Removing the haze from Dodger windows - Page 3 - SailNet Community
 3Likes
post #21 of 30 Old 02-23-2019
pdqaltair's Avatar
Re: Removing the haze from Dodger windows
Originally Posted by SanderO View Post
I've used Pledge furniture polish... seems to work fine. When they get scratched... time to replace.
FWIW, Pledge is the one of the few products that Strataglass (premium vinyl maker) specifically forbids under warrentee, because of repeated problems with it creating discoloration after repeated use.
Just sayin.'
NEVER:
Use Windex, Rain-X, Pledge, Plexus, Simple Green, Orpine or any other harsh cleaner to clean CrystalClear.
Use a car wax or any kind of wash and wax to protect CrystalClear curtains.
Use cleaners, polishes, scratch removers, or any products intended for commercial grade vinyl or plastic.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #22 of 30 Old 02-23-2019
SanderO's Avatar
Just sayin.'
NEVER:
Thanks.... I don't contemplate making a warranty claim... My dodger has 2 panels of plastic and the are pretty good... or no worse than the Sunbrella.... I replace the whole thing every 6 or 7 years or so... and the Pledge seems to work fine during this period.
pay attention... someone's life depends on it
SanderO is online now
post #23 of 30 Old 02-23-2019
bell ringer
Why not just use the correct polish as the cost is minor in the big picture?
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is online now
post #24 of 30 Old 02-23-2019
Markwesti's Avatar
I have had good results with this . It really helps to have a solid backing on the other side and a car buffer helps too .
https://www.walmart.com/ip/Meguiar-s...SABEgIca_D_BwE
Westsail 28 , Patricia A
Markwesti is online now
post #25 of 30 Old 02-23-2019
chef2sail's Avatar
My question also....why invent alternatives when the manufacturer gives you a rather cheap solution for protecting it's product
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #26 of 30 Old 02-24-2019
SanderO's Avatar
Purchasers of dodgers etc. with windows don't get an mfg maintenance sheet. However the custom canvas shops should have a hand out and if they had any class they would provide on can of the proper window cleaner with the sale.
post #27 of 30 Old 02-24-2019
TakeFive's Avatar
I've used the same stuff. It worked very well. My windows were hazy and yellow, and I was considering replacing them. Then I found the bottle of Meguiars that they PO had left on the boat, so I tried it. I used a car wax sponge to wipe on and polished both sides by hand - didn't have to be particularly vigorous. The yellow sponge turned a mucky gray color, and the windows turned clear. I got the feeling that most of the discoloration was pollen that had stuck on and decayed to slime over time. That stuff even gets under the snap-on Sunbrella covers that we always use.
I can't guarantee OP's results, but if his dodger is less than 10 years old, he probably has some life left in it.
SanderO and Markwesti like this.
Rick S., Swarthmore, PA
USCG Certified Captain, OUPV and 50 Ton Master
2001 Catalina 34MkII Tall Rig Wing Keel Breakin' Away, Universal Diesel M35B, Mantus 35 lb. anchor, sailing out of Rock Hall Landing Marina
TakeFive is offline
post #28 of 30 Old 02-24-2019
Not all clear vinyl is the same, as I understand it. Eisenglass, rolled vinyl, strataglass, etc. IIRC, strataglass has an outer layer that is different from it's core, which is why you can never polish it with an abrasive, which would remove this outer layer. I could be wrong, but that's what I've understood.
I had a canvas shop once say that the only thing one should ever use to clean clear vinyl is diluted vinegar and water. I did it for years, however, I hate the smell of vinegar, unless it's in food.
I now use the Strataglass cleaner in the spray bottle. Smells like coconut, which I'm sure is it's primary advantage. That and doing no damage, but I don't think it either cleans or protects better than the water-vinegar mix.
The primary advantage of applying a polish is that seawater will shed off better for about one hour after you apply it.
Jeanneau 54DS
Minnewaska is offline
post #29 of 30 Old 02-24-2019
pdqaltair's Avatar
Most manufacturers make both coated and un-coated. Strataglass (coated) and Crystal Clear 20/20 are from one maker, and O'Sea (coated) and Regalite are from another. The coating is polyurethane and does make buffing somewhat more difficult. The coating slightly increases abrasion resistance and stiffness (bad) and considerably increases resistance to internal fogging in damp weather.
Some of the cleaners dramatically improve beading and hence visibility in the rain for months. Starbrite ViewGuard is my favorite cleaner, Imar the best protectant, and I avoid compounding.
(I had test panels on my roof for 5 years, with 5 vinyl products and more than a dozen cleaners and polishes.)
SanderO likes this.
post #30 of 30 Old 02-24-2019
SanderO's Avatar
my windows never turned yellow or discolored... they got scratched... and show dried salt at times from spray. The few times a year that I wipe them with pledge seems to show no effect on the material. Mine is going on 7 years... the cloth needs some tending to... not the plastic windows. The center window is designed to be removed (or flipped on top of the dodger). In summer it is rarely left in place except when it's raining. 99% of the *viewing* is through the center where there is nothing (panel removed) to get hazy or fogged. This is largely a non problem on our boat.
compass lens haze lans0012 Gear & Maintenance 16 03-11-2012 08:19 PM
hard dodger vs soft dodger bluetommy77 Boat Review and Purchase Forum 6 10-07-2007 06:29 PM
Malaysia warns Malacca Strait ships as haze worsens (Reuters via Yahoo! Asia News) NewsReader News Feeds 0 10-09-2006 07:15 AM
Malaysia warns Malacca Strait ships as haze worsens (AlertNet) NewsReader News Feeds 0 10-09-2006 04:15 AM
Haze on new cetol ??? skyamsen Gear & Maintenance 2 10-20-2003 06:53 PM
