Polyurethane foam insulation - Page 3 - SailNet Community
 11Likes
post #21 of 21 Old 05-09-2019 Thread Starter
Re: Polyurethane foam insulation
Originally Posted by Scandium View Post
Great, please let us know what they say.
As mentioned it was my sense that the fire rating test was for attics and non-occupied spaces. Where the code assume people, and hence many ignition sources, don't go regularly (not to say there aren't any). So I'd guess the manufacturer says this is a non-approved install, but who knows.
edit: and if you want to help the field of fire science (and my job) also post the result of your ignition test
This is the foam company reply, common sense.
"The foam is classified as combustible and should not be exposed to high temperatures (> 250F.) or ignition source. This foam product needs open air flow to dry properly"
Pasadena is offline
what glue for attaching foam insulation to the cabin interior? peterchech Gear & Maintenance 13 01-02-2013 10:07 PM
Painting with 2-part polyurethane lapkanash Gear & Maintenance 15 06-12-2002 11:43 AM
Sound Insulation Foam Sue & Larry Gear and Maintenance Articles 0 01-31-2002 07:00 PM
2 part polyurethane paint mikehoyt Gear & Maintenance 1 11-23-2001 07:20 PM
Sanding Clear Linear Polyurethane Don Casey Gear and Maintenance Articles 0 02-27-2000 07:00 PM
