Is tinned boat wire necessary? - Page 2 - SailNet Community
 31Likes
post #11 of 58 Old 04-29-2019
Dirt Free
boatpoker's Avatar
Re: Is tinned boat wire necessary?
Originally Posted by paulinnanaimo View Post
I respect boatpoker's opinion on these matters and I'm staying out of the debate. However, in this case, I think his photos are very misleading; those awful connections would not be any better if tinned wire had been used.
The point I was trying to make was that corrosion creeps. It will creep and do more damage to non-tinned than tinned.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #12 of 58 Old 04-29-2019
colemj's Avatar
I don't see anything in those pictures that has anything to do with the wire itself, and no sign of wire corrosion - or even what type of wire is being used. They really don't have anything to do with the tin/non tin discussion.
Mark
Manta 40 Catamaran "Reach"
colemj is offline
post #13 of 58 Old 04-29-2019
Dirt Free
boatpoker's Avatar
Mark
Wow, I thought my point was simple and clear. I guess not.
You win.
Minnewaska likes this.
post #14 of 58 Old 04-29-2019
When I rewired my old boat a 74 Ericson. I found so much corrosion in the old wires. So when i did the rewire I did everything up the highest standard I could, knowing the wiring would outlive the boat. It seems the real cost of a rewiring job is in the labor whether you are paying someone to do it or not paying yourself to do it. Why take any shortcuts?
CVAT and Minnesail like this.
Jordan
West Wight Potter 14 "Lemon Drop"
Oceanside CA
jephotog is offline
post #15 of 58 Old 04-29-2019
pdqaltair's Avatar
... In the US, there really isn't many choices for suitable marine untinned wire. I think that is why it gets such a bad rap - people are using unsuitable or cheap wire and not differentiating between applications. I suspect the costs are similar for good untinned wire and tinned wire.
Mark
Stranded THHN wire is the most common industrial wire in the US and is stocked by Home Depot, Lowes, and every electrical supply house. It is what is pulled through conduit. People may not know to look for it.
https://www.homedepot.com/p/Southwir...5858/203401697
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #16 of 58 Old 04-30-2019
Dirt Free
boatpoker's Avatar
ABYC standards cover much more than what has been discussed here, wire type, strand size, oil resistance of the insulation, temperature rating and voltage loss among others. I don't know if Home Depot conductors would meet those requirements.
Of course many have no use for ABYC Standards. To each his own.
post #17 of 58 Old 04-30-2019
celenoglu's Avatar
The cover of wire is osmotic. If you pass the wire from the bilge, water will osmotically pass to the wire and cause crevice corrosion. It is best to use tinned wire.
celenoglu is online now
post #18 of 58 Old 04-30-2019
colemj's Avatar
Here is HD's price for 100' of THHN - $28.37: https://www.homedepot.com/p/Southwir...5884/204868304
Here is 100' of tinned marine wire - $27.50: 12 AWG Primary Wire Marine Grade Tinned Copper Black 100 ft
Going with untinned wire in the US is not for cost reasons. Outside the US, it most likely is. I suspect anyone using untinned wire in the US, and having problems with it, is using cheaper stuff than THHN.
Mark
colemj is offline
post #19 of 58 Old 04-30-2019
colemj's Avatar
I'm pretty sure this is not true. At least not on less than glacial time scales. Likely, any issue with water will be one of wicking from a penetration, and not osmosis. Could you point to a reference regarding this? If osmosis and crevice corrosion is a concern with marine wire, tinned wire won't prevent it.
Mark
colemj is offline
post #20 of 58 Old 04-30-2019
hpeer's Avatar
My 2006 Yanmar wiring harness has untinned wire.
What about the engine in your boat?
33' Brewer, Murray 33, steel cutter
44' Pape, Steelmaid, cc steel cutter
hpeer is online now
Boat wire: is SAE tinned "good enough"? novic Gear & Maintenance 72 02-20-2015 02:41 PM
Tinned Marine Wire prior Gear & Maintenance 11 03-14-2010 12:27 PM
ABI LED Lights - NO tinned wire paulmcquillan Gear & Maintenance 0 06-20-2005 07:37 PM
tinned wire anneminix Gear & Maintenance 2 11-05-2003 11:55 AM
tinned wire anneminix Gear & Maintenance 2 08-25-2003 07:47 PM
