Insulating top of ice box - SailNet Community
 13Likes
post #1 of 16 Old 04-14-2019 Thread Starter
krisscross's Avatar
My ice box has a lot of condensation on top surface when my refrigerator is running. I take it the insulation is not sufficient. Right now I知 covering it with a sheet of closed cell foam, about half inch thick. It definitely helps but I知 contemplating a better solution. Any ideas?
Plato
krisscross is offline
post #2 of 16 Old 04-14-2019
Re: Insulating top of ice box
How about another sheet of foam glued to the underside of the lid to increase R value?
krisscross likes this.
Capt Len is online now
post #3 of 16 Old 04-14-2019
1st thought....
Are you ok with the power draw/need
If so..maybe you just l8ve with it
Gallery counter top space is dear.
Mine is usually confused...
RegisteredUser is online now
post #4 of 16 Old 04-14-2019
Old boat refrigerators are horribly insulated by modern standards. What you're already doing is probably the most reasonable solution without getting into a big renovation project.
I'm doing the same with mine, but also budgeting for a major renovation next season.
BillMoran is offline
post #5 of 16 Old 04-14-2019
roverhi's Avatar
The engineers say 4" of blue board on sides and bottom or eqjuvalent R value, 2" for the top for a refrigerator box. Should have a UV barrier especially on the top under the companionway. That can be as simple as glued on tin foil shiny side out. As Registereduser says may be you can live with it as is as it will be a bit of PITA to install insulation if the counter above is already in place. If not 2" foam insulation in top and lid with an airtight seal on the lid will definitely help keeping the hot out.
Blueboard is the DOW styrofoam hard board insulation if you didn't know. They advertise Blue Board as R5 per inch.
roverhi is online now
post #6 of 16 Old 04-14-2019 Thread Starter
krisscross's Avatar
Thanks for suggestions. The power draw by the unit is tolerable as is but I would love to cut it a bit. Draws about 6 to 7amps when running. And runs maybe 25% of the time. Perhaps the unit runs too cold. Ice sometimes forms on stuff near the cold plate.
Plato
post #7 of 16 Old 04-15-2019
Have you checked the seal around the hatch? Close a dollar bill in the seal and try to pull it out. If it sticks, the seal is good, if it pulls out easily, it's leaking. Of course, you'll have to repeat this around the perimeter. I think bad seals are the most common cause of humidity ingress and excessive run time.
Jeanneau 54DS
Minnewaska is offline
post #8 of 16 Old 04-15-2019
JimsCAL's Avatar
When you say "top" do you mean outside the box? If so, why not glue some sheet insulation to the top of the box but inside? I did that on my previous boat which had no insulation on the top of the box, only the plywood counter. It helped.
S/V First Tracks
1985 Cal 33-2
JimsCAL is offline
post #9 of 16 Old 04-15-2019
Too cold is something you want to avoid. I did this video when the boat first arrived in Florida:
https://youtu.be/Scu1wqOHIy0
Since then, I noticed that things were freezing in the refrigerator. So I bought a pair of fridge thermos and put one in the freezer portion and one in the refrigerator portion and adjusted the settings until the temperatures were correct in both places. I haven't timed it again, but I'm quite certain the compressor is running less often now.
Doing the same should reduce the power usage, but I doubt it's going to do much to reduce condensation on the top. That problem is the result of poor insulation and the only thing that will 100% solve it is better insulation.
post #10 of 16 Old 04-15-2019
SchockT's Avatar
I am surprised ambient fridge temp is enough to create condensation on the exterior, even with poor insulation.
Is it just the lid that is getting cold or is it the countertop? If it is the countertop is it possible that the evaporator plate is in direct contact with the underside? If that is the case, then unscrewing the evaporator and adding some spacers will help.
Some pics might help.
Sent from my SM-G960W using Tapatalk
2011 Jeanneau 39i Azura
SchockT is online now
ice ice baby QuickMick Provisioning 3 01-27-2011 09:37 AM
ICE, i now own an ice boat scottyt General Discussion (sailing related) 10 01-25-2011 08:29 PM
insulating? Captain_Rick General Discussion (sailing related) 0 02-23-2007 02:03 AM
Insulating an Icebox SailNet Gear and Maintenance Articles 0 07-22-2002 09:00 PM
Insulating noise Bunbury General Discussion (sailing related) 1 02-01-2001 08:19 AM
