Moisture meter - SailNet Community
 6Likes
  • 1 Post By SanderO
  • 2 Post By colemj
  • 1 Post By boatpoker
  • 2 Post By boatsurgeon
post #1 of 7 Old 03-18-2019 Thread Starter
davidpm's Avatar
Moisture meter
https://www.dropbox.com/sh/2llhwg4nv...jyG3uCCVa?dl=0
I put a moisture meter on the deck of this boat and got some varied readings.
I'm aware that the meter doesn't measure moister but an electical effect that might be correlated to moisture.
I also know that metal will make the meter go high.
As a potential buyer, not a surveyor I'm not inclined to tap the deck with a hammer.
I know that if the meter pegs to right the deck is really wet.
I know that if the meter registers low it is probably dry.
What I don't know is how much of a problem are the intermediate readings.
What do you think?
davidpm is offline
post #2 of 7 Old 03-19-2019
SanderO's Avatar
Re: Moisture meter
Tap the deck with a nylon mallet and compare the sound to the values of the meter.
tempest likes this.
pay attention... someone's life depends on it
SanderO is online now
post #3 of 7 Old 03-19-2019
colemj's Avatar
Re: Moisture meter
The meter is on non-skid. Tough to measure. Did you try it on large, clear non-skid areas with no deck penetrations? If so, did you also get variable readings? Salt and dirt also effects readings - were these areas cleaned and dried first?
I don't know why you would hesitate to tap an area - it is non-destructive and the owner shouldn't mind. You don't whale on it with a hammer. Some gentle tapping with the end of a screwdriver handle will tell a lot. The reason surveyors use a phenolic hammer (besides being a more comfortable tool) is that with experience, the hammer gives a physical feedback that adds value in addition to the sound.
Mark
SanderO and tempest like this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #4 of 7 Old 03-19-2019
Dirt Free
boatpoker's Avatar
Re: Moisture meter
Sharon and I use brass hammers and have never marked a boat. I was never satisfied with the feel of a phenolic hammer. A very gentle tap is all that is required. As Colemj says, the feel (bounceback) is every bit as important as the sound.
We use Lee valley plane hammers with a hardwood tip on one end. We sometimes use the wood tip end on very good paint jobs. We replaced the original wood tip with lignum vitae.
SanderO likes this.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is offline
The Following User Says Thank You to boatpoker For This Useful Post:
davidpm (03-19-2019)
post #5 of 7 Old 03-19-2019
Tough to top real experience...and having that sense
RegisteredUser is online now
post #6 of 7 Old 03-19-2019 Thread Starter
davidpm's Avatar
Re: Moisture meter
Mark
Yes it read dry in other non-skid locations.
It was clean.
davidpm is offline
post #7 of 7 Old 03-20-2019
Re: Moisture meter
What do you think?
I concur it is very impolite to strike someone else's boat with any object. If the owner has signed a purchase and sale agreement that allows you to inspect the boat to this level, that's another story. It is pretty hard to find a 30+ year old boat that doesn't show higher readings somewhere. Most marine sealants start failing in about 10 years. Unless the owner has removed all deck fittings and resin potted the mounting holes, higher readings are inevitable. Higher readings alone, though undesirable, don't necessarily mean recore unless accompanied by rot and delamination. Very high readings, generally mean something more than just replacing the bedding compound will be required.
SanderO and davidpm like this.
boatsurgeon is offline
Is there an affordable moisture meter? jarcher Gear & Maintenance 32 08-30-2018 11:43 PM
Low Cost General Tools Moisture Meter? TakeFive Gear & Maintenance 17 12-11-2012 06:08 PM
HELP! - Need Moisture Meter in Ft Myers eherlihy Boat Review and Purchase Forum 0 02-24-2010 06:37 PM
Could someone lend me a moisture meter? TakeFive Gear & Maintenance 24 12-25-2009 01:36 PM
Could I borrow a moisture meter? TakeFive Boat Review and Purchase Forum 1 12-21-2009 09:48 AM
