Another anchor thread - SailNet Community
 74Likes
post #1 of 115 Old 02-07-2019 Thread Starter
krisscross's Avatar
Is 45lbs CQR adequate for a 18,000 lbs 35' Island Packet as a primary anchor? About 200' of chain (have not measured it yet).
I have another space on the bow roller. The stern anchor is 9kg CQR. Adequate for frequent anchoring along SE coast?
Plato
krisscross is offline
post #2 of 115 Old 02-08-2019
Old soul
MikeOReilly's Avatar
Re: Another anchor thread
I’ve not travelled this area, so I don’t have personal experience with the kinds of bottoms you can expect. However, the size seems right for the CQR. Chain seems adequate. However, I would also carry a large Danforth-style anchor, and be prepared to switch between the two. I’d also get another 100’ of rope rode, just in case.
Personally, I’d spend the relatively small dollars to upgrade to a new-gen anchor.
I did cruise (seasonally) over many years using a CQR and a Danforth. I carried both on the bow, and would switch between them depending on the bottoms. Eventually I upgraded to a Rocna, which covers most of the same range of the CQR/Danforth combo.
chef2sail, capta and krisscross like this.
Why go fast, when you can go slow.
BLOG:
MikeOReilly is online now
post #3 of 115 Old 02-08-2019
SanderO's Avatar
Your ground tackle sounds OK. Shiva is 16,000# x 36' and carries 200' of 5/16" chain and a 36# CQR and a Bruce which was lent and never returned! I did fine in NE and in the Caribe with this tackle only dragged a few times in 25 years! Important is your TECHNIQUE which includes a snubber and a windlass. I think Mike's idea of a next gen is a sound one. Reviews suggest this as well.
pay attention... someone's life depends on it
SanderO is online now
post #4 of 115 Old 02-08-2019
bell ringer
Don L's Avatar
It's probably enough, once it's set, on paper.
Wouldn't be my choice and since you are asking I bet you aren't all the comfortable with it.
Don't blow air up my rear, be useful and blow it at the sails!
Don L is online now
post #5 of 115 Old 02-08-2019 Thread Starter
krisscross's Avatar
I was thinking that one anchor might not be enough, and was considering getting a used danforth as I had good success with that anchor type in the past. Just not sure about the right weight for this boat.
I also have extra rode and a hefty rode rider weight.
What would be your choice, Don?
Plato
post #6 of 115 Old 02-08-2019
Master Mariner
capta's Avatar
Weight wise I think 45# is about right, but you didn't mention chain size. I'm sure after all these years you know my feelings on primary anchors, so I'll not repeat it once again. However, I have no idea what you would use the 9# anchor for except possibly your dinghy. For the 35' Island Packet I'd suggest around 200 feet of ˝" chain if you want the 9 pounder to be useful for anything other than wrapping around a tree or between boulders for Med mooring.
Personally, I would rather a Fortress than a steel Danforth as my #2. It breaks down into a pretty manageable size and has an immense amount of holding power for its weight. They can usually be picked up used for only a bit more than a steel anchor, so just look around. The nice part of the Fortress is that they are 100% guaranteed, so if you bend a fluke, you just get a replacement and you are back in business.
Good luck with your new boat and perhaps we'll see you in an anchorage down this way someday soon.
MikeOReilly and krisscross like this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #7 of 115 Old 02-08-2019
TQA
Bombay Explorer 44
TQA's Avatar
Absolutely fine for Florida and the Bahamas.
If you have any pennies to spare I might replace the smaller CQR with an ali danforth type. The holding on a straight pull in sand or mud is much better and you are most likely to need it for a fore and aft moor [ Bahamian ] somewhere you get current reversal.
I lived on the hook with a 45 lb CQR as my primary for 10 years firstly with a heavy 38 ft steel ketch then a 44 ft lightweight sloop some of the time was in your area. ,
I did replace the CQR with a Rocna recently but that was mostly because it needed to be regalvenised and it is hard to find somewhere that still does that.
krisscross likes this.
TQA is offline
post #8 of 115 Old 02-08-2019 Thread Starter
krisscross's Avatar
The chain is G4 5/16. Matches my windlass so not likely to change that.
Thank you for the input. Much appreciated.
The small CQR on the stern is 9 kg, not 9 lbs, and it's all rode.
What size Fortress or Danforth secondary anchor would you advise? The chart says 15 lbs for this boat but it seems a bit light.
Plato
post #9 of 115 Old 02-08-2019
Master Mariner
capta's Avatar
That is the thing with a Fortress; holding power @ lightweight. I went with the recommended one as I'd had no experience with them. Have only used it once, to hold the stern to the swell in an anchorage and it worked wonderfully even w/o chain. Of course, in that situation, (wind nearly or on the beam) one would hope that it's the stern anchor that drug in a squall, rather than one's primary.
capta is online now
post #10 of 115 Old 02-08-2019
Old soul
I cruised with a 45# CQR with my 15 ton boat for a few seasons. A bit undersized in my opinion, but it still worked OK. As Sander wisely mentions though, good technique is vital for these anchors.
I second Capta’s recommendation for a Fortress. I use "Danforth-style" generically. A Fortress is generally a better version of these anchors. Fortress has good sizing charts. Generally, I say get the biggest one you and your boat can reasonably manage, but with an aluminum Fortress this could become huge.
Be fully prepared to go between the two. The CQR is an OK anchor (in my opinion), but it doesn’t do as well in softer mud/sand. This is where you want the Danforth (or Fortress). Neither do well in very hard bottoms. A new-gen anchor covers this whole range, and does most tasks generally better. It really is worth the added bucks.
For the record, I now carry a Rocna (#55) as my bower. I have a 15 kg Bruce as my stern ‘Oh Shyte!’ anchor. I carry a large Danforth as a backup, and a very large Fortress (F37 I think) as my storm anchor. Three separate rodes.
BLOG:
Another Venture 17 keel repair question Another Venture 17 keel repair thread Vssman MacGregor 25 01-31-2020 01:06 PM
Thread Thread: Trimaran Trampolines and UV Resistant Thread petertribo General Discussion (sailing related) 7 10-24-2013 09:29 AM
Another Boat on the Beach, Another Anchor Thread sww914 General Discussion (sailing related) 10 04-03-2013 09:23 PM
Another Anchor Thread Powernow General Discussion (sailing related) 2 01-21-2009 04:36 PM
Yet another anchor question. Has anyone seen/used an Oceane anchor? SVDistantStar Gear & Maintenance 2 08-28-2008 01:09 AM
