Propane line - Page 2 - SailNet Community
 14Likes
post #11 of 42 Old 03-12-2019
Dirt Free
boatpoker's Avatar
Re: Propane line
Yes. Pressure loss over length is real. Suggest you talk to the manufacturer before ignoring their requirements.
This one does not apply but if you search online you should be able to find a calculator for your size piping.
LPG friction/pressure loss calculator.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #12 of 42 Old 03-12-2019 Thread Starter
Master Mariner
capta's Avatar
Re: Propane line
Well, assuming I'll be using about 2.5 gallons every two or three months on a 16 foot run, that table seems to leave me well below problem level.
Thanks for the info.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #13 of 42 Old 03-12-2019
Always learning...
Re: Propane line
I have seen several references online stating a 1.5m recommended maximum length for a flexible hose connection to a hard feedline, in order to accommodate a gimballed installation. It seems this might be standard practice in some areas, but is not the recommendation of the ABYC. Perhaps this is the reason your documentation reads as it does?
Jonathan
MarkofSeaLife likes this.
S/V Pinniped
Jason 35
jwoytek is online now
post #14 of 42 Old 03-12-2019
Dirt Free
boatpoker's Avatar
Re: Propane line
Jonathan
No, ABYC A-1, Marine Liquified Petroleum (LPG) Gas Systems makes no reference to any length whatsoever, whether pipe, tube or hose are used.
post #15 of 42 Old 03-12-2019
Dirt Free
boatpoker's Avatar
Re: Propane line
Capta, I can't upload pdf's to this site but if you send an email to [email protected] I will respond with the ABYC LPG Standards.
capta likes this.
The Following User Says Thank You to boatpoker For This Useful Post:
capta (03-13-2019)
post #16 of 42 Old 03-13-2019
SanderO's Avatar
Re: Propane line
You can save a PDF as a JPEG... at least in Bullzip which is a great alternative to Adobe who changed their financial model to a subscription. Bullzip is a single purchase. I switched and love it. Interface is intuitive and easy to pick up. basic version is free! Upgrade is not expensive.
FREE PDF Printer
pay attention... someone's life depends on it
SanderO is online now
post #17 of 42 Old 03-13-2019
Dirt Free
boatpoker's Avatar
Re: Propane line
FREE PDF Printer
Thanks but I don't want any more software.
I tried saving a pdf as a jpeg (didn't know that could be done). It does work but I don't have the patience to upload 34 pages at one photo per page.
post #18 of 42 Old 03-13-2019
SchockT's Avatar
Re: Propane line
You are only storing the propane in liquid form. When you use it on your appliances you are drawing vapor off the top of the tank. The regulator reduces that gas pressure to 11" wc, or about 0.4psi. Such low pressure is very sensitive to restriction and pressure drop. At the burner the appliance relies on gas velocity coming through the burner orifice to draw air in to mix with the gas. If pressure and flow are reduced at the burner it may not mix enough oxygen, and you end up with incomplete combustion, which will manifest as yellowish flame, and sooting on your pots. Incomplete combustion also produces carbon monoxide, which, of course, is not a good thing in an enclosed space.
Gas is not something to be trifled with. If you are not sure, consult a gas fitter.
Sent from my SM-G960W using Tapatalk
SanderO, boatpoker, flyrod and 1 others like this.
2011 Jeanneau 39i Azura
SchockT is online now
post #19 of 42 Old 03-14-2019
Re: Propane line
As noted above the pressure drop along a hose depends on the length and number of bends etc. in the hose. Another important factor is the inside diameter of the hose. Using a larger diameter hose will result in less pressure drop. A larger diameter hose that ends in a fitting that will attach directly to your stove might solve any pressure drop problem, should one occur. The trick might be finding one.
chicory83 is offline
post #20 of 42 Old 03-14-2019
Dock
geoirishbox is offline
Propane line re-route Oday30 deniseO30 Gear & Maintenance 6 08-20-2007 10:01 PM
Line Choice for Single-Line Reefing lmitchell Gear & Maintenance 6 04-12-2007 01:38 PM
Shorter Single Line Reef Line dnseal Gear & Maintenance 6 11-26-2006 05:58 PM
How to connect American propane line to European stove faithab General Discussion (sailing related) 3 05-25-2006 04:29 PM
