Looking for the best temporary leak fix ... - SailNet Community
 1Likes
post #1 of 12 Old 04-19-2019 Thread Starter
First off, I'm going to brag a bit ... my 40 year old Tartan 37 has only 1 leak. I've worked very hard to fix every other leak I've found _correctly_ so it will stay fixed for a long time.
However, I just discovered a new leak this week, and it's the toe rail that's leaking. Since I've got a lot of other projects to finish, and since the toe rail is a big job to remove to fix the leak properly, and since it is something that can be worked on at anchor ... I want to fix it temporarily (for 3 to 6 months) so I can get moving. I can fix it correctly later.
I'm theorizing that if I clean out the corner between the wooden toe rail and the fiberglass deck, and then fill it with something, I should be able to stop the leak for a time without going through all the disassembly/reassembly.
Does that seem like the most practical short-term fix until I can do the job right? Also, what would be the best product to fill that gap? I obviously don't want to use something like 5200 ...
BillMoran is online now
post #2 of 12 Old 04-19-2019
Re: Looking for the best temporary leak fix ...
I've used the same butyl tape for temporary leak stop that I use to bed hardware. For example, I put it around a leaking window on my Beneteau 23 until I could replace and reseal the window.
Because it's sticky,it will retain dirt and crud, so the aesthetics are yucky. However, I feel it's less messy that the usual "smear some silicone" solution. Also, you can kind of press it in place to help get a good seal. It is much easier to remove when time allows doing the job right. I used Colorimetrics Putty Tape / Butyl Tape (available through Amazon) on my boat.
Hope this helps.
Mark
BeneteauMark is offline
The Following User Says Thank You to BeneteauMark For This Useful Post:
BillMoran (04-19-2019)
post #3 of 12 Old 04-19-2019
colemj's Avatar
There is a product called Captain Tolly crack cure or something like that. It seems to be a latex or polyurethane that is water thin and can find its way into tight spaces. There are also penetrating epoxies that are very thin.
Mark
colemj is offline
post #4 of 12 Old 04-19-2019
1st thought...
Push butyl in there...them warm it up...heat gun etc...then push that again with other butyl over it.
BillMoran likes this.
RegisteredUser is online now
post #5 of 12 Old 04-19-2019
Towguy's Avatar
Marine goop
Northern Alberta. "85" C/L 16. ,"85"S2 7.9 under repair.
Towguy is online now
post #6 of 12 Old 04-19-2019
Captain Tolly's is a good product for minute leaks, it isn't designed to block anything more than a tiny hairline fissure.
'has only one leak'...care to take a bet on that?
paulinnanaimo is online now
post #7 of 12 Old 04-19-2019
I used a super glue to fill a crack in a hatch glass...and i 'think' that has worked.
Youre both filling and blocking when dealing with water intrusion like you have
You can get cheap vet syringes if needed to get into small places.
Dunno what yours looks like....
post #8 of 12 Old 04-19-2019
+1 on butyl. can you loosen the attaching screw just enough to get the butyl under the rail?
danvon is offline
post #9 of 12 Old 04-19-2019 Thread Starter
You're welcome to stop by and locate any leaks that I'm not aware of ...
post #10 of 12 Old 04-19-2019 Thread Starter
Not really ... anything like that is involved. First there's a track mounted on top the toerail that needs to be removed. Then all the screws have bungs in them that would need to be drilled out, then I'd probably have to loosen 3 - 5 screws to get anything loose. Then, of course, put all that back.
I could be wrong, but it seems that if I'm going to that much work I might as well just keep going and remove the entire section of toe rail and re-bed it. And that's the 1 or 2 days worth of work that I'm trying to find a temporary shortcut for ...
Temporary Portlight Leak Stop midwesterner Gear & Maintenance 7 09-11-2017 06:41 AM
Temporary fix to deck cracks? abudoggie Gear & Maintenance 3 07-28-2014 04:53 PM
Soft deck temporary fix advice needed seafrontiersman Gear & Maintenance 7 03-23-2010 05:27 PM
Temporary Fix - Possible Exhaust Leak wolfmt Gear & Maintenance 8 08-18-2008 09:40 AM
