Tether overload protection - Page 3 - SailNet Community
 39Likes
post #21 of 29 Old 04-26-2019
Re: Tether overload protection
Originally Posted by SteffanieS View Post
I suspect they got tired of all us newbies getting seasick.
Either that or sailing outside of the gate is serious business. Sailing inside the gate is serious business.
MarkofSeaLife and SteffanieS like this.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is online now
post #22 of 29 Old 04-26-2019
Administrator
Jeff_H's Avatar
After watching a YouTube video on the testing of tethers, I'm fairly certain that if I fall off the boat attached to a tether, I'd better have a sharp rigging knife at the ready so I can cut myself free. It looked like a sure-fire way to drown. I'm assuming the only way a tether would save my life is to keep me on the boat in the first place. Barring that, the skipper had better be really good at stopping the boat on a dime or I'll drown at any boat speed above 2 knots.
On my own boat, I need to rig the jack lines so I won't go overboard. If I'm single-handed, the skipper will be me.
I'm going to order that $100 tether now...
In terms of carrying a sharp knife, modern tethers have a snap shackle at the chest ring that you can pull if you need to get free of the tether in a hurry. The sharp knife thing is actually pretty much of an urban legend since I can't imagine anyone actually being able to get their hands on a knife, open it, find and cut the tether while being dragged at several knots face first through the water.
The current thinking is that at any speed at all, the chest ring attachment of the tether will place the person being towed in a pretty dangerous position that is as likely to drown them as save them. There are some experimental harness set-ups that have a a back ring as well as a chest ring. These use a tether that has a snap shackle at the chest ring with a length of tether that runs to the back ring. If the person in the water feels like they are being drown by being towed, they can blow the chest ring and be towed from their back instead, which is safer in terms of drowning. But that set up only works with a crew on board to retrieve you since you can no longer reach the tether to pull yourself back aboard.
Having tried to pull myself aboard from the water in wet clothing, my belief is that if I were hanging from a tether with my body completely over the side, I have about a 50-50 chance of pulling myself aboard if I wasn't injured going over the side and almost no chance if i were injured. For me as a single-hander, the tethers and jacklines are solely to keep me on board and ideally inside the toerails from my waist up.
SteffanieS likes this.
Jeff_H is online now
post #23 of 29 Old 04-26-2019
PhilCarlson's Avatar
Dock
Originally Posted by Jeff_H View Post
...modern tethers have a snap shackle at the chest ring that you can pull if you need to get free of the tether in a hurry.
I'm curious about the use of a snap shackle in this application, having seen a few release at inopportune times in other applications. It would never even cross my mind to trust a snap shackle as a personal anchor. Seems like it would be the weak point in the system.
Thoughts?
PhilCarlson is offline
post #24 of 29 Old 04-26-2019
I dont disagree. I would expect a one handed safety latch.
Mine has snap shackle
RegisteredUser is online now
post #25 of 29 Old 04-26-2019 Thread Starter
Yeah, that didn't exactly sound feasible to me either. However, there are some tethers that attach to the harness by a loop, no shackle. There would be no release in this case. You can buy a gadget for slicing through the tether in a pinch, but I'm not sure it's much better than a knife.
That is exactly my plan on my own boat.
SteffanieS is offline
post #26 of 29 Old 04-27-2019
TQA
Bombay Explorer 44
TQA's Avatar
I flew hang gliders intensively for 10 years and then at odd times for the next twenty years.
After 30 years I decided to stop flying and cut up my harness. All the webbing straps showed signs of slight bleaching by the sun.
But all seemed still sound.
TQA is offline
post #27 of 29 Old 04-27-2019
pdqaltair's Avatar
ISO and World Sailing standards do not specify a quick-release at the harness end. Personally I would always have some manner of release; I've gotten on the wrong side of rigging numerous times and it is handy if you can just clip back around.
Whether a quick release is better has been debated. A singlehander will point out that spin shackles occasionally come loose, and they don't believe release is likely to save them. On the other hand, sailor have been trapped by tethers that didn't release; the Windnutz accident was high profile.
If you do have a snap shackle, remember that if you clip the unused tether to the harness you have defeated the quick release function (after release you will be held to the harness by the other leg--one of the Windnutz sailors made this mistake); you need to have a parking loop on the ether or clip it in to the snap shackle eye... if it is large enough, which most are not.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is offline
post #28 of 29 Old 04-28-2019
Having a cutting tool you can actually use when being waterboarded is always wise (lines under tension are also easy to cut). If you wear an inflatable PFD, the "rescue hook" style cutters may be both more effective and safer for the PFD. Still, I'd prefer a proper quick-release mechanism and I'm not convinced snap shackles are actually designed for that. In the WingNuts case, I think only one of the crew was able to use the snap-shackle release as intended.
Interesting reading is the PS article on tethers from back in 2011, which also mentions that it took 34-38 lbs of force to open the shackles under load: https://www.practical-sailor.com/iss...r_10574-1.html
As to improvised tethers, this is an area where climbers may better understand the forces involved. Fall factors are counted by the ratio of the fall distance to the available rope. A factor of 1 (you are at the anchor and fall the full length of the tether) represents a significant impact. A factor 2 fall means you climbed above the anchor and so fell twice the length of the tether. In drop tests, a factor 2 fall is sufficient to break Dyneema slings. (Humans are squishier, so more likely to break than the sling.)
Hopefully a boat presents less opportunity for such a fall; a more "gentle" slide under the lifelines will generate less force, and a connection to the jacklines means the length of the jacklines is also involved in absorbing energy. Still, the forces involved with "sudden stops" shouldn't be underestimated. This is why via ferrata gear includes shock absorbers; via ferrata falls can easily exceed factor 2. The takeaway? Try not to put yourself in positions where you could take a hard fall on a tether.
requiem is offline
post #29 of 29 Old 04-28-2019
pdqaltair's Avatar
Originally Posted by requiem View Post
... Fall factors are counted by the ratio of the fall distance to the available rope. A factor of 1 (you are at the anchor and fall the full length of the tether) represents a significant impact. A factor 2 fall means you climbed above the anchor and so fell twice the length of the tether. In drop tests, a factor 2 fall is sufficient to break Dyneema slings. (Humans are squishier, so more likely to break than the sling.)
The ISO and World Sailing standard includes a drop that is fall factor 1 but with slightly greater mass. About factor 1.3.
A fall factor 1.3 only means you've been thrown across the cockpit at 7 knots with a wave following you. It does NOT require an actual fall, only equivalent energy.
Can you overload a 12 volt battery? Bruce3966 General Discussion (sailing related) 58 09-15-2015 08:44 AM
West Marine Combine/Overload module??? csharp56 Electrical Systems 1 07-29-2013 06:27 AM
Don't watch these videos unless you are suffering from election overload disorder and knothead General Discussion (sailing related) 1 11-01-2008 09:56 PM
Toddler PFD-harness/ tether h20ski General Discussion (sailing related) 11 04-18-2006 02:59 PM
