Lofrans Cayman chain type? - Page 2 - SailNet Community
 1Likes
post #11 of 15 Old 02-11-2019 Thread Starter
Re: Lofrans Cayman chain type?
Originally Posted by celenoglu View Post
Very close but not the same. I am sometimes using 1/2 inch wrench for 13mm bolts. They are also very close but if the bolt is a little bit corroded, I feel the 1/2 fits better.
Not sure what that's relevant.
The difference between 1/2" and 13MM is 0.3MM
The difference between 5/16" and 8MM is 0.06MM
Also, it says right on the windlass "8MM or 5/16"" ... so it's clearly designed with 0.06MM of tolerance.
BillMoran is online now
post #12 of 15 Old 02-11-2019
overbored's Avatar
The diameter is very close but it is the pitch of the chain that make the difference. if you look at the charts on the 8 mm size it is closer to 5/16" BBB chain in pitch then 5/16" HT chain. why not use the chain it is designed for? the 8 mm ISO766 chain or get a different Gypsie
"GOLD RUSH" PRINDLE 16
overbored is online now
post #13 of 15 Old 02-11-2019 Thread Starter
5/16" IS what it's designed for. It's marked right on the gypsy that it's for 8MM or 5/16". Lofrans designed the gypsy to work with both of those chain dimensions, which is hardly surprising given how close they are.
post #14 of 15 Old 02-11-2019
The pitch..link length..is just a little different between BBB and G4 short link.
Your gypsy might handle both...or not.
RegisteredUser is online now
post #15 of 15 Old 02-18-2019
captflood's Avatar
GREETINGS EATHLINGS :- do yourself a favour and change the "O Ring" on the end of the gypsy with a piece of rigging wire or SS mig wire stops the whole lot coming off in anger "AS ALWAYS GO SAFE"
captflood is offline
Chain to chain connectors on anchor chain kwaltersmi Gear & Maintenance 12 10-16-2013 09:24 AM
Want to Buy - Lofrans chain wheel (gypsy) pacsail4837 Gear & Maintenance 3 02-21-2013 07:49 PM
Need 5/16HT gypsy for Lofrans-Royal windlass icaptain Gear & Maintenance 3 08-16-2009 12:36 PM
Lofrans Windlass just makes spinning noise Bene505 Gear & Maintenance 18 09-11-2008 09:12 AM
Quick vs Lofrans windlass telekitr Gear & Maintenance 0 08-25-2008 08:31 AM
