Lofrans Cayman chain type? - SailNet Community
 1Likes
post #1 of 15 Old 02-10-2019 Thread Starter
When I started refitting this boat last year, I purchased a Lofrans Cayman windlass and installed it.
As I'm (finally!) nearing the end of the refit, I need to buy ground tackle. The gypsie on the windlass has "8MM" stamped on it. It's my understanding that there are size difference between HT and BBB chain. Does anyone know which type is correct for this Windlass? I'm attempting to contact Lofrans, so we'll see if their support is any good.
BillMoran is online now
post #2 of 15 Old 02-11-2019
Moderator
MarkofSeaLife's Avatar
Dock
Re: Lofrans Cayman chain type?
Its not the windlass, its the gypsy. you can pull it off and change it to whatever size you want the chain to be. But they are not cheap.. $200?
Wgat the size of your boat? 8mm is very small. I use 10mm on a 39 footer.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go
And they'll turn it down for the cell they know
MarkofSeaLife is offline
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
BillMoran (02-11-2019)
post #3 of 15 Old 02-11-2019 Thread Starter
Right ... but I'd prefer not to change the gypsy unless I have to ...
The boat is a Tartan 37, so 37 foot and about 15000 pounds dry.
I also heard back from Lofrans this morning, and they claim the type of chain _is_ stamped on the gypsy, so I'll have another look ... Turns out it's stamped DIN766, which I didn't previously recognize as part of the chain designation, but now I know ...
Using this https://www.westmarine.com/WestAdvis...An-Anchor-Rode and considering my boat medium weight, I get 1/2" rope and 1/4" chain as recommended sizes. Since 8MM is about 5/16, it's actually a bit larger than the recommendation. Did I read that chart wrong or is this a matter of personal experience on your part that bigger is needed?
post #4 of 15 Old 02-11-2019
Prob 5/16 g4 chain matched to 5/8 8-plait nylon
...but check what your gypsy will handle
RegisteredUser is online now
post #5 of 15 Old 02-11-2019
colemj's Avatar
The chart for your boat says 5/16" chain, unless using HT, then 1/4". Personally, I would use 8mm or 5/16" HT (G43) chain if it was my boat - and I'm a proponent of light chain.
Mark
Manta 40 Catamaran "Reach"
colemj is offline
post #6 of 15 Old 02-11-2019
Your 15.5 dry boat will prob be over 18 when you are supplied
post #7 of 15 Old 02-11-2019
TQA
Bombay Explorer 44
TQA's Avatar
Take the gypsy with you when visit the chain supplier. Buy chain that fits the gypsy.
TQA is offline
post #8 of 15 Old 02-11-2019
celenoglu's Avatar
Although inches can be converted to milimeters, there will be differences. make sure you use the chain specified for your gypsy. Hand fitting the chain on the gypsy is not very indicative.
celenoglu is online now
post #9 of 15 Old 02-11-2019 Thread Starter
Apparently (according to Lofrans) 5/16" and 8MM are 100% interchangeable. Your overall point is taken, however.
post #10 of 15 Old 02-11-2019
celenoglu's Avatar
Very close but not the same. I am sometimes using 1/2 inch wrench for 13mm bolts. They are also very close but if the bolt is a little bit corroded, I feel the 1/2 fits better.
MarkofSeaLife likes this.
Chain to chain connectors on anchor chain kwaltersmi Gear & Maintenance 12 10-16-2013 09:24 AM
Want to Buy - Lofrans chain wheel (gypsy) pacsail4837 Gear & Maintenance 3 02-21-2013 07:49 PM
Need 5/16HT gypsy for Lofrans-Royal windlass icaptain Gear & Maintenance 3 08-16-2009 12:36 PM
Lofrans Windlass just makes spinning noise Bene505 Gear & Maintenance 18 09-11-2008 09:12 AM
Quick vs Lofrans windlass telekitr Gear & Maintenance 0 08-25-2008 08:31 AM
