What are these Pushpit Fittings for? - SailNet Community
 3Likes
post #1 of 15 Old 03-16-2019 Thread Starter
SchockT's Avatar
I am curious what the flange and pins were intended for. The previous owner had the bbq mount here but I want the bbq closer to the propane tanks, so the outboard mount will go here.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
post #2 of 15 Old 03-16-2019
I cant see it very well on my fone.
Maybe stern nav lite...?
RegisteredUser is offline
post #3 of 15 Old 03-16-2019
Flag mount...dunno
post #4 of 15 Old 03-16-2019
roverhi's Avatar
Re: What are these Pushpit Fittings for?
Whatever the PO wanted to mount to the plate. Note the hole spacing and see what you can find that you might need hanging off the pulpit and will fit or can be adapted to the hole pattern. Since the bracket is welded on easier to find a use for it than to remove it.
capta likes this.
roverhi is online now
post #5 of 15 Old 03-16-2019
Master Mariner
capta's Avatar
I see a hole in the verticle tube (to run a wire?), so I'd go w/a stern light, too. Do you have a masthead tricolor now?
SanderO likes this.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #6 of 15 Old 03-16-2019
The pins on the top rail could keep the bbq hardware from rotating while a sturdy support strut was bolted to the plate.
paulinnanaimo is online now
post #7 of 15 Old 03-16-2019 Thread Starter
SchockT's Avatar
The stern light is mounted on the transom from the factory, and the bbq mount was just a scotty mount clamped beside the pins. There is a socket welded to the pushpit that I assume is for a flag pole.
post #8 of 15 Old 03-17-2019 Thread Starter
SchockT's Avatar
So according to some at the Jeanneau forums those "pins" are the remnants of a horseshoe ring bracket that was cut off, which makes sense I guess since we cant use horseshoe rings in Canada.
post #9 of 15 Old 03-17-2019
Horseshoe, ring buoy, LifeSling...base of MOB pole (does anyone carry those any more?) or you could pretend to be American and mount an extra cup holder there.(G)
Of course if you are racing you'll need to get a cutting wheel and grind off that extra weight at once!
bshock likes this.
hellosailor is offline
post #10 of 15 Old 03-18-2019
SanderO's Avatar
I do have a MOB tied to a horse shoe and strobe... more useful at MOB in night time. But for sure a good marker for returning to a location.
pay attention... someone's life depends on it
SanderO is online now
Can someone identify these fittings? BillMoran Gear & Maintenance 2 12-26-2017 08:20 PM
Can anyone identify these light fittings for me TQA Gear & Maintenance 6 05-22-2013 09:25 AM
Swaged fittings vs. mechanical fittings yachtthor Pacific Seacraft 24 04-21-2012 05:48 PM
Cal 25 Pushpit?? sturmkatze Cal 0 10-17-2007 06:37 PM
Replacment Pushpit Tree Gear & Maintenance 4 02-06-2005 06:58 PM
