Help Removing Rudder - SailNet Community
post #1 of 9 Old 02-17-2019 Thread Starter
I know that there are quite a bit of posts on the internet about removing rudders. However, I have a Morgan 321 that I am trying to replace the cutlass bearing and need to drop the rudder. On this boat the rudder sits on a lower support.
Anyone out there know how to remove that type of rudder?
Any help would be greatly appreciated.
Rhorlacher is offline
post #2 of 9 Old 02-18-2019
TQA
Bombay Explorer 44
TQA's Avatar
Re: Help Removing Rudder
Are you SURE you need to remove the rudder?
TQA is online now
post #3 of 9 Old 02-18-2019
In my Pearson there is a small cutout in the leading edge of the rudder. If you move the rudder all the way to the left or right it allows enough clearance to remove the prop, shady or bearing without dropping the rudder.
Just to be clear, is your's a full keeled boat with tiller steering?
CLOSECALL is online now
post #4 of 9 Old 02-18-2019
I believe the Morgan 32 has skeg. If I've got this right, and the rudder doesn't allow access as the OP states, here's what we did on our boat with a skeg hung rudder.
1. dig a hole under the rudder.
2. Remove the shoe at the base of the skeg.
3. Unclamp the quadrant.
4. Drop it into the hole.
5. Do your thing.
6. Reverse the steps.
Good luck! It's a PIA but not as bad as it sounds.
capecodda is online now
post #5 of 9 Old 02-18-2019 Thread Starter
Thanks very much for the replies. I am certain that I need to remove the rudder. I unhooked the steering and with the rudder turned in any direction, the most I get is about a 2" gap from the leading edge of the rudder to the end of the prop shaft. The prop is about 3" deep, so it is very close but will not go.
I am going to try and remove the shaft from the coupler first, then remove the coupler from the area and then see if I can slide the shaft back to get the prop off. I am replacing the cutless bearing and repacking/replacing the stuffing box, so I need to pull the shaft anyway. Maybe that will work.
As a side question, the shoe on the bottom does not look like it unbolts. Could it have bolts bedded in the paint? I did not thoughly inspect, but it seems like it is all once piece.
post #6 of 9 Old 02-18-2019
Don't know for sure on the shoe on your boat, but my guess is that it was faired over, just a guess.
post #7 of 9 Old 02-18-2019 Thread Starter
Thanks for all the replies. This is very helpful.
I will also write back once complete, as it might help others in the future.
post #8 of 9 Old 02-19-2019
Tartan 27' owner
CalebD's Avatar
Good luck with this job and do report back how it goes.
I tackled the same job on my old boat a while back, chronicled here:
2011, November 30th. Begin drive train rebuild | Odalisque
We foud that it was much easier to just cut the shaft then to mess around trying to separate shaft from coupling in that small uncomfortable space.
You will want a threaded prop puller tool, like a steering wheel puller from NAPA or other.
A brand new shaft hopefully wont cost more than $300, probably less in stainless.
Everybody has one:
CalebD is online now
post #9 of 9 Old 02-20-2019 Thread Starter
Thanks for the posts. I really hope I don't need to replace the shaft, but will cut if needed.
Also, thanks for the link. Now I know what I will be doing online the next few days. Ha Ha. Your site is inspiring and can't wait to see all you did.
Catalina 30- removing rudder for service narrowpath Catalina 5 11-29-2017 11:11 AM
Removing cutless bearing without removing the shaft (Video) SSBN506 Gear & Maintenance 5 07-15-2014 04:37 PM
Any tips for removing corroded bolts at rudder? kjzerr Gear & Maintenance 11 05-10-2013 11:11 AM
PS31 Removing Rudder to get Shaft out yellotaxi Pacific Seacraft 2 04-13-2010 09:12 PM
Removing the rudder Survivor Gear & Maintenance 4 08-08-2008 12:37 PM
