Is tinned boat wire necessary? - Page 6 - SailNet Community
 31Likes
post #51 of 58 Old 05-10-2019
Re: Is tinned boat wire necessary?
No one's talking about "tinning" anything ourselves, but purchasing boat wire that's already been tinned along the whole length each strand as part of the manufacturing.
Doesn't even cost more per foot than the same grade cable untinned.
And forget solder full stop, proper milspec crimping shop here. . .
john61ct is online now
post #52 of 58 Old 05-10-2019
So twisted lamp cord wrapped in duct tape is bad...
MarkofSeaLife and oysterman23 like this.
SeanM26 is offline
post #53 of 58 Old 05-10-2019
colemj's Avatar
Originally Posted by riggy001 View Post
Use your best judgement as to exposure and either tin your tips or don't. I would. It can never hurt, and flux core solder is dirt cheap.
Actually, tinning tips can be harmful. I recently installed a few pieces of gear where a trimmed wire end is inserted into a clamp terminal and the terminal tightened down on the wire end. In all cases, the instructions had a separate warning section in bold type that said DO NOT TIN THE WIRE ENDS.
Besides, what good is tinning the tips if the rest of the wire can corrode?
Mark
SanderO likes this.
Dolphin 460 Catamaran "Reach"
- Current boat
- Previous boat
colemj is offline
post #54 of 58 Old 05-10-2019
pdqaltair's Avatar
Mark
The specific problem they are referring to is that with certain terminal types, the solder can soften with vibration and repeated heating/cooling, causing the connection to loosen. Thus the common admonition to not tin wire ends. This is quite distinct from using tinned wire, which is good practice.
Writing full-time since 2014
Author--Rigging Modern Anchors
"Keeping a Cruising Boat for Peanuts"
"Faster Cruising for the Coastal Sailor"
"Singlehanded Sailing for the Coastal Sailor"
pdqaltair is online now
post #55 of 58 Old 05-10-2019
Mark
A properly crimped connection actually creates a metal-metal colloidal bond at the surface between the wire and the terminal. If you tin the end that will connected you prevent the strands from arranging themselves correctly and from actually contacting the connector directly.
SeanM26 is offline
post #56 of 58 Old 05-11-2019
With ABYC screw-down connections, there is supposed to be a small plate in the connector that the screws tights on. The plate then compresses the wire. If you tin the end of the wire, it becomes solid which prevents the plate from compressing the wire. Iíve occasionally ďbunch tinnedĒ about 1/16Ē on the very end of small wires to make sure that I donít get loose strands pushed back when the wire is inserted. With most types of mechanical connections, soldering only makes things worse.
svinshallah is online now
post #57 of 58 Old 05-13-2019 Thread Starter
Minnesail's Avatar
It is my understanding that you really shouldn't solder anything on a boat. If you feel like you're getting loose strands aren't you doing something wrong?
Anyway, we're talking about tinned wire. Nothing to do with solder.
Catalina 22
on a starboard tack
Minnesail is online now
post #58 of 58 Old 05-13-2019
In general, Iím in agreement with Minnesail: itís almost always better to do a proper crimp connection with the appropriate terminals and tools. But Colemj made a point about not using solder on the ends of wires that are inserted into screw-down terminal blocks. Heís right, you usually donít need or want it. My point was that sometimes, where itís difficult to see that there are no loose strands pushed out of the wire when itís inserted into a block, one can use a little bit of solder at the very end of the wire just to hold the strands together. Itís a sometimes-useful technique when you canít see to insert the wires.
MarkofSeaLife likes this.
Boat wire: is SAE tinned "good enough"? novic Gear & Maintenance 72 02-20-2015 02:41 PM
Tinned Marine Wire prior Gear & Maintenance 11 03-14-2010 12:27 PM
ABI LED Lights - NO tinned wire paulmcquillan Gear & Maintenance 0 06-20-2005 07:37 PM
tinned wire anneminix Gear & Maintenance 2 11-05-2003 11:55 AM
tinned wire anneminix Gear & Maintenance 2 08-25-2003 07:47 PM
