Putting her away - SailNet Community
 3Likes
post #1 of 28 Old 04-02-2019 Thread Starter
outbound's Avatar
Putting her away
Have decades of experience laying up a boat for winter storage in the US northeast but no experience putting a boat on the hard in the tropics for the summer
Would appreciate any advice about putting my Outbound 46 away at Clarkeís Court Grenada 🇬🇩.
s/v Hippocampus
Outbound 46
outbound is online now
post #2 of 28 Old 04-02-2019
SanderO's Avatar
Re: Putting her away
One of the risks is Hurricanes which are lower in the Grenada and Trinidad. Some people I know who stored had the hull buried so it wouldn't tip off the stands. Protect from UV and provide for ventilation.
pay attention... someone's life depends on it
SanderO is online now
post #3 of 28 Old 04-02-2019
colemj's Avatar
Do yourself a favor and put some of these throughout the boat: https://www.njsupply.com/SunPac-Mild...4_p_70422.html
They will not only keep the boat free of mold and mildew, they keep bugs out of the interior of the boat. I think you can get them in Grenada - ask around.
If possible, put in a dehumidifier. Make sure to plug all entries into the boat, like engine room vents, tank vents, etc - bugs and daubers like to nest in them. Use screening material so that air can still pass.
Mark
outbound likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #4 of 28 Old 04-02-2019 Thread Starter
outbound's Avatar
Been told conflicting information
Some close dorades and any other openings. Hang dehumidifier bags and mildewcide.
Some stuff bronze wool in dorades and any other openings but leave things open
Some put cover over boat to protect from uv.
Some don’t due to fear it will become partially detached flail in the wind and cause damage. Also concern it will limit ventilation.
Some hire a service to check on the boat.
Some don’t.
Some disconnect batteries.
Some just turn off inverter and depend on their solar and wind to keep thing charged.
(We have lifeline agms - solar and wind)
Some leave water tanks completely empty.
Some completely full.
All leave fuel full and holding empty.
What do you do and why?
s/v Hippocampus
Outbound 46
post #5 of 28 Old 04-02-2019
colemj's Avatar
Mildewcide, air-permeable blockages in openings. We have hung dehumidifier bags and buckets in the past, but found they did not do anything except provide a pool of water to evaporate back in the air. Instead, we have placed a couple of these around the boat - drill a hole in the collection bucket, place them in sinks, and let the water drain overboard. However, you do need power while gone. https://www.amazon.com/dp/B01KTAF4I8...d_i=B01KTAF4I8
Some donít due to fear it will become partially detached flail in the wind and cause damage. Also concern it will limit ventilation.
Don't cover - particularly if in storm zone. UV is part of the boat's normal life and would be there if you were on it.
Some donít.
We don't. We know so many people who have come back to find their "professionally cared for boat" a complete mess. Batteries don't get charged, maintenance doesn't get done, etc. If you do want a service, I can recommend safe yachts grenada - Credentials
If shore power is available, we leave both it and the solar charging the batteries. The battery charging profiles are adjusted to remain in float, with a short re-absorption charge every 2 weeks. The absorption voltage is lowered below gassing voltage. This is when we had FLA batteries. Our procedure for LFP is different for reasons relating to battery type.
Why one would leave the water tank full is beyond me. It would be a biologic disaster upon return. We leave our fuel at whatever level it is at when we haul, and have never had an issue. You are in the Caribe, holding tanks shouldn't even be a discussion, but empty for sure.
Mark
CVAT likes this.
- Current boat
- Previous boat
colemj is offline
The Following User Says Thank You to colemj For This Useful Post:
outbound (04-02-2019)
post #6 of 28 Old 04-02-2019
Mold would be my number one concern. If power was available, a dehumidifier draining down a sink would be my preference, but I suspect it's not an option. May not be safe to leave it plugged in for such a long unattended time anyway.
What if you sealed every opening and set off a chlorine dioxide bomb. It would be inhospitable down below, but easily vented out, upon return.
I would be inclined to blow out the fresh water lines, just like winter, and bleach shock when I return.
Batteries on solar would be ideal.
Don't see much need to cover. I'm sure you're going to strip sails and canvas.
Stand anchoring for tropical storms is key. Grenada is not immune, just less likely.
Jeanneau 54DS
Minnewaska is offline
post #7 of 28 Old 04-05-2019 Thread Starter
outbound's Avatar
So have
Mildewcide
Water absorpers for spaces that canít be left open
Bronze wool to place in through hulls
Plastic mosquito screen to place inside dorades cowlings
Supplies to pickle watermaker.
Supplies to change oil in engine and generator before layup.
Zincs
Cordage for messagers when running rigging is removed
What did I forget to bring back from the states?
s/v Hippocampus
Outbound 46
post #8 of 28 Old 04-06-2019
Do you get any bilge water from rain? Our keel stepped mast, with 70ft furling slot will put 2-3 gallons in the bilge from one good storm. I pull a thru hull near the base of the mast, to allow drainage. May not be an issue, but I would want any potentially collected water to find itís way out.
Which mildewcide are you using? I think the dilemma is whether it will be effective, if there remains airflow. For winter here, I put 8 Damp Rid buckets around and collect 0.75 gallon of water over our relatively dry winter. One would think theyíll fill quickly there. I know someone who swears they just draw in more moisture to replace anyway. Not sure. We also put kanberra gel around, in open containers. I buy the 24oz refill bag and deploy it all for being on the hard. You donít need their individual containers. However, I would prefer something more certain and aggressive down there.
While you plan to put to sleep, weíre knee deep in commissioning. Been aboard since Tues. Always a ton of work. In and out. All the best in laying up.
Jeanneau 54DS
post #9 of 28 Old 04-06-2019
chef2sail's Avatar
So have
Mildewcide
Zincs
Kannabera Gell
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
ďSailing is just the bottom line, like adding up the score in bridge. My real interest is in the tremendous game of life.Ē- Dennis Conner
chef2sail is online now
post #10 of 28 Old 04-06-2019
SanderO's Avatar
If you were storing on the hard in the summer and making regular visits to the boat... what measures would you take?
Putting Away the Little Sneakbox Sailboat -- Moving on After My Husband's Death - Huf NewsReader News Feeds 0 04-27-2015 04:30 AM
Options for Charging batteries while away from the boat OR away from shore power northwestsailor Electrical Systems 3 05-03-2013 11:30 PM
Sell her or ship her? shadypark General Discussion (sailing related) 1 09-14-2009 05:14 AM
West Marine Peel Away vs. Peel Away Marine Strip 2 SeanC. Gear & Maintenance 0 03-24-2006 03:28 PM
Peel Away Marine Strip II is the same as Standard Peel Away foxglove Gear & Maintenance 2 04-08-2004 09:13 AM
