Docklines - How long should they be? - Page 5 - SailNet Community
 17Likes
post #41 of 50 Old 05-12-2019
paulk's Avatar
Re: Docklines - How long should they be?
We use our old spinnaker sheets to tie up when we go in to a dock. They're about 2x boat length, so the bow & stern lines can be cleated off to the dock and then come back to the boat as a spring line. In a slip they're long enough to be cleated in the middle on board and then led off P&S to the fingers. We're moored or anchored most of the time, so don't worry much about them.
MarkofSeaLife likes this.
paulk is offline
post #42 of 50 Old 05-13-2019 Thread Starter
Moderator
MarkofSeaLife's Avatar
Dock
Originally Posted by fallard View Post
We have 6 ea. 1/2” color-coded dock lines of different lengths
This has been a great suggestion. Everyone I've mentioned it to says it's a terrific idea.
However, the 4 marine stores here have it in only 1 colour each, 2 colours overall: black and v dark blue that looks black. The Dark blue visiting 10% more.
Lol
Length of the long ones gradually increasing After @paulk s post I think they will each be 100 metres long...
Sea Life
Notes on a Circumnavigation:
People can say they want freedom, but offer them the keys to what chains them, a map to where they want to go,
And they'll turn it down for the cell they know
MarkofSeaLife is offline
post #43 of 50 Old 05-13-2019
SanderO's Avatar
Lol
Can you order from Defender? They might have the colors/thickness and lengths you want. You can also have the loops made up... but colors are mostly in braided line.
pay attention... someone's life depends on it
SanderO is online now
post #44 of 50 Old 05-13-2019 Thread Starter
Moderator
Dock
I am in France.
Viva La Revolution!
Sea Life
post #45 of 50 Old 05-13-2019
fallard's Avatar
We leave the color-coded docklines on the dock: the spliced loops go on the boat and the bitter ends are cleated on the dock, once the correct length is determined. They stay there for the season.
Our normal approach to the dock is to back down at an angle to the dock, using the dock wheel as a fender. Draped on the dock wheel is the blue spring line, ready to be picked up with a boat hook and looped over the midship cleat. This is the important line, as we are backing into the (normally) leeward side of the dock in shallow water with the keel and rudder retracted.
We then pick up the bow lines, hooking at least one of them to the appropriate bow cleat. (Red-port, green-starboard). As the boat backs down against the dock, the bow lines(s) allow the boat to settle in parallel to the dock. Then we secure the white stern lines (not shown).
The important part is attending to the spring and at least one of the bow lines. By using the color coding, we can instruct unfamiliar crew with what goes where.
It helps to get it right the first time, as boat is not very maneuverable with the “landing gear” retracted and the muddy bottom comes up within a boat length from the docked position. If you don’t spring the boat promptly, the rudder will dig into the mud at low tide and keep the boat from swinging against the dock.
fallard is online now
post #46 of 50 Old 05-13-2019
chef2sail's Avatar
Like the wheel idea.....Ron, where are the sails🙀🙀🙀
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
post #47 of 50 Old 05-13-2019
fallard's Avatar
It’s Fred, not Ron. The sails were removed before taking the boat to the marina for seasonal haul-out. The thumbnail was taken in October 2018.
post #48 of 50 Old 05-13-2019
chef2sail's Avatar
Sorry Fred......not sure where I came up with Ron
Boat looks great👍
Parkville, Maryland
Our blog-
post #49 of 50 Old 05-14-2019
Clever but might be a little wimpy... and require the board spacing and construction to permit insertion... AND they seem to take longer to untie when you are casting off... especially when under tension...
Yeah, looks clever. Probably OK for a dinghy. But I would not want to hang my boat on the nails that keep the dock boards down. Actually, they are not even good at keeping the boards 'down.' There are some low-lying docks in my marina where the water gets over the dock boards occasionally during spring tides, and it is not unheard of that boards are dislodged by the rising water.
MastUndSchotbruch is online now
post #50 of 50 Old 05-14-2019
I cant imagine a dock owner wanting that used
RegisteredUser is online now
For Crew: How to Handle Docklines SavvySalt Maintenance/How-to Videos 54 04-03-2017 05:47 PM
Squeaking and Creaking of Docklines and Fenders... MedSailor Gear & Maintenance 13 09-02-2011 11:32 AM
What do you do with docklines? Honda800 Seamanship & Navigation 18 07-15-2011 07:38 PM
Attach docklines to Pilings arknoah Learning to Sail 11 05-20-2011 10:56 PM
Casting off the docklines PBzeer General Discussion (sailing related) 17 11-16-2006 05:58 PM
