Head pump sticks - SailNet Community
post #1 of 6 Old 1 Week Ago Thread Starter
Head pump sticks
I have a manual pump head that I installed about 2 seasons ago. The pump on it is starting to stick a lot. Especially now that she just went back in the water after sitting all winter. Can I use lock carbon on it or WD40? Is there a special lube for it.
wind cree is offline
post #2 of 6 Old 1 Week Ago
Re: Head pump sticks
Lube the shaft and dribble a bit of canola oil at IT,,, (Dry bowl) ,,,,regular treatment
Capt Len is online now
post #3 of 6 Old 1 Week Ago
A few years ago, my manual pump was squealing a lot. I poured a couple ounces of cooking oil in the head. Squeal went away and pump worked much better. Seems I got the idea from Peggy Hall.
Catalina 34
chuck53 is offline
post #4 of 6 Old 1 Week Ago
Cassidy's Avatar
What pump do you have?
If it’s the ubiquitous Jabsco, there is a large nut that forms the seal holder in top of the pump. Using an adjustable spanner (wrench in USA ) pull the pump handle to the top, undo the nut, tip the shaft to the side to vent the pump (stops water spilling into the boat) and remove the plunger. A small amount of waterproof grease on your finger, wipe it onto the inside of the pump cylinder and reassemble.
Takes five minutes, will stop the sticking for a few months. There will be some who say “oh yes, but the grease will damage the seal”. Yes it will over several years. When it does, a dollar will buy a new o-ring that will last the next five years. Insert it next time you fix the sticky. 😊
Cassidy is offline
post #5 of 6 Old 1 Week Ago
colemj's Avatar
Don't bother with cooking oil, etc - they last a week or two at best, and are not the correct solution.
Do what Cassidy recommended, only use SuperLube as the grease. This is what the toilet is manufactured and shipped with, and it will not harm the seals.
A dose of SuperLube and it won't squeak for 6-12 months.
https://www.homedepot.com/p/Super-Lu...1030/202932687
Mark
Manta 40 Catamaran "Reach"
colemj is offline
post #6 of 6 Old 1 Week Ago Thread Starter
Thanks very much to everyone for the responses.
Turbo wastegate sticks Minnewaska Gear & Maintenance 2 09-07-2015 07:35 PM
the head pump is harder to pump ekenna Gear & Maintenance 6 06-03-2010 09:28 AM
Pulled the sticks and didn't break anything CharlieCobra Gear & Maintenance 7 08-15-2009 08:46 PM
Anchor chain sticks in windlass dhornsey Gear & Maintenance 8 08-05-2008 08:43 PM
What sticks to teak? jr438234606 Gear & Maintenance 2 10-26-2006 10:11 PM
