Is tinned boat wire necessary? - Page 3 - SailNet Community
 31Likes
post #21 of 58 Old 3 Weeks Ago
Moderator
MarkofSeaLife's Avatar
Dock
Re: Is tinned boat wire necessary?
Re-ran a bit of wire yesterday. Had the choice in my cupboard of tinned or untinned.
The run was from the bow nav lights through the anchor locker and into the forrard head connecting under the sink.
I went tinned
CVAT and elliowb like this.
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #22 of 58 Old 3 Weeks Ago
Id rather repair sewer lines than run wiring in a boat
MarkofSeaLife likes this.
RegisteredUser is online now
post #23 of 58 Old 3 Weeks Ago
bell ringer
And there there's the cruisers. When you need to replace a wire you have to use what is available. But I've personally never had to replace a wire, just a fitting on it. Unfortunately replacing a terminal lots of times becomes splicing in a new section of wire. I bet the cost of all the spare wire on the boat in my electrical bag is like $50. But the cost of the wire terminals etc. in the bag is at least $300.
Now I do run wires for new equipment on the boat. I think I tend to get that wire from a marine store just because there's one near me when I decide to do it. I also tend to oversize the wire.
Don't blow air up my rear, be useful and blow it at the sails!
Don0190 is online now
post #24 of 58 Old 3 Weeks Ago
SanderO's Avatar
My OEM wiring is not tinned as the boat was made in Holland. Some of the smaller gauges show corrosion... I discover this when I might want to replace a pump for example. So I simply change the wire to tinned... especially since there is not enough length to cut back to the shiny non corroded wire. I maintain several spools in different gauges and colors for this purpose. The entire main 12v wiring from the batts to the busses was all changed to tinned wiring when I upgraded the batteries.
I assume that corroded wire connections offer more resistance/less current or lower voltage will pass. Most of the loads are low enough that there is no danger of fire from heat. But 110v is another story.
pay attention... someone's life depends on it
SanderO is online now
post #25 of 58 Old 3 Weeks Ago
colemj's Avatar
Originally Posted by hpeer View Post
My 2006 Yanmar wiring harness has untinned wire.
What about the engine in your boat?
As I mentioned earlier, there are a lot of things on boats with untinned wire. I just replaced a brand-name bilge pump, a brand-name switch, and installed an expensive brand-name shower sump pump, and a waste pump. All of these are in wet places, and none of them came with tinned wire. In these cases, using tinned wire runs to them doesn't help much. Put the money into quality connectors and adhesive heat shrink instead.
Mark
Manta 40 Catamaran "Reach"
colemj is offline
post #26 of 58 Old 3 Weeks Ago
colemj's Avatar
Having done both of these things in the past week, I disagree. Personal preference, of course.
Mark
jblumhorst and MarkofSeaLife like this.
colemj is offline
post #27 of 58 Old 3 Weeks Ago
I've recently ripped out a significant percentage of the wiring in my boat for the electric motor conversion. Not a bit of it was tinned. However, some of it was so well wrapped that even at 25 years of age in a marine environment it still was free of damage, and my multimeter showed it was still well within spec.
The worst cables were corroded, but not so badly that they failed to work. I didn't find a single cable that wasn't well crimped. Whoever was in charge of wiring my Hunter originally definitely had an eye for detail.
Captain Canuck is offline
post #28 of 58 Old 3 Weeks Ago
Dirt Free
boatpoker's Avatar
How are you checking that with a multi-meter ?
If you are checking resistance by ohms, one intact strand can show 0.0ohms.
CVAT likes this.
The hysterical laughter you hear as you drive a way in your"new" boat ..... is the seller.
boatpoker is online now
post #29 of 58 Old 3 Weeks Ago Thread Starter
Minnesail's Avatar
My boat is only 22í and doesnít have a lot of systems, so there insít much wiring and the runs are short. The cost of the wire is negligible compared to the cost of fittings and the time consumed, so Iíve been using oversized tinned wire for everything Iíve replaced. Iím sure the wiring will outlive the boat, but thatís the case with most of the repairs Iíve done (like a bronze seacock on a 22í boat that will never see saltwater).
Catalina 22
on a starboard tack
Minnesail is online now
post #30 of 58 Old 3 Weeks Ago
pdqaltair's Avatar
Originally Posted by boatpoker View Post
ABYC standards cover much more than what has been discussed here, wire type, strand size, oil resistance of the insulation, temperature rating and voltage loss among others. I don't know if Home Depot conductors would meet those requirements.
Of course many have no use for ABYC Standards. To each his own.
Home Depot standards? Oh, for heavens sake. I'm guessing you ave no use for UL or ISO.
This is industrial wire from Southwire, which meets UL and ISO standards. It carries a second jacket to protect it from damage during pulling, is extremely oil resistant and heat resistant, and is used in refinery and steel mill applications you can't imagine.
This is apparently outside of your experience. It is common on ships.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
Boat wire: is SAE tinned "good enough"? novic Gear & Maintenance 72 02-20-2015 02:41 PM
Tinned Marine Wire prior Gear & Maintenance 11 03-14-2010 12:27 PM
ABI LED Lights - NO tinned wire paulmcquillan Gear & Maintenance 0 06-20-2005 07:37 PM
tinned wire anneminix Gear & Maintenance 2 11-05-2003 11:55 AM
tinned wire anneminix Gear & Maintenance 2 08-25-2003 07:47 PM
