Repowering- What to do with Old Engine? - SailNet Community
 4Likes
post #1 of 18 Old 05-04-2019 Thread Starter
rbrasi's Avatar
I'm in the process of trading out my Vetus 3.10 for a Beta 20. When an old engine is removed, what does the yard typically do with them? Is there a disposal fee, or do they have a refurbishing pipeline that they send it through?
1968 Cal 2-30
Sandpiper 2
MDR
rbrasi is offline
post #2 of 18 Old 05-04-2019
roverhi's Avatar
Re: Repowering- What to do with Old Engine?
Really depends on the condition of an engine, the number of them in service and whether the yard has the storage to keep the good parts. If the engine was still running and had some life left in it, they will probably sell it to someone who can't afford a rebuild. If it's a popular engine there may be a core value from a rebuilder. If there's a hole through the block or a broken crank, they might pull off the still good parts and sell them. For the most part, if the engine is trashed, would bet it just goes in the dumpster.
Unless they are paying you for the old engine and/or you give up ownership to the yard, the engine should still be yours to do what you want with it. If it's trashed, hauling it to a recycling facility may exceed the value, however. Advertising here, Ebay, or Craig's List in a major boating area should get you some interest in buying anything of value off the engine or the whole engine.
olson34 likes this.
roverhi is online now
post #3 of 18 Old 05-05-2019
Moderator
MarkofSeaLife's Avatar
Dock
The yard will do everything to steal your old engine.
Likely you did not need a new engine but were cohearsed by lies or circumstance to buy a new one.
They make more money selling & installing a new engine that fixing your old one.
So now you have a nicely built engine that the yard tells you is scrap but they will take off your hands.
They will then paint it up and sell it for thousands.
Thousands.
And give you nothing for it.
Mark
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
The Following User Says Thank You to MarkofSeaLife For This Useful Post:
chef2sail (05-05-2019)
post #4 of 18 Old 05-05-2019
When I converted to Electric Propulsion I sold my dead Westerbeke 27 engine to a fellow who purchased the same model boat that had sunk and he was bringing back to life. Sold the engine for $500 and transmission for $700. He did the rebuild himself spent $3,500 in parts and ran it for two years and then he replaced it.
Mike
Currently: Heading to warm waters over the winter on a variety of boats.
mbianka is online now
post #5 of 18 Old 05-05-2019
It really depends. If it was still running or could be easily made to run, it has value. If it was shot, it could cost money to junk it. Stripping and selling parts is a crap shoot. If you retain the motor to sell yourself, you’ll have to store it for an indefinite period of time, deal with negotiating a sale, then deal with shipping or other form of delivery.
In any event, it’s your motor, so you should remain in control of its destiny. Does you estimate from the yard specify what happens to it, ie the yard disposes.
Jeanneau 54DS
Minnewaska is offline
post #6 of 18 Old 05-05-2019
TQA
Bombay Explorer 44
TQA's Avatar
If it is a runner video it starting and running. This makes it MUCH easier to sell.
Stick it on EBAY.
TQA is offline
post #7 of 18 Old 05-05-2019
Question Re: Repowering- What to do with Old Engine?
Not identical of course, but similar experience for us last year. I gave away a decent-running Universal 23 hp diesel engine complete. I shopped it around a little and could get $1K for it, but thought it over and just gave to a friend who is rebuilding it to repower an older boat with a long-in-the-tooth Universal two cylinder engine.
In my situation, the panel had no value and the harness was overdue for replacement, the engine had quite a bit of blow-by, and with 2200 hours the original Hurth 50 trans was a huge question mark.
Our new Beta 25 was almost $10K with larger panel and upgrade alternator.
Everyone has a different calculation for making this work.
I talked to several experienced diesel mechanics and decided that IF I took out the original drivetrain and rebuilt and replaced everything that needed work, I would be out 5 or 6K, and still have an "old" engine.
The new Beta is SO much more quiet and the vibration is much less! I repeat: it's Quiet.
Obviously we are in this for the 'long haul' so we do expect to amortize out the expense in reliability at the least. I also figure that the Beta is a good gamble because our moorage has quite a large number of similar engine replacements in the last ten years.
(There have been some other brands installed that proved to be a lot less reliable, but that's a subject for a different thread. Experienced wrench turners can likely guess what those are......)
eherlihy likes this.
1988 Olson 34, by Ericson Yachts.
Sail # 28400
Betamarine 25 (new 2018)
RCYC, Portland, Oregon
olson34 is online now
post #8 of 18 Old 05-05-2019
davidpm's Avatar
What else did that 10K include if you don't mind mentioning?
Transmission
shaft
prop
fuel tank
control panel
shifter and throttle
Remove old engine
Prep engine bed
Did you do a lot of the work yourself?
OK spill what happened to the other engine brand install, and what brand was it?
davidpm is offline
post #9 of 18 Old 05-05-2019
chef2sail's Avatar
Dave,
T37Chef repowered with a Beta for his Tartan 37 or around that amount and was very happy with the Beta
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #10 of 18 Old 05-05-2019
I priced a 25 beta a few years ago...as a what if.
Didnt need it but the straight answer then was 10k with tranny.
Extras...are extra.
It seems like beta has had good success in repowers. Their attempts at plug n play replacements are well received and a big reason for that success...imo.
Done right...youre probably buying the last drivetrain you will buy...for your lifetime
RegisteredUser is online now
Repowering - Need help on figuring out if this engine will work chowdan Engines 2 04-28-2016 11:11 PM
old engine, new engine paikea Engines 24 04-05-2016 11:34 AM
Repowering with an electric engine? CaptainRahnn Electric/Hybrid 157 09-24-2014 11:43 PM
Repowering - Newer engine models SailRedemption Diesel 15 04-21-2014 09:30 AM
which engine for repowering? prussell Diesel 8 02-01-2014 05:19 PM
