Tides Marine mast track - SailNet Community
 7Likes
post #1 of 11 Old 02-11-2019 Thread Starter
I've been pricing out a replacement mast for my San Juan 21. The existing mast broke, and a previous owner spliced it back together. The problem is the track on the luff side (hope I used the correct term!) has some damage and as a result the slugs on the main come right out when I raise it to that position. While searching I found a link to the mast track system. I'm wondering if this might be an acceptable solution to the problem?
I live in Montana, this boat will be used on local lakes only. The first quote I have received back is $1900 plus shipping. That's $1700 more than I paid for the boat. More importantly, I have to convince the wife that money spent on "that old heap" will be worth it in the end. She would rather have a motor boat.
So considering the use and budget, am I being reasonable in thinking the mast track will be a good solution?
Thanks!
Sent from my Moto E (4) Plus using Tapatalk
Newbie sailor with (now 2) San Juan 21.
skills4lou is online now
post #2 of 11 Old 02-11-2019 Thread Starter
Re: Tides Marine mast track
I should also mention that I'm replacing all the running rigging, and slowly inspecting my way through the standing rigging, and expect to do some gelcoat repairs, and need to make me covers for the cushions, and.... You get the idea.
post #3 of 11 Old 02-11-2019
Trailer Sailer Moderator
Rezz's Avatar
Do you have a pic of the area where the slugs pop out? Honestly, for a boat that cost you so little (I know the feeling), cheaper may be the way to go. I'm wondering if you can just gently reshape the track with your tool of choice.
gamayun and RegisteredUser like this.
~ Rezz
S/v DreamWeaver
1980 Laguna Windrose 22
Rezz is offline
post #4 of 11 Old 02-12-2019
Sailnet Vendor
jblumhorst's Avatar
Location: San Francisco Bay area and West Coast by trailer
Dock
Thanks!
If you do decide to install a TidesTrack, it should cost around $750, not 1900.
tides track runs $26 - 28 per foot of luff. That’s around $650for a SanJuan 21. That includes the track and the slides for your sail. Plus about $100 shipping in the USA.
You can install the track yourself, and probably swap in the slides as well. Tides track is pretty diy friendly.
Judy B
San Francisco Bay and Delta
F24 Trimaran
jblumhorst is offline
post #5 of 11 Old 02-12-2019
My boat has a Tides track. I didn't install it, it came with the boat, but as far as I know the track slides into the track for the sail. Mine is only secured a the very top and it's a much bigger boat. I'm having trouble understanding how your sail stops pop out of the track, so it makes me wonder if the Tides track would pull out as well.
I also wonder if you can solve the issue just by using bigger slugs on your mainsail luff.
Pics?
jarcher is offline
post #6 of 11 Old 02-12-2019
paulk's Avatar
A picture might help us get a better idea of the problem, but there might be two ways to fix this cheaply and easily. If the luff groove is too wide and the slugs pop out, take Rezz's idea and use a hammer with a wood block to bend the arms of the extrusion (gently) closer together. There's a thread on Sailing Anarchy (Dinghies) showing this problem and solution, with pictures. Put the section you're banging on a bench so you don't bend the mast. It might take an hour. If the issue is caused more by a gap in the mast extrusion - the sides of the groove are missing because that's where it broke - have a welder fill in the missing material so there's no gap. He'll need to be careful not to fill in the groove, or you'll have to grind it so the slugs will get through afterwards! It would be a big hassle, to get in there to open up passage for the slugs without bending the arms of the groove open and re-creating the problem! Someone here at the expensive end of the country might charge $60 for something like that. It might take him 15 minutes. You could also try such a fill-in repair using some epoxy goop, but a weld might end up lasting longer and looking better. (The epoxy would need to be painted, which means painting the whole mast...) K.I.S.S.!
paulk is online now
post #7 of 11 Old 02-12-2019
hpeer's Avatar
We have Tides track I installed myself. It was not too hard.
Yes your price seems way out of wack. What size boat are we talking here?
The sail track has a life expectancy based upon UV exposure. It seems that it’s about 8 years minimum for tropical sun conditions. When you replace it they seem youbthe track alone at a reduced price.
Your P dimension is 23’ and tides is quoting $29.10/foot on their website, you may do better through a rigger. Anyway that looks like under $600. Maybe they thought you meant METERS?
I would also consider the weight you are adding to the mast. I would check that it is appropriate for such a small boat.
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
post #8 of 11 Old 02-12-2019 Thread Starter
Thanks everyone! The $1900 is for a new mast. Just the track is $700ish.
Post #6 is the problem I'm having. The track is widened at the break, allowing the slugs to pop out of the channel. I hadn't considered welding it. And I have the equipment to do just that. I guess for some stupid reason that just never occurred to me. I think my repair may have just gotten a lot less expensive!
gamayun and overthehorizon like this.
post #9 of 11 Old 02-12-2019
colemj's Avatar
Could you just screw a piece of aluminum plate to the mast to cover the wide/broken area?
Mark
JimMcGee likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #10 of 11 Old 02-12-2019
JimMcGee's Avatar
Catalina Direct sells mast gates for the Catalina 22. From what you're describing these should do the trick for about $40 bucks. Drill four holes and you're done...
MastGater Sail Track Gate, C-22, CP-22
jarcher and RegisteredUser like this.
Currently Boatless
ďThe sail, the play of its pulse so like our own lives: so thin and yet so full of life, so noiseless when it labors hardest, so noisy and impatient when least effective." - Henry David Thoreau
JimMcGee is online now
Advice wanted: Tides Marine Track and Slide system JackandJude Gear & Maintenance 16 10-19-2012 01:16 PM
Tides Marine STRONG mainsail track system BELLATRIX1965 Gear & Maintenance 11 05-31-2012 11:52 PM
Tape under mast track to separate stainless from aluminum mast preservedkillick Gear & Maintenance 1 05-12-2012 01:37 PM
The right track for sail track Skipper Joe Gear & Maintenance 4 07-26-2011 10:26 AM
Tides Strong Track System chef2sail C & C 7 03-07-2011 09:52 PM
