Putting her away - Page 3 - SailNet Community
 3Likes
post #21 of 28 Old 04-08-2019 Thread Starter
outbound's Avatar
Re: Putting her away
2000 m from the nearest west Marine. Will hit island water works and see what they have and read the labels.
s/v Hippocampus
Outbound 46
outbound is online now
post #22 of 28 Old 04-08-2019
Freedom Chip Counter
scubadoo's Avatar
If anyone is in need of a "boat sitter" on the SE coast of Florida, let me know! I'd be happy to do it on an as needed basis for the cost of time and mileage. Send a PM if interested.
Dave
Tartan 31
scubadoo is offline
post #23 of 28 Old 04-08-2019
Bleemus's Avatar
Originally Posted by SanderO View Post
If you have solar why can't you turn the batts off and let a bilge pump wired directly to the batts drain the water? I realize keel stepped masts get water into the boat and that needs to be removed.
Deck stepped should have no leaks and may not need to leave the bilge pump on. Solar should keep the batts topped up.
If the boat gets hit by lightning your solar and bilge pumps are likely toast.
Sent from my moto x4 using Tapatalk
Keth
Boat Vinyl Lettering and Graphics
Bleemus is online now
post #24 of 28 Old 04-08-2019
Bleemus's Avatar
A gallon of Simple Green never hurt anything and it smells good.
Keth
post #25 of 28 Old 04-08-2019
colemj's Avatar
Not everyone thinks that: https://www.ewg.org/guides/cleaners/...PurposeCleaner
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #26 of 28 Old 04-09-2019
I use it aboard, especially to clean up grease or oil. I understand, however, if left to stand for extended periods, it will corrode some metals. Aluminum in particular. You are cautioned not to use it on aircraft, with aluminum structures, and not to leave it on any aluminum for more than 10 minutes, without thoroughly rinsing. Simple Green even developed a special formula for aircraft, as a result. The Air Force banned the original formula.
As long as you rinse well or keep it off aluminum, it's good stuff.
Jeanneau 54DS
Minnewaska is offline
post #27 of 28 Old 04-09-2019 Thread Starter
outbound's Avatar
Our go to general cleaner is fresh water with some Dawn and vinegar in it. Followed by fresh water.
s/v Hippocampus
Outbound 46
post #28 of 28 Old 04-09-2019
Bleemus's Avatar
Same here. No Dawn though. Vinegar and water. Use it on everything.
Keth
Putting Away the Little Sneakbox Sailboat -- Moving on After My Husband's Death - Huf NewsReader News Feeds 0 04-27-2015 05:30 AM
Options for Charging batteries while away from the boat OR away from shore power northwestsailor Electrical Systems 3 05-04-2013 12:30 AM
Sell her or ship her? shadypark General Discussion (sailing related) 1 09-14-2009 06:14 AM
West Marine Peel Away vs. Peel Away Marine Strip 2 SeanC. Gear & Maintenance 0 03-24-2006 04:28 PM
Peel Away Marine Strip II is the same as Standard Peel Away foxglove Gear & Maintenance 2 04-08-2004 10:13 AM
