Best GFlex-650 Filler for Keel Joint Sealing - SailNet Community
post #1 of 8 Old 03-19-2019 Thread Starter
So, this weekend I will be doing some work on my rusty bolt-on keel.
I want to seal the keel-hull joint with the West Systems GFlex-650 which is a flexible epoxy, so it should last a few seasons without cracking.
My priority is to keep the joint water-tight, but it would be nice to have something that is easily sandable. My understanding is the low density stuff is easily sandable, but do I give up the waterproofing for that?
My question is which West Systems filler should I use to thicken the epoxy?
hildamman is offline
post #2 of 8 Old 03-19-2019 Thread Starter
Re: Best GFlex-650 Filler for Keel Joint Sealing
I found this manual by west systems, on page 55 for Keel hull joint, they don't mention any filler - just GFlex, so unless someone has a better idea, that is what I am going to go with.
post #3 of 8 Old 03-21-2019
I'll be curious to know how your repair went and how it holds over the seasons.
The previous owner used something like 3m 4200 and faired it smooth. The boat was out of the water when I bought her, so I ground down to raw glass/lead over a 8" width around the entire keel stub/keel.
Any areas that had a joint I filled with 3M 4200 to fill the gap then tightened the bolts.
From there I used 6oz cloth and did 6-8 layers around the entire keel join(8" wide tape) and then faired it smooth with 407. I used interlux 2000e for the barrier coat. So far i haven't had an issue(repair performed in August of 2018). I'm curious to see how the repair holds up over the years, but I will say if I make it to a place such as Mexico, I'll likely redo the entire repair using a biaxal after dropping the keel, checking the keel bolts and rebedding the keel back to the keel stub.
chowdan is offline
post #4 of 8 Old 03-21-2019
What kind of keel joint are you fairing, a straight joint from a stub to the keel or a 90 degree joint from the keel directly to the hull? I have the latter and just fair the joint with a generous dose of 4200. Easily replaced every few years, as necessary.
Jeanneau 54DS
Minnewaska is offline
post #5 of 8 Old 03-21-2019
Very good point. This would definitely change ones approach to a repair!
Saw a keel like that for the first time in a yard in Canada last weekend. Very interesting design I must say!
chowdan is offline
post #6 of 8 Old 03-27-2019 Thread Starter
It is a vanilla straight joint. Here are some pictures.
post #7 of 8 Old 03-27-2019 Thread Starter
I will keep you updated. This grinding business is nasty s**t and taking longer than I expected. My current plan for the keel-joint is:
  • Grind out 1/8 of an inch of the current sikaflex sealant (deeper if I see deeper rust stains)
  • Grind out rust on top of the keel until I hit clean metal
  • POR-15 degreaser, etch/rust convert and then 4 layers of POR-15 for the entire keel (including the top of the keel)
  • Lightly sand the POR-15
  • Fill the joint with GFLEX
  • Cover the keel-hull joint with 2 inch fibreglass tape soaked with Gflex
  • Brush on more gflex over the fbreglass tape.
  • 4-6 Coats of Interlux 2000
  • Fare & sand and irregularities with Quick Fare.
  • 2 more layers of Interlux 2000.
  • Bottom-paint
My plan for the whole keel in general is
  • Get the Rust off
  • Lightly Sand the POR 15
  • 4-6 coats of Interlux 2000
  • Fare the keel with Quck Fair
  • 2 Coats of Interlux 2000 over that.
  • Bottom Paint.
Hope this makes sense. I will keep you updated on my progress and how this works out over the years. BTW, I am using the general guidelines by this gentlemen, which seems to have held up for 10 years.
post #8 of 8 Old 04-03-2019
  • Bottom-paint
  • Get the Rust off
  • Bottom Paint.
Good luck! I do agree the grinding part is the absolute worst. I dont mind working with glass at all surprisingly.
One thing I will advise during the fairing part. When you think you get her as smooth as possible, slap your first coat of interlux 2000 on it, then take a look to see if you actually are smooth. If not, let the first coat tack up and slap your final fairing compound on.
This was recommended to me by a professional glass worker - after I had ran out of time and needed to finish up the project. In turn, my keel is not as fair as it should be, and it was incredibly obvious when I put my first coat of interlux on.
chowdan is offline
West System Gflex Bruce3966 General Discussion (sailing related) 1 07-07-2015 10:22 AM
Sealing the stub / keel joint (the smile) WoobaGooba Gear & Maintenance 2 04-14-2014 08:38 PM
Questions about barrier coat on steel keel, and sealing keel joint EricinToronto Gear & Maintenance 1 04-21-2012 10:43 PM
removing cap rail and sealing deck-hull joint tflak Gear & Maintenance 3 05-09-2010 02:44 PM
Sealing the hull and deck joint SSBN506 Gear & Maintenance 3 03-16-2009 08:15 PM
