Looking for the best temporary leak fix ... - Page 2 - SailNet Community
 1Likes
post #11 of 12 Old 4 Weeks Ago
Re: Looking for the best temporary leak fix ...
My eyes wander while I'm doing other things, and I was looking at that small gap between the toerail and the deck on both sides of the toerail. I was thinking, after I redo the deck with 2 part or gelcoat, and refinishing the toerail, taping and putting in a bead of black caulk of some form to keep water from intruding on the hull/deck joint. As with any compound, you'd probably want to go OVER the toerail finish so the raw teak wouldn't suck the life out of the caulk Just ruminating. I could make it look outstanding, but not sure the efficacy. It would keep water from getting under, but you've also got the track on the rail where water could be coming in through the bolts.
VIEXILE is online now
post #12 of 12 Old 4 Weeks Ago
Markwesti's Avatar
On our boat we have a wooden toe rial . The hull to deck joint is "L" on the hull and to a "L" on the deck and that was sealed with a bedding compound and then the wood cap rail was bolted down and then a bead of caulk on both sides . now that the Westsails are really old they all leak . The fix is easy , remove the old caulking and put new .
Westsail 28 , Patricia A
Markwesti is offline
Temporary Portlight Leak Stop midwesterner Gear & Maintenance 7 09-11-2017 06:41 AM
Temporary fix to deck cracks? abudoggie Gear & Maintenance 3 07-28-2014 04:53 PM
Soft deck temporary fix advice needed seafrontiersman Gear & Maintenance 7 03-23-2010 05:27 PM
Temporary Fix - Possible Exhaust Leak wolfmt Gear & Maintenance 8 08-18-2008 09:40 AM
