Fin-keeled Sailboats on Grids - SailNet Community
 2Likes
post #1 of 12 Old 04-08-2019 Thread Starter
Avast, ye scurvy dogs!
Sailheads,
Thinking about doing some below-the-waterline work on a grid instead of going through the expense of hauling out.
Thing is, I've got a fin keel and was wondering if I would damage my hull by resting the full weight of the boat on it.
Any thoughts about this or any other things I ought to think about before I attempt this?
Cheers.
Ed
Ed Kinney is offline
post #2 of 12 Old 04-08-2019
al brazzi
Re: Fin-keeled Sailboats on Grids
Are you doing this in the water, not sure how you mean but accomplish this but a good bit of the weight is resting on the Keel when hauled, my guess would be 60-80%, bracing is to steady, some weight is distributed but not as much as on the Keel.
albrazzi is offline
post #3 of 12 Old 04-08-2019
Master Mariner
capta's Avatar
I don't see a problem. If the boat can't take her own weight on her keel, then there are probably other problems that need to be addressed. It is best if you have a rub rail to rest the boat against the piles.
As mentioned Jack stands in a yard are mainly to keep the boat upright and should be taking any significant weight of the weight of the boat. By overtightening the stands is how yards and unknowledgeable people do damage to boats.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #4 of 12 Old 04-09-2019
roverhi's Avatar
The entire weight of the boat should be taken up by the keel when hauled on any boat. The stands are only there to keep the boat from tipping over. Drying out the boat on the tide will work with a fin Keeler if the boat will sit on the keel with side supports to keep it upright. I used halyards tied to anchors to insure the boat wouldn't tip over. Boats that are regularly dried out on the tide have boards that bolt to the sides of the boat. One thing to be concerned about with a fin keel boat is fore and aft stability. Some boats, especially ones with raked keels, may fall over forward without support. May want to have a piece of scrap lumber to prop the bow up.
roverhi is online now
post #5 of 12 Old 04-10-2019
Ed, how much work? Your marina may be willing to do a short haul, on Friday afternoon, and leave it sit until Monday morning.
jarcher is offline
post #6 of 12 Old 04-10-2019
Originally Posted by Ed Kinney View Post
.....instead of going through the expense of hauling out.
...wondering if I would damage my hull by resting the full weight of the boat on it.
These seems to conflict, so not sure what you're asking. Bottom line is that any boat should be designed to take it's weight on it's keel, when on the hard. Totally normal. All keel types.
If you're removing the internal grid to modify it, while on the hard, that may change the engineering.
Jeanneau 54DS
Minnewaska is offline
post #7 of 12 Old 04-10-2019
SanderO's Avatar
Clue... when your boat is hauled, blocked on the hard with jack stands... the weight is on the keel. Sure the stands are carrying some load... but it a small fraction of that on the keel.
pay attention... someone's life depends on it
SanderO is online now
post #8 of 12 Old 04-10-2019
Senior Moment Member
SloopJonB's Avatar
As noted above, if your boat can't sit on its keel you have other, structural, concerns.
With a fin keel boat on a tide grid the real concern is whether or not the boat is balanced longitudinally - some boats want to go bow down when the water goes away.
SloopJonB is online now
post #9 of 12 Old 04-10-2019
Tidal grids are still common on the coast, often harbouring a fin keel bow down, cleats askew.It would appear that some underestimate the thought needed. Many tidal grids have cross timbers so the keel is a single point contact.That makes it tricky to balance.
Capt Len is online now
post #10 of 12 Old 04-12-2019
paulk's Avatar
Interesting thread to compare with one on a French site (check out the photo here:https://www.hisse-et-oh.com/forums/l...-sur-la-quille ) where a boat's keel pushed up through the hull when they went to put it on a grid. The general consensus there was that a boat should NOT be expected to rest fully on its keel, and should not be stored that way. They seemed to think that it was important to support the hull independently, and that one should not expect the keel to hold up the hull. If that is the case, it is hard to imagine how they expect the boat to be lifted in slings without the keel dropping off, but they seemed willing to ignore that issue.
SloopJonB likes this.
paulk is online now
Wing-Keeled C&C 30 MkII?? Kenneth K C & C 13 01-14-2018 11:45 AM
Tidal grids with fin keel boats Buchido Gear & Maintenance 8 09-23-2012 02:29 AM
Swing Keeled 26-28 ft boat? mmazour Boat Review and Purchase Forum 0 05-24-2010 01:49 PM
Is adding a fin or bulb to a fin keel ok? rangeryacht26 Sailboat Design and Construction 10 09-12-2008 09:13 PM
Fin/spade vs Modified fin skeg? orthomartin Boat Review and Purchase Forum 17 01-08-2007 06:44 PM
