Fiberglass checks - Page 2 - SailNet Community
 13Likes
post #11 of 32 Old 05-10-2019
fallard's Avatar
Re: Fiberglass checks
I donít see any problems in your photos. Unlikely that your bottom was sandblasted, as that would be too aggressive. Probably soda or walnut shells were used. The blush you are seeing is probably residue from the original bottom paint, which is what I saw when my bottom was walnut shell blasted. I used a palm sander with 80 grit paper to easily remove the residue to get down to the white gel coat. After washing the bottom, I then used an epoxy fairing compound to fill the pinholes.
Those pinholes were predicted by the bottom blasting crew, who said they are expected after the blasting operation with any boat.
Once the fairing layer was applied and sanded, it was time to apply barrier coats (4 layers of Interlux 2000). My boat had vinylester gelcoat, so it wasnít really necessary, but made me feel good. Besides, the Interlux 2000 makes an excellent prime coat for the ablative bottom paint I then applied.
Bottom line: I donít see a problem, based on your photos. Also, the hard work on your bottom has been done and the remaining work is well within the capabilities of a do-it-yourselver.
Pasadena likes this.
fallard is online now
post #12 of 32 Old 05-10-2019 Thread Starter
This sounds fantastic, thank you fallard. Great information to have when I see the owner again and very reassuring.
Pasadena is offline
post #13 of 32 Old 05-11-2019
fallard's Avatar
Please be aware that your photos provided limited information and that there may be other issues with your bottom that a professional assessment may uncover. Having someone knowledgeable to sound the hull by tapping it all over would be the first step. A good surveyor would do this along with a moisture check.
BTW, “sandblasting” alone does not fix an actual blister problem, but does provide a better view of the hull condition.
post #14 of 32 Old 05-11-2019
Pasadena, be careful you don't just hear what you want to hear. Fallard didn't say that hull was fine, only that it might be. We both said we can't see blistering in those photographs. It may be there, if you think you saw it. I'd need to see a close up pic of what you believe is a blister.
I thought this was your boat, but take it you are shopping. Try not to buy a project boat, but redoing a bottom is not all that big a deal. Just factor the cost into the price. Not your cost, but the cost to have it done properly. Then, if you do it yourself, that's fine, but the value of the boat is based on commercial repair costs.
Jeanneau 54DS
Minnewaska is offline
post #15 of 32 Old 05-11-2019 Thread Starter
Absolutely, I am going with someone for a second opinion. I haven't seen the blistering myself yet. The owner told us that there was some and decided to do the bottom as a preventive measure but then bought another boat.
Pasadena is offline
post #16 of 32 Old 05-11-2019 Thread Starter
Yes, we are trying to be as objective as we can. But this boat has everything we were looking for, so it's easy to be bias and over optimistic.
Everything checks so far. It has work to be done, but it's similar on all the boats that we have seen, unless you look the other way. The boats we are looking at are all about 40 years old. The fleet is getting old, so are we if we keep looking. We want to sail this summer, hopefully in the water not on the dock ))
Pasadena is offline
post #17 of 32 Old 05-11-2019
I am currently media blasting my hull and noticed the same thing. Had one of the local boatyard guys come over and fed him beer to take a look at it. He dug through several of them with and awl and flashlight to make sure they weren't in to the layup and told me basically what was said above. Once the hull has been blasted, then sanded to gelcoat, apply a coat of primer to fill everything, sand it smooth, fair any that weren't completely filled, then add several base coats.
SeanM26 is offline
post #18 of 32 Old 05-11-2019
Pasadena-
Look on YouTube for Sail Life Athena. Athena is the boat he's rebuilding, and Mads stripped down and rebuilt the entire hull in the process, all nicely documented. You'll get some idea of what you're getting into.
The "blue" in the pinholes also makes me suspect it is old bottom paint, so whatever they did, you've got a typical problem that the sanding or grinding drove contaminants into the material and more fine sanding plus solvent washing would be required to make sure they are all out. You'll also find that many yards have rules about what work you can DIY on the boat, and for frp repairs you will want a respirator (to keep the frp particles out of your lungs) and face mask, a full tyvek suit, a lot of work and not cheap to build up all the layers properly again. And, if you finished this, working outdoors and allowing for the weather, in less than two months I'd be surprised. That's two months of yard fees and no sailing.
The owner probably bought the second boat because he realized it would be cheaper than trying to finish the hull repairs. Bear that in mind.
hellosailor is offline
post #19 of 32 Old 05-11-2019 Thread Starter
Thank you for sharing. Great to see for comparison, and good luck with the work
Pasadena is offline
post #20 of 32 Old 05-11-2019
overbored's Avatar
is the boat in a yard that will let you do the work? do you know how to do the work? do you have a couple of friends that are going to help you? do you have the equipment that it will take to do the work? do you realize how long it will take to do the work? if you think so then triple it. and it will even take longer then that. it is not just the time to do the work you also need to include the time to get ready to do the work, gather the supplies and material and tools. the time to prep yourself and the environment where you are doing the work so you do not apply the finish to yourself or the neighbors boat. boats are tall, remember you will be doing some of the work from a ladder or scaffolding which cost money and tend to grow legs at night and can walk away. and the rest of the work will be done bent over looking up and holding a sanding board over your head and moving it back and forth for hours if you arm can handle that. and then after all that stuff you need to include the time it will take you to recover from the work that you did the day before.
the thought of someone thinking of getting that boat ready for this summer sailing season, well that just make me remember back a few years when I had those thoughts and then I have to laugh.
"GOLD RUSH" PRINDLE 16
overbored is online now
Automated Marine VHF Radio Checks wwilson Electronics 11 07-12-2015 12:20 PM
Aug 3rd can't promise SS checks will go out" More terror tactics against the mature? deniseO30 Politics, Current Affairs, Guns & HOT Topics 27 07-18-2011 12:37 PM
Sailing Checks? sealover General Discussion (sailing related) 6 02-20-2011 08:27 AM
ID Checks for everybody MIKEMCKEE Politics, Current Affairs, Guns & HOT Topics 4 07-06-2010 08:24 AM
After Sail Checks/PM PalmettoSailor Gear & Maintenance 20 06-05-2006 09:17 PM
