Mounting over fibreglassed plywood question - SailNet Community
post #1 of 5 Old 04-21-2019 Thread Starter
Cruiser
argalax's Avatar
Question Mounting over fibreglassed plywood question
Ahoy,
I am making a (semi-) rigid bimini, made of fiberglassed plywood, and I want to mount flexible solar panels on top of it.
What is the best way of doing it?
SS nuts&bolts trough? Screws? ... Other options?
My main concern is water seeping alongside bolts or screws into plywood and eventually rotting it.
Also, having bunch of nuts sticking out visible from the inside is not esthetically pleasing.
Any suggestions?
Thanks.
argalax is offline
post #2 of 5 Old 04-21-2019
pdqaltair's Avatar
Re: Mounting over fibreglassed plywood question
Originally Posted by argalax View Post
Ahoy,
Any suggestions?
Thanks.
Another alternative, if you don't want potential leak/core problems, is to bond studs to the surface. This panel is mounted to custom studs that on FRP feet that are epoxied on. You can also buy the glue-on studs from Duckworks or Weldmount. They are nearly as astrong as the threads, if installed properly. I've used them for many things and never had a failure.
A nice feature of the studs is that you can use them to adjust for curvature of the roof, avoiding any stress on the panel. In this case, the frame is just 2 lengths of 2" aluminum angle.
See item 80a. http://sail-delmarva.blogspot.com/search?q=studs
With semiflexible panels there are even more options, including 3M Duallock. But rigid panels last longer.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #3 of 5 Old 04-21-2019
VHB tape.
Choose the right tape.
Bimini frame will come off before the panels fly away.
You can slice it if ever needed.
Has worked well for me.
RegisteredUser is online now
post #4 of 5 Old 04-21-2019
colemj's Avatar
Originally Posted by RegisteredUser View Post
VHB tape.
This. VHB tape has become the go-to thing on a boat for me. Think of it as 5200 that is actually user-friendly, non-messy, easy to use, easy to intentionally remove, but almost impossible to release otherwise.
Skyscrapers windows are held on using nothing but VHB tape.
Mark
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #5 of 5 Old 05-13-2019 Thread Starter
Cruiser
argalax's Avatar
Thanks for the replies.
I will try VHB tape.
argalax is offline
Caliber 33 mounting instruments over companionway mstorey Caliber 1 01-07-2019 07:05 PM
Fiberglassing Over Plywood jimmoser Gear & Maintenance 7 10-02-2011 04:37 AM
mounting instruments over companionway orientalnc2010 Pacific Seacraft 30 12-07-2008 09:49 PM
Technical Plywood Core question saurav16 Boat Review and Purchase Forum 4 05-16-2007 11:52 PM
Marine plywood VS. pressure treated (wolmanized) plywood duffer1960 Gear & Maintenance 8 03-03-2006 01:12 AM
