What are these Pushpit Fittings for? - Page 2 - SailNet Community
 3Likes
post #11 of 15 Old 03-18-2019
Re: What are these Pushpit Fittings for?
Originally Posted by SchockT View Post
So according to some at the Jeanneau forums those "pins" are the remnants of a horseshoe ring bracket that was cut off, which makes sense I guess since we cant use horseshoe rings in Canada.
Sent from my SM-G960W using Tapatalk
What are you hanging your life ring from?
Jeanneau 54DS
Minnewaska is offline
post #12 of 15 Old 03-18-2019 Thread Starter
SchockT's Avatar
At the moment there is a hook clamped to the rail for the life ring, but on my previous boat I used a LifeSling instead of a ring, and I will probably do that again.
2011 Jeanneau 39i Azura
SchockT is online now
post #13 of 15 Old 03-18-2019
The LifeSling is just a horseshoe on a tether. I thought CA required a lifering. Seems your prior owner sawed off the lifering bracket to make some room. Easily re-accommodated, however you'd like to set it up.
Jeanneau 54DS
post #14 of 15 Old 03-18-2019 Thread Starter
SchockT's Avatar
Yes, we have annual safety inspections at our club, and every year I bring the big plastic life ring down to the boat, and tie a piece of rope to it to satisfy the inspector. Then once the inspection is done the ring goes away, and the life sling gets mounted on the rail instead.
In my mind the Lifesling, which is required equipment for racing anyway, makes a lot more sense than the big plastic ring!
post #15 of 15 Old 03-19-2019
roverhi's Avatar
Have a self deploying Epirb that I can't find a place to install as it needs fairly large unobstructed area to mount. If you have one, the bracket might work for that.
roverhi is offline
Can someone identify these fittings? BillMoran Gear & Maintenance 2 12-26-2017 08:20 PM
Can anyone identify these light fittings for me TQA Gear & Maintenance 6 05-22-2013 09:25 AM
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 05:48 PM
Cal 25 Pushpit?? sturmkatze Cal 0 10-17-2007 06:37 PM
Replacment Pushpit Tree Gear & Maintenance 4 02-06-2005 06:58 PM
