 1 07-23-2001 06:57 PM
