Sticky question - SailNet Community
 2Likes
post #1 of 14 Old 04-10-2019 Thread Starter
Sticky question
I'm making new slats for my companionway but the widest teak boards that I've been able to purchase are 8 inches. I'll have to glue two pieces edge-to-edge to replicate the sizes of the existing boards. My plan is to use dowels to attach the pieces (I considered biscuits but the Internet consensus seems to be that dowels are stronger, particularly in applications like doors). My question is what glue to use? My research suggests either epoxy (West System, in my case) or a wood glue like TiteBond III. Any recommendations by y'all?
nestorph is offline
post #2 of 14 Old 04-10-2019
Re: Sticky question
Epoxy does a good job holding wood together.
Something to think about is that you aren't required to match the original slat height. You can just have more slats, if you like. They may even be easier to store. More work to take in/out, however.
Towguy likes this.
Jeanneau 54DS
Minnewaska is offline
post #3 of 14 Old 04-10-2019
Markwesti's Avatar
Re: Sticky question
On our boat they used teak ply and then edge trimmed in solid teak .
Westsail 28 , Patricia A
Markwesti is offline
post #4 of 14 Old 04-10-2019
overbored's Avatar
Re: Sticky question
If I wanted wood I would laminate several pieces about 2" wide and run dowels the full width to make up the boards, the more lamination the less chance of warpage. one 8" wide piece will warp.
the wood does look nice but the newer boats are using smoked plexi because it does not warp , does't need a finish and lets light in.
I have not had wood ones on my boats for 30 years and don't miss them.
SanderO likes this.
"GOLD RUSH" PRINDLE 16
overbored is online now
post #5 of 14 Old 04-10-2019 Thread Starter
Re: Sticky question
That was my plan B and now having given it more thought, it's probably the least complicated solution. Thanks for reminding me!
nestorph is offline
post #6 of 14 Old 04-10-2019 Thread Starter
Re: Sticky question
That was the case with my first boat. This one has solid teak but as another poster mentioned below, it did warp. Looks like I have to do more thinking...
nestorph is offline
post #7 of 14 Old 04-10-2019
al brazzi
Re: Sticky question
Mine are banded, meaning a end plate tongue and grooved perpendicular to the end grain. So wood grain going in two different directions, which means more stability on flatness but just a bit of movement in the different grain directions, certainly not an issue for me anyway. I have a single hatchboard I use off season to cover the hole up with just house paint on it and it holds up well, then I refinish the nice ones and put back on in the spring.
albrazzi is offline
post #8 of 14 Old 04-10-2019
Master Mariner
capta's Avatar
Re: Sticky question
Weldwood Plastic Resin Glue is made specifically for gluing wood.
“Believe me, my young friend, there is nothing - absolutely nothing - half so much worth doing as simply messing about in boats.” ― Kenneth Grahame, The Wind in the Willows
facebook.com/svskippingstone
capta is online now
post #9 of 14 Old 04-10-2019
Re: Sticky question
Another vote for plexy, if you have room to store the full sized single panel.
Jeanneau 54DS
post #10 of 14 Old 04-10-2019
SanderO's Avatar
Re: Sticky question
I replaced the teak plywood companionway hatch board w/ 1/2" thk smokey plexiglass with a wide teak edge on the top to life it out. Bottom is beveled to match the pitch of the teak sill piece. Looks great, lets light in... low maintenance.
Solid wood lay up edge to edge can warp... not a great idea.. needs continual varnishing.
pay attention... someone's life depends on it
SanderO is online now
Sticky Deck Question Neicy Gear & Maintenance 15 10-12-2007 05:00 PM
Sticky subject! RAGTIMEDON Gear & Maintenance 4 08-06-2007 12:00 PM
Re: sticky business with my inflatable NewsReader Mass Bay Sailors 0 06-04-2007 08:15 PM
sticky business with my inflatable NewsReader Mass Bay Sailors 0 06-04-2007 11:15 AM
Sticky Gelcoat. Any advice [email protected] Gear & Maintenance 2 03-27-2001 05:20 PM
