SailNet Community (https://www.sailnet.com/forums/)
-   Gear & Maintenance (https://www.sailnet.com/forums/gear-maintenance/)
-   -   Remove dried salt from porthole glass (https://www.sailnet.com/forums/gear-maintenance/329586-remove-dried-salt-porthole-glass.html)
fune31 05-11-2019 12:48 PM
Does anybody know of a good product or home made solution to remove dried salt from porthole glass?
I have tried white vinegar and a lot of elbow grease. But, that dried salt will just not go away.
capta 05-11-2019 01:02 PM
Re: Remove dried salt from porthole glass
We just rinse with fresh water. Salt is 100% water soluble. Even after days in the sun and wind, the salt just washes off our Eisenglass dodger windows, and they are a lot more prone to scratching than porthole material.
chicory83 05-11-2019 01:07 PM
Mild acids like the acetic acid in vinegar should be good for removing residual calcium carbonate, but there are more aggressive products you can buy in a hardware store for removing lime scale that may work better. Before you try one of them I would try to increase the contact time by soaking a cloth in vinegar and securing it against the window for a while. Increasing the temperature will also increase the rate of reaction, moderate warming might help the process along.
SeanM26 05-11-2019 02:07 PM
CLR diluted in hot water.
paulinnanaimo 05-11-2019 02:14 PM
Are you certain that you are dealing with dried salt and not abrasive scratches for example?
hellosailor 05-11-2019 02:53 PM
If it is salt, as the others said, that's water soluble and letting it get damp (cover with damp paper towels & wait) would let it come off easily.
If it is NOT salt, and the portlights really are glass, one alternative is to take a fresh single-edged razor blade and carefully hold it at a low angle, and scrape. Unless you dig a pointy corner of the blade into the glass, this works on windshields, glass stove tops, portlights, windows, no problem. Some folks will take a stone or fine sandpaper and just round off the corners of the blade to make sure it can't nick.
Home-made glass cleaner often is salt and lemon juice and water, so perhaps a little lemon juice would also help.
Thank hard: If it is not salt, what else could it be?
fune31 05-12-2019 11:49 AM
Thank you for the responses.
rocullen 05-15-2019 04:15 AM
I use vinegar and calcium lime rust remover.
Copyright ©2000 - 2019, vBulletin Solutions, Inc.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
User Alert System provided by Advanced User Tagging v3.1.0 (Pro) - vBulletin Mods & Addons Copyright © 2019 DragonByte Technologies Ltd.
